Subscribe to our Updates
  • Home
  • GT500 Project
  • Exhaust
  • Blog
  • Mustang Videos
  • Mustang Classifieds
  • 2011 Ford Mustang
  • Mustang Apparel
  •   !NEW! Fiesta Forums
Filed Under: Mustang Tech
S197 Ford Mustang Technical Service Bulletins23 Sep
StangNet.com is proud to present late model (S197) Ford Mustang owners with an updated and organized listing of all technical service bulletins (TSBs) released by Ford, to date.  Be sure the computer you are using has the Adobe Reader software installed so you can read each of the documents listed in the table below.  As more information is released, we will be sure to keep you updated.
Technical Service Bulletin ID
Description
04-9-6 BODY-PAINT-IRON PARTICLE REMOVAL-INDUSTRIAL FALLOUT-ACID RAIN NEUTRALIZATION
04-14-7 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES-SERVICE TIPS
04-16-1 ENGINE MISFIRE OR ROUGH RUNNING-COIL ON PLUG (COP) IGNITION SYSTEMS-WDS COP KIT DIAGNOSTIC TIPS
04-24-14 GENERAL PCM PROGRAMMING PROCEDURES
04-26-16 WELD BONDING PROCEDURE
04-24-20 LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED MANUEVERS (SUPERCEDES 04-17-5)
04-24-5 REAR WINDOW DEFROSTER GRID-INTEGRAL ANTENNA DIAGNOSIS AND REPAIR-TERMINAL TAB REPAIR
04-26-22 MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTICE TROUBLE CODES (DTCS) P035X AND NO DRIVABILITY SYMPTOMS-4.6L 3V ENGINE
05-3-1 MAF DIAGNOSTIC SERVICE TIP-VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
05-4-8 FUEL FILL SLOW, OR DIFFICULT TO FILL
05-6-9 INTERMITTENT CD PLAYER CONCERNS
05-6-15 AIR BAG WARNING LAMP ON-DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53-VEICLES BUILT BEFORE 10/02/2004
05-7-3 AXLE WHINE-VEHICLES BUILT THROUGH 11-15-2004
05-8-6 EXHAUST VIBRATION AT 850 RPM-4.0L ENGINE AND AUTOMATIC TRANSMISSION
05-8-8 GROWL-GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION-TR3650 MANUAL TRANSMISSION-VEHICLES BUILT BEFORE 1-15-2005
05-9-3 INTERIOR PLASTIC TRIM-PAINT-TO-MATCH AND REPAIR-INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-9-11 FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT-VEHICLES BUILT BEFORE 4-8-2005
05-9-14 CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
05-9-15 MIL AND ETC LAMPS ON WITH BOTH DTC P2106 AND P2135-VEHICLES BUILT 11-29-2004 AND PRIOR
05-9-18 DISCHARGED BATTERY-CHARGING SERVICE TIPS
05-10-19 INTERMITTENT CD PLAYER CONCERNS-AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS SUPERCEDES 05-06-09
05-14-4 WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135-VEHICLES BUILT 11-29-2004 AND PRIOR (SUPERCEDES 05-09-15)
05-15-2 GROWL-GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION-TR3650 MANUAL TRANSMISSION-VEHICLES BUILT BEFORE 2/21/2005
05-15-8 TICKING AND-OR KNOCKING NOISE FROM ENGINE-4.6L-5.4L 3V
05-15-12 FUEL FILL SLOW, OR DIFFICULT TO FILL-VEHICLES BUILT BEFORE 4-26-2005 (SUPERCEDES 05-4-8)
05-15-13 FRONT SIDE MARKER LAMP RETAINING TAB BREAKING
05-16-12 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES-SERVICE TIPS
05-17-14 LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT
05-18-10 BRAKE NOISE-VEHICLES BUILT BEFORE 3-8-2005
05-18-7 WIRING-SOLDERING AND CRIMPING REPAIRS-SERVICE TIPS
05-19-10 LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT (SUPERCEDES 05-17-14)
05-20-2 REAR AXLE NOISE
05-21-2 LIMITED SLIP AXLE MOAN-GROAN NOISE DURING LOW SPEED TURNING MANUEVERS
05-22-8 WDS COP KIT DIAGNOSTIC TIPS-COIL ON PLUG (COP) IGNITION SYSTEMS-ENGINE MISFIRE OR ROUGH RUNNING
05-23-17 DIAGNOSTIC TROUBLE CODE (DTC) P0340/P0344/P0345/P0349-4.6L 3V AND 5.4L 3V
05-24-6 CONVERTIBLE SYSTEM CONCERNS
05-25-15 MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020-4.6L 3V
06-1-5 DTC P1000 MAY NOT CLEAR IN HIGH ALTITUDE CONDITIONS
06-2-9 DTC P0340-P0344-P0345-P0349-4.6L 3V AND 5.4L 3V (SUPERCEDES 05-23-17)
06-3-13 FUEL FILL SLOW, OR DIFFICULT TO FILL
06-4-1 RATTLE/NOISE FROM CENTER STACK (RADIO/HEATER) OF THE INSTRUMENT PANEL OR GEARSHIFT AREA
06-4-2 BATTERY SERVICE-OPERATION OF BATTERY EYE-CHARGING SERVICE TIPS (SUPERCEDES 05-09-18)
06-4-7 TICKING AND-OR KNOCKING NOISE FROM ENGINE-4.6L-5.4L 3V
06-4-9 A-C COMPRESSOR NOT OPERATIONAL-LOW FREON-SHAFT SEAL LEAKS
06-5-4 PARK BRAKE CABLE FREEZING-REAR BRAKES DRAGGING
06-7-10 MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020-4.6L 3V (SUPERCEDES 05-25-15)
06-9-9 HESITATION ON ACCELERATION AFTER LONG CRUISE
06-9-11 LOUD TICKING NOISE-3-VALVE ENGINES-STUCK LASH ADJUSTER
06-10-1 AIR CONDITIONER COMPRESSOR CLUTCH FAILURE-REVISED COMPRESSOR CLUTCH
06-10-10 AUDIO/NAVAGATION SERVICE AND ORDERING PROCEDURES
06-10-13 MIL P0463 OR ERRATIC FUEL GAUGE
06-10-5 5R55S-TRANSMISSION FLUID LEAK
06-12-11 LIMITED SLIP AXLE MOAN-GROAN NOISE DURING LOW SPEED TURNING MANUEVERS (SUPERCEDES 5-21-2)
06-14-3 AIR CONDITIONER COMPRESSOR CLUTCH FAILURE-REVISED COMPRESSOR CLUTCH (SUPERCEDES 06-10-1)
06-18-16 IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES-SERVICE TIP
06-19-2
8.8 LIMITED SLIP AXLE MOAN-GROAN NOISE DURING LOW SPEED TURNING MANUEVERS (SUPERCEDES 06-12-11)
06-19-5 CONVERTIBLE TOP WEAR
06-19-8 TICKING AND OR KNOCKING NOISE-STARTUP RATTLE FROM ENGINE 4.6L-5.4L 3V (SUPERCEDES 06-4-7)
06-19-12 DTC P0340-P0344-P0345-P0349-4.6L 3V AND 5.4L 3V (SUPERCEDES 06-2-9)
06-10-10 AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES
06-21-07 AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES (supercedes 06-10-10)
06-21-19 HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY) (supercedes 01-15-06)
06-22-16 CONVERTIBLE TOP WEAR—BUILT BEFORE 10/11/2006 (supercedes 06-19-05)
06-22-18 POWER WINDOW DIAGNOSIS
06-25-15 ALUMINUM BODY PANELS—CORROSION—SERVICE TIP
06-26-01 MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS
06-26-02 CARPET REMOVE AND REPLACE
07-01-07 MERCON ATF REPLACED BY MERCONâ V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS
07-03-09 MIL ON—DTC P0456
07-04-03 LEATHER-WRAPPED STEERING WHEEL—LEATHER COMING LOOSE
07-05-08 BATTERY SERVICE—OPERATION OF BATTERY EYE—CHARGING SERVICE TIPS
07-05-13 DISCHARGED BATTERIES—VEHICLES IN STORAGE/LIMITED USAGE
07-06-07 SPOILER/DECK LID CONTACT
07-10-03 AIR BAG WARNING LAMP ON—DTC 2295 IN RESTRAINTS CONTROL MODULE AND LAMP FLASH CODE 22—BUILT 3/1/2007- 4/15/2007
07-12-03 RCM FAULT REPORTING USING DTCS AND BIT-MAPPED PARAMETER IDENTIFIERS (PIDS)—SERVICE TIPS
07-14-06 WATER LEAK—FRONT FLOOR AREA
07-18-01 FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT—VEHICLES BUILT BEFORE 4/8/2005
07-18-02 FRONT END NOISE OVER BUMPS
07-19-01
CONVERTIBLE TOP WEAR—BUILT BEFORE TSB 10/11/2006 (supercedes TSB 06-22-16)
07-20-03
CONVERTIBLE TOP—TENSION CABLE NOISE—BUILT TSB BEFORE 12/1/2006
07-21-12
FUEL FILL SLOW, OR DIFFICULT TO FILL TSB (supercedes TSB 06-03-13)
07-22-08
8.8 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS (supercedes TSB 06-19-02)
07-23-01
GRUNT/CREAK/SQUEAK/CHIRP NOISE FROM THE LOWER CONTROL ARM BUSHING OVER BUMPS—BUILT BEFORE 2/28/2007
06-15-2 SPARK PLUG REMOVAL INSTRUCTIONS—5.4 3V
08-17-03 CONVERTIBLE—REAR QUARTER GLASS—TORN/SEPARATING QUARTER GLASS DIVISION BAR
08-04-02 COLD START FEAD HOOT—WHISTLE NOISE / BUILT BEFORE 1/28/2008
Bookmark and Share
Tags: tech, tsb
3 Responses to “S197 Ford Mustang Technical Service Bulletins”
  1. Ron Short (November 16th, 2009 at 8:24 pm)
    We have 2006 Mustang GT and have had a consistent cold start grinding noise immediatly after starting, lasting 1-3 seconds. We had it into the dealer several times and left it over several nights. They could hear it on several occasions but could not diagnose it. Any hints as to what it might be. Just recently it has gotten worse.
    Thank you,
    Ron
  2. mraburn (November 16th, 2009 at 9:15 pm)
    Please visit our 2005 + Forums to get help from our community.
    http://www.stangnet.com/mustang-forums
    Mike
  3. R. F. (December 5th, 2009 at 2:13 pm)
    In the last 6 mo. have had “check engine” light pop on. All 3 times has been from the gas cap. Any information?
Leave a Reply
Click here to cancel reply.
Sponsors
[Advertise Here]
Categories
  • 2010 Mustang
  • 2011 Mustang
  • Aftermarket
  • Events
  • Featured
  • Ford
  • General
  • Mustang Tech
  • Videos
Archive
  • February 2010 (4)
  • January 2010 (7)
  • December 2009 (18)
  • November 2009 (11)
  • October 2009 (9)
  • September 2009 (12)
  • August 2009 (10)
  • July 2009 (16)
  • June 2009 (16)
  • May 2009 (14)
  • April 2009 (7)
  • March 2009 (5)
  • February 2009 (10)
  • January 2009 (7)
  • December 2008 (13)
  • November 2008 (9)
  • October 2008 (15)
  • September 2008 (2)
  • August 2008 (1)
  • July 2008 (2)
  • June 2008 (1)
  • February 2008 (2)
  • January 2008 (1)
  • August 2007 (1)
  • May 2007 (2)
  • March 2007 (1)
  • February 2007 (2)
  • December 2006 (1)
  • September 2006 (1)
  • February 2003 (1)
  • May 2002 (3)
  • March 2002 (1)
  • January 2002 (1)
  • December 2001 (3)
About
StangNet.com, a division of the Drive9 Media network, is a premier Ford Mustang enthusiast community seeking to bring the Mustang legend, present, and future to Mustang fans worldwide. Since its launch in 1998, StangNet has served millions of readers, thousands of customers, and hundreds of contributing sponsors with focused drive, attention, and care. Additionally, StangNet has been directly reputed as one of the top Ford Mustang communities by Ford Motor Company.
twitter_icon
Twitter Updates
  • 2011 Ford Shelby GT500 gets new SVT toys http://stangnet.com/2011-GT500-SVT-package #mustang
  • RT @FordMustang:Join us for a live reveal of the 2011 Shelby GT500 & SVT plans. 12:30pm EST today http://cot.ag/dcznG3 http://bit.ly/b5Wv2n
  • 2011 Shelby GT500 teaser video http://stangnet.com/2011-Shelby-GT500-teaser-video #mustang
  • S197 Ford Mustang extended ball joints http://stangnet.com/S197-Mustang-extended-ball-joints #mustang
Follow us on Twitter!
Contact Us
Tips: tips@stangnet.com
Support: help@stangnet.com
Advertising: advertise@drive9.com
Copyright 1998-2009 StangNet - Drive9 Media
