Subscribe to our Updates
  • Home
  • GT500 Project
  • Exhaust
  • Blog
  • Mustang Videos
  • Mustang Classifieds
  • 2010 Ford Mustang
  • Mustang Apparel
Filed Under: Mustang Tech
S197 Ford Mustang Lowering Spring Install22 Dec
S197 Ford Mustang Lowering Spring InstallIf you have been thinking about lowering and sporting-up your late-model Ford Mustang, we here at StangNet.com are proud to present this illustrated technical article demonstrating the installation of some lowering springs from Vogtland. This write-up gives a real-world overview and interpretation on how to install the springs on a 2005 Ford Mustang GT. StangNet Staff member bigcat takes us on this journey to a lower ride with a crisper suspension response. Enjoy!
Vogtland S197 Lowering Spring Install tools needed: jack, jack stands, sockets, ratchets, torque wrench, strut spring compressor.
Step 1. Raise the vehicle to a comfortable working height so the suspension hangs freely. Properly support the vehicle so you can safely work under it.
Step 2. Remove wheels. The stock lug nuts are a 13/16” standard nut. If equipped, use the locking lug key to remove the wheel lock. After the wheel is removed, check to see if the rotor retaining clips are still present. If so, this is a good opportunity to remove them.
Simply pry or cut them off and discard. They are installed to hold the rotor on the car during assembly. If you use aftermarket wheels, they can cause vibrations and other annoying steering problems. The stock wheels have a recess machined into them to accommodate these clips, while most aftermarket wheels do not. This makes the aftermarket wheel not sit flush to the rotor.
Step 3. I chose to start with the rear, as no special tools or steps are required. Remove the brake line bolt found in front of the axle, attached to the inner wheelhouse using a 10 mm socket. See the picture below for exact location.
Step 4. Remove the lower shock bolt and flag nut, as shown in the next picture, using an 18mm socket.
Step 5. If replacing the rear panhard bar, remove the panhard bar plastic cover along with the bolts and flag nuts for each side. On the passenger side, you may need to loosen the bolt for the upper panhard support brace to allow the panhard bar to be removed. This allows the bracket to slightly spread apart, loosening the tension on the bushings. The panhard bar bolts are also 18mm.
Step 6. Although I did not perform this step, it may be easier if you disconnect the rear sway bar to allow the axle to move more freely.
Step 7. Pull down on the axle housing while pushing up on the spring. It may be easier if you use your body weight to pull on the axle, while pushing the spring up and out. You need to lift the spring, so it will clear the lower spring perch. Pull the spring out. Below are two different angles of the spring perch.
Step 8. Make sure the rubber coil spring isolator is still on the axle spring perch. Using the same method as removal, install the new springs into the perch. It is easier to put the top of the spring in first, and then try the bottom. Make sure you clear the upper spring perch, as shown in the pictures below.
Step 9. Repeat Steps 3-8 for the opposite side. Here is a picture of the passenger side panhard bar mount. The lower bolt is for the panhard bar, and the upper is for the support brace.
Step 10. If replacing the panhard bar with an adjustable bar, set the length of the new bar to stock length. Hand tighten the jamb nuts. Reinstall the panhard bar.
Step 11. Reinstall the shock and brake line bolts. Torque them to the factory specs. Step 12. Moving to the front, remove the brake line bolt located at the lower inboard of the strut, using a 10mm socket. Remove the nut for the swap bar stabilizer link, using a 18mm socket. This is located just below the spring. Also, unclip the wiring from the lower rear of the strut. It is just a Christmas tree style clip and pulls straight out.
Step 13. If using a strut tower brace (STB), you will need to remove it. Reinstall the nuts to hold the strut assembly in place temporarily. The upper strut nuts are 13mm.
Step 14. Remove the 2 lower 18mm strut bolts. Be sure to have a support ready for the rotor/hub assembly. Once you remove the strut bolts, there is nothing to hold the knuckle up. You do not want to let it hang freely on the lower ball joint. This could cause damage to your suspension parts. I used a jack stand and put it under a lug stud, as seen in the pictures.
Step 15. While holding the strut assembly, remove the upper strut nuts, and remove strut assembly from the strut tower. On top of the strut, there is an arrow and a notch. Note how it pointed when removed, and make sure you reinstall in the same position.
Step 16. Install the spring compressors on the coils of the spring as close to the top and bottom as you can. This allows the spring top compress enough to remove the spring. If you put the compressor in the middle of the springs, you wont be able to compress the spring enough to relieve the tension. They should be installed on opposite sides of the spring, to evenly compress the spring. Failure to do this can cause the spring to come out of the tool, causing injury or damage.
Step 17. With the spring compressed, remove the upper nut, the upper mounting flange, and the dust cover. Then pull out the compressed spring and relieve the tension evenly. Compare the new springs to the old and determine the correct orientation. Remove the lower rubber protector from the old spring, clean them off and transfer them to the new spring.
Step 18. Compress the new spring, making sure you have enough room to remove the tool after you install it on the strut. If you are too wide, you wont be able to remove the tool from the strut assembly. Once the spring is compressed, install it on the strut, along with the dust shield and upper mounting flange. Tighten the upper nut. You will most likely need to use a wrench on the nut, and also hold the stud to keep it from spinning while you tighten the nut. Make sure you installed the upper mounting flange the same way it came out. Check the arrow and the notch.
Step 19. Install the strut assembly into strut tower and install the upper nuts inside the engine compartment to hold it in place while you work below.
Step 20. If you were prepared, then you already purchased new camber adjusting bolts. I used new 14mm bolts from Ingalls, part number 35420, available from Summit Racing. Other alternatives are available. Follow the instructions from the manufacturer. My bolts are designed to go into the upper bolt location, if using one bolt. This allows +/- 2 degrees of adjustment. If more adjustment is needed, you can install another set of camber bolts in the lower bolt location as well, for a total of +/- 4 degrees of camber adjustment. The torque values may differ from factory bolts, so be sure to follow the instructions included with your bolts.
Step 21. Reinstall the stabilizer link and nut, the brake line bolt, and clip the wiring into place. Torque the fasteners to the factory specs. Don’t forget to torque the upper strut mounting nuts in the engine compartment as well. Remember, torque values should be read at ride height, with a loaded suspension.
Repeat steps 12-21 for the remaining side. Reinstall the wheels and check over your work. Measure the rear end to be sure it is centered. Measuring from the edge of the wheel lip to the edge of the rim works well. Adjust the panhard bar as necessary, and fully tighten the jam nuts. Believe it or not, you can adjust the panhard bar with the tires on the ground. Test drive and listen for abnormal sounds. Clunks are usually loose bolts, and pops are usually spring related issues. Perform an alignment before putting many miles on your car after it is lowered. Otherwise, you can prematurely wear out the tires and cause drivability issues.
NOTE: All suspension components should be loaded, and at ride height during the torque procedure. Factory torque specs (lb-ft, unless otherwise noted):
FRONT:
Brake caliper bracket bolts 98
Dust shield bolts 15
Wheel spindle pinch nut 76
Lower control arm forward bolt 129
Lower control arm rearward nuts 129
Heat shield bolts 89 lb-in
Brake line bracket bolt 15
Strut upper nut 46
Strut-to-spindle bolts 148
Strut-to-body nuts 26
Wheel hub retainer nut 221
Stabilizer bar bracket nuts 52
Stabilizer bar link nuts 85
Anti-lock brake sensor bolt 53 lb-in
Outer tie-rod end nuts 59
Steering gear mounting bolts 85
REAR:
Rear shock absorber upper nut 30
Rear shock absorber lower bolt 85
Lower arm-to-body bolt 129
Brake caliper anchor plate bolts 76
Lower arm-to-axle bolt 129
Panhard rod-to-body mount bolt 129
Panhard rod-to-axle bolt 129
Lateral stiffener bar-to-body mount nut 85
Lateral stiffener bar-to-body bolts 46
Stabilizer bar link bolts 85
Parking brake cable bracket-to-lower arm 20
Upper control arm front bolt 129
Upper control arm rear bolts 85
Upper control arm bushing nut 129
Fuel tank strap bolt 38
Brake hose bracket bolt 15
Bookmark and Share
Tags: install, s197, springs, vogtland
Leave a Reply
Click here to cancel reply.
Sponsors
[Advertise Here]
Categories
  • 2010 Mustang
  • Aftermarket
  • Events
  • Featured
  • Ford
  • General
  • Mustang Tech
  • Uncategorized
  • Videos
Archive
  • November 2009 (9)
  • October 2009 (9)
  • September 2009 (12)
  • August 2009 (10)
  • July 2009 (16)
  • June 2009 (16)
  • May 2009 (14)
  • April 2009 (7)
  • March 2009 (5)
  • February 2009 (10)
  • January 2009 (7)
  • December 2008 (13)
  • November 2008 (9)
  • October 2008 (15)
  • September 2008 (2)
  • August 2008 (1)
  • July 2008 (2)
  • June 2008 (1)
  • February 2008 (2)
  • January 2008 (1)
  • August 2007 (1)
  • May 2007 (2)
  • March 2007 (1)
  • February 2007 (2)
  • December 2006 (1)
  • September 2006 (1)
  • February 2003 (1)
  • May 2002 (3)
  • March 2002 (1)
  • January 2002 (1)
  • December 2001 (3)
About
StangNet.com, a division of the Drive9 Media network, is a premier Ford Mustang enthusiast community seeking to bring the Mustang legend, present, and future to Mustang fans worldwide. Since its launch in 1998, StangNet has served millions of readers, thousands of customers, and hundreds of contributing sponsors with focused drive, attention, and care. Additionally, StangNet has been directly reputed as one of the top Ford Mustang communities by Ford Motor Company.
twitter_icon
Twitter Updates
  • SEMA fallout - the 2010 Steeda Q350 Ford Mustang http://stangnet.com/SteedaQ350 #mustang
  • Steve Saleen's newest installation: SMS Superparts http://stangnet.com/SMSsuperparts #mustang
  • Grab 'n Go! Ninosport Shift Knob with LeMans Stripes for the Ford Mustang http://stangnet.com/LeMansShiftBall #mustang
  • ROUSH scopes Propane Ford Mustang drag cars http://stangnet.com/PropaneStang #mustang
Follow us on Twitter!
Contact Us
Tips: tips@stangnet.com
Support: help@stangnet.com
Advertising: advertise@drive9.com
Copyright 1998-2009 StangNet - Drive9 Media
