Subscribe to our Updates
  • Home
  • GT500 Project
  • Magnaflow
  • Blog
  • Mustang Videos
  • Mustang Classifieds
  • 2013 Ford Mustang
  • Mustang Apparel
   Top > Mustang Tech > S197 Ford Mustang Panhard Bar Install
Filed Under: Mustang Tech
 Feb 10th 2007
S197 Panhard Install - Ford MustangIf you have been thinking about sporting the suspension up beneath your late-model Ford Mustang. StangNet.com is proud to present this illustrated technical article demonstrating the installation of a panhard bar. This write-up gives a real-world overview and interpretation on how to install the J&M panhard bar on a 2005 Ford Mustang GT. StangNet Staff member bigcat takes us on a journey to achieving a crispier suspension. Enjoy!
Raise the vehicle to a comfortable working height so the suspension hangs freely. Properly support the vehicle so you can safely work under it.
If replacing the rear panhard bar, remove the panhard bar plastic cover along with the bolts and flag nuts for each side. On the passenger side, you may need to loosen the bolt for the upper panhard support brace to allow the panhard bar to be removed. This allows the bracket to slightly spread apart, loosening the tension on the bushings. The panhard bar bolts are also 18mm.
Here is a picture of the passenger side panhard bar mount. The lower bolt is for the panhard bar, and the upper is for the support brace.
If replacing the panhard bar with an adjustable bar, set the length of the new bar to stock length. Hand tighten the jamb nuts. Reinstall the panhard bar.
Once the panhard is installed, snug up the bolts, then lower the vehicle. Once the car is sitting on the ground, Torque the bolts to 129 lb-ft. Now, measure the distance from each wheel to the outer edge of the body. Use a plumb bob taped to the top center of the wheel opening. If you don’t have a plumb bob, it is very easy to make one.
All you need is a string and a weight. Tie the weight to one end of the string. Hang the other end on the wheel well with tape. Make sure the weight is off of the ground, and not touching anything.
Ford Mustang panhard bar install
Measure from the edge of the rim to the plumb bob string. Compare the measurements for each side.
If the rear end needs adjustment, loosen the jamb nuts on the panhard bar. Rotate the adjuster in the appropriate direction until the rear axle is centered. The car should be on the ground during measurement and adjustment. It seems as if it would be difficult to adjust while on the ground, but there is very little effort required, as the body moves over the rear end. Many people think that the rear end would have to drag across the ground to adjust, but as you will see, this is not the case. After the proper adjustments are made, tighten the jamb nuts on the panhard bar using the proper wrenches, hand tight is not enough to prevent loosening. Don’t forget to reinstall the plastic cover for the panhard bar.
Bookmark and Share
Tags: install, j&m, panhard
2 Responses to “S197 Ford Mustang Panhard Bar Install”
  1. 2011 mustang rear wheel alignment - Ford Mustang Canada Forums & Classifieds (June 20th, 2011 at 10:07 am) Reply
  2. mike (July 8th, 2011 at 9:13 am) Reply
    pass side lock nut cannot be tightend when pan bar is installed. driver side is easy. pass side is surrounded by bracket. cannot get a wrench to it. Mike
Leave a Reply
Click here to cancel reply.
Sponsors
[Advertise Here]
Ads
StangWear
Mustang T Shirts
Mustang Hats
Mustang Jackets
Mustang Apparel
Categories
  • 2010 Mustang
  • 2011 Mustang
  • 2012 Mustang
  • 2013 Mustang
  • 2014 Mustang
  • 2015 Mustang
  • Aftermarket
  • Built to Cruise
  • Events
  • Featured
  • Ford
  • General
  • Mustang Tech
  • Videos
About
StangNet.com, a division of the Drive9 Media network, is a premier Ford Mustang enthusiast community seeking to bring the Mustang legend, present, and future to Mustang fans worldwide. Since its launch in 1998, StangNet has served millions of readers, thousands of customers, and hundreds of contributing sponsors with focused drive, attention, and care. Additionally, StangNet has been directly reputed as one of the top Ford Mustang communities by Ford Motor Company.
twitter_icon
Twitter Updates
  • Video: Jay Lenos Book Club - Farr's Mustang Boss 302 http://t.co/DMsvjXy0 #mustang @fordmustang
  • Ford Racing Electronic Pedal Bracket Adaptor http://t.co/S0KpyXXs
  • BTC Water Overflow Setup http://t.co/dBRZ3omT
  • 2013 Ford Mustang pony projector light http://t.co/mwU50Wg2 #mustang @fordmustang
Follow us on Twitter!
Contact Us
Tips: tips@stangnet.com
Support: help@stangnet.com
Advertising: advertise@drive9.com
Copyright 1998-2011 StangNet - Drive9 Media Privacy Policy
