Subscribe to our Updates
  • Home
  • Magnaflow
  • Converters
  • Blog
  • Mustang Videos
  • Mustang Classifieds
  • 2015 Mustang
  • Mustang Apparel
   Top > Mustang Tech > S197 Ford Mustang LCA Relocation Bracket Installation
Filed Under: Mustang Tech
 Aug 14th 2007
S197 LCA Relocation Bracket InstallationContinuing on with suspension upgrade installations for the S197 Ford Mustang, we are back to show yet another how-to regarding the installation of a set of lower control arm relocation brackets. These J&M LCA relocation brackets allow for a dramatic change in the instant center of the car, resulting in a better weight transfer to provide a better launch off the line. This original StangNet.com write-up gives a real world overview and interpretation on how to perform the bracket installation on a 2005 Ford Mustang GT. StangNet Staff member bigcat shows us just how it’s done.
Tools needed: 19mm socket and wrench, 18mm socket 22mm socket and wrench, ratchet, torque wrench, jack, jackstands
Raise the vehicle and properly support it so you can safely work underneath it.
Using the 18 mm socket and wrench, remove the counter balance weights from the rear axle, if equipped.
S197  Install
S197  Install
Remove the 18mm bolt and flag nut from the lower control arm where it attaches to the axle, and swing the LCA out of the way. The fasteners will not be reused for the new brackets.
S197  Install
Install the J&M relocation bracket onto the axle, over the original control arm mounting bracket. The bracket with the offset and washer is the driver’s side bracket. Insert the small nut and bolt with washers on each side into the upper mounting hole, where the weight was originally mounted.
S197  Install
Use the metal sleeve included, and insert it between the original bracket mounting holes. Install a washer on the long bolt, and insert it through the sleeve. Install the other washer and nut. If the nut is towards the center of the car, there is more room for your power tools. Suspension components will be in the way on the other side.
S197  Install
Reattach the lower control arm using the new 14mm bolts, nuts, and washers supplied. Do not torque any fasteners yet. All fasteners must be torqued with the vehicle at ride height and with a loaded suspension. J&M recommends installing the LCA in the upper mounting hole. If more traction is needed, move the LCA to the lower mounting hole, as shown in the pictures here.
S197  Install
S197  Install
Repeat procedure for the other side.
S197  Install
Once the vehicle is on the ground and suspension is loaded, you can torque the fasteners.
TORQUE SPECIFICATIONS
129 Lb-Ft. for the 14mm (larger) bolts
82 Lb-Ft. for the 12mm (smaller) bolts
Bookmark and Share
Tags: install, j&m, lca, relocation bracket
Leave a Reply
Click here to cancel reply.
Sponsors
[Advertise Here]
Ads
StangWear
Mustang T Shirts
Mustang Hats
Mustang Jackets
Mustang Apparel
Categories
  • 2010 Mustang
  • 2011 Mustang
  • 2012 Mustang
  • 2013 Mustang
  • 2014 Mustang
  • 2015 Mustang
  • Aftermarket
  • Built to Cruise
  • Events
  • Featured
  • Ford
  • General
  • Mustang Tech
  • Videos
About
StangNet.com, a division of the Drive9 Media network, is a premier Ford Mustang enthusiast community seeking to bring the Mustang legend, present, and future to Mustang fans worldwide. Since its launch in 1998, StangNet has served millions of readers, thousands of customers, and hundreds of contributing sponsors with focused drive, attention, and care. Additionally, StangNet has been directly reputed as one of the top Ford Mustang communities by Ford Motor Company.
twitter_icon
Twitter Updates
  • http://t.co/szhnFiOV
  • Mustang Pedal Bracket Updates - http://t.co/5IngyN0p
  • BTC Blog Moved to Auburn Customs http://t.co/i0DSV7ke
  • 68 shelby conv replica | Mustang Forums at StangNet http://t.co/w9ea5mCF via @stangnet
Follow us on Twitter!
Contact Us
Tips: tips@stangnet.com
Support: help@stangnet.com
Advertising: advertise@drive9.com
Copyright 1998-2011 StangNet - Drive9 Media Privacy Policy
