Subscribe to our Updates
  • Home
  • GT500 Project
  • Exhaust
  • Blog
  • Mustang Videos
  • Mustang Classifieds
  • 2010 Ford Mustang
  • Mustang Apparel
Filed Under: Mustang Tech
S197 BMR Lightweight Radiator Support Install30 Jan
BMR Radiator Support installBack for another S197 Ford Mustang technical write-up, the StangNet crew hopes that every late model Ford Mustang drag fan can enjoy these awesome tech and instructions on how to make it happen. StangNet Staff member DarkFireGT paves the way for some great weight reduction at the track with the Lightweight Radiator Support / sway bar delete tehcnical illustration. Take a closer look inside, with the hi res images available in full detail.
The Install
Road racers need not apply, this is a job for a drag junkie. BMR Fabrication can help you take 26.5lbs off the front end not only lightening your car, but helping with weight transfer during launch. Everyone I talked to said they didn’t notice a difference with driving on the road, but you’d definitely notice a difference if you were in the twisties. BMR’s directions are pretty simple and straight forward, but a few could use pictures. I don’t have a lift, so they’re pretty close-up. Installation should take 1-1/2 hours on jack stands, or less on a lift.
Tools and Supplies Needed:
  • 18MM deep well socket
  • 15MM deep well socket
  • 6″ or 12″ extension
  • 10MM socket
  • 11MM socket
  • Floor jack and small piece of scrap wood
  • Wire cutters or sharp scissors
  • 3 zip ties
1. Lift vehicle and support safely with stands under the frame rails (I don’t think you need pictures of this)
2. Using the 18MM deep well socket, remove the sway bar end links from the strut on each side. I used my impact wrench. You may need to take the nut off at an angle, as the stud spun with the nut if I tried to remove it head on. An easier way would be to use a ratcheting wrench on the 18MM nut and hold the bolt with a crescent wrench or something similar.
3. Using the 15MM deep well socket, remove the sway bar cross member mounts and lower the sway bar/endlink assembly by pulling straight out on the sway bar until it clears the bolts, then pull down and out.
4. Locate the plastic bumper cover support and remove the 7 screws using the 7/32″ socket.
4-1. Use a flathead screwdriver or similar object to break the tabs in the 2 square holes that clip into the radiator support, then remove the cover.
4-2. Cover removed:
5. BMR says to use a 10MM socket, but my car had an 11MM socket, so Ford may have changed this. Use whichever fits (obviously). Loosen the nut on top of the radiator support that holds the clip for the AC line. The nut is on the left side, next to the brake line clip.
6. Pop the brake lines out of the two clips attached to the OEM radiator support. One is on the drivers’ side of the horizontal section. The other is on the passengers’ side, attached to the vertical section.
7. Place a jack under the radiator to prevent it from moving when the cross member is removed. I put a piece of wood on top of the jack to keep from damaging the radiator.
8. Remove the 4 bolts holding the OEM radiator support on using the 18MM deep socket with an extension. There are two on each side. Lower the cross member. There may be a line zip tied to the cross member, so have your cutters ready to cut the zip tie.
8-1. OEM front sway bar and radiator support removed:
8-2. OEM vs BMR:
9. Remove the two rubber isolators from the OEM radiator support and transfer them to the BMR cross member.
10. Install the BMR cross member using the 18MM deep well socket and extension, and torque to 110 ft/lbs.
11. Remove jack stand from under radiator.
12. Reinstall factory bumper cover using the 4 7/32″ screws you removed earlier along with 3 zip ties (1 through the center hole where the screw was, and two through the square holes where the clips were).
13. Lower vehicle and clean up.
Bookmark and Share
Tags: bmr, install, radiator support
Leave a Reply
Click here to cancel reply.
Sponsors
[Advertise Here]
Categories
  • 2010 Mustang
  • Aftermarket
  • Events
  • Featured
  • Ford
  • General
  • Mustang Tech
  • Uncategorized
  • Videos
Archive
  • November 2009 (9)
  • October 2009 (9)
  • September 2009 (12)
  • August 2009 (10)
  • July 2009 (16)
  • June 2009 (16)
  • May 2009 (14)
  • April 2009 (7)
  • March 2009 (5)
  • February 2009 (10)
  • January 2009 (7)
  • December 2008 (13)
  • November 2008 (9)
  • October 2008 (15)
  • September 2008 (2)
  • August 2008 (1)
  • July 2008 (2)
  • June 2008 (1)
  • February 2008 (2)
  • January 2008 (1)
  • August 2007 (1)
  • May 2007 (2)
  • March 2007 (1)
  • February 2007 (2)
  • December 2006 (1)
  • September 2006 (1)
  • February 2003 (1)
  • May 2002 (3)
  • March 2002 (1)
  • January 2002 (1)
  • December 2001 (3)
About
StangNet.com, a division of the Drive9 Media network, is a premier Ford Mustang enthusiast community seeking to bring the Mustang legend, present, and future to Mustang fans worldwide. Since its launch in 1998, StangNet has served millions of readers, thousands of customers, and hundreds of contributing sponsors with focused drive, attention, and care. Additionally, StangNet has been directly reputed as one of the top Ford Mustang communities by Ford Motor Company.
twitter_icon
Twitter Updates
  • SEMA fallout - the 2010 Steeda Q350 Ford Mustang http://stangnet.com/SteedaQ350 #mustang
  • Steve Saleen's newest installation: SMS Superparts http://stangnet.com/SMSsuperparts #mustang
  • Grab 'n Go! Ninosport Shift Knob with LeMans Stripes for the Ford Mustang http://stangnet.com/LeMansShiftBall #mustang
  • ROUSH scopes Propane Ford Mustang drag cars http://stangnet.com/PropaneStang #mustang
Follow us on Twitter!
Contact Us
Tips: tips@stangnet.com
Support: help@stangnet.com
Advertising: advertise@drive9.com
Copyright 1998-2009 StangNet - Drive9 Media
