Check the 2012 Boss 302 ‘S’ Race-Ready Mustang from Ford Racing
Share this Post:
We are sure to see an official announcement sooner or later, but for now, we know that Ford Racing plans to unleash a new race-ready 2012 Mustang Boss 302 S track car.  There’s not a ton to go on right now, but FordRacingParts.com has the specifics on what will be rolled into the 2012 Boss 302S.  The leaked photo we have here is sure to be expounded upon as we make it closer to an official Press Release.
The 2012 Mustang Boss 302S, in a nutshell, is a factory-built turnkey race car.  Prepped on the line for SCCA and NASA class racing, loaded with Ford Racing Performance Parts, and carrying a price tag of $79,000, you’d better be serious about speed to keep up.  What’s more, the production stream will be limited to just 50 units, whereas the Boss 302R is currently without limitation.
Be sure to keep your eyes peeled for this track terror.  More details and specs continue, below.
2012 Mustang Boss 302 “S” details
Engine
* 5.0L BossR engine
* Engine oil cooler
* FR serialized intake badge
* Boss 302 fuel system
* Upgraded cooling system
Driveline
* 5L Boss 6 speed transmission with stock Boss 302 clutch/flywheel
* Torsen Diff
* 3.73 gears
* FR1 Muffler
Chassis
* Front: coil over struts
* Front lower control arms with extended ball joint and delrin bushing kit
* FR adjustable front swaybar
* Caster/Camber plates
* Rear: coil over shocksTubular lower control arms with spherical bearings
* FR Swaybar
* EPAS with unique Ford Racing calibration
* FIA Spec 6 point roll cage
Electrical
* Lightened FR wiring harness
* AMB Transponder
* Switch plate – Start/ignition, aux switches
Interior
* AIM data aquisition system with GPS
* Recaro HANS Pro Racer seat
* Fire system with 2 nozzles
* Quick release racing steering wheel
* Window net
* Safety system triangle nets
* 6 point racing harness
* Master cut off switch
Exterior
* FR front splitter
* Rear adjustable CF wing
* Unique fiberglass hood with air extractors
* Hood pins
* 18X9.5″ wheels
* Boss 302S graphics package
* F/R tow hooks
Brakes
* Brembo race 4 piston front brake system
* 2 piece 14″ front rotors
* 2 piece 12″ rear rotors
* PFC racing pads
* Brake duct kit
* Stainless steel brake lines
* FR brake booster assembly
* Unique FR ABS calibration
Source: MustangHeaven
Categories: Ford, 2012 Mustang
