ProCharger winds up their 2011 5.0 Mustang Cog Supercharger kit
Share this Post:
After the recent announcement of their 2011 Mustang GT 5.0-liter ProCharger kit, the team is set to now debut their 2011 5.0 Mustang Cog Race Kit at the  2010 Performance Racing Industry (PRI) Show.  This new Mustang GT supercharger is going to be on display in Orlando this weekend (starting 12/9/10) and will be accompanied in the booth by the Stage II Supercharger System & Tuner Kit as well as the High Output System & Tuner Kit that were debuted at SEMA and in back in the summer.
This all-new Cog Race Kit is made from billet aluminum and is designed to handle most any ProCharger blower setups, including: the F-1D, F-1, F-1A, F-1C and F-1R.  What’s more, the new Cog Race Kit also features an air2air intercooler and a ProCharger racing bypass valve.
Ready to see what these kits can produce on the new Mustang GT rockin’ the 5.0?  Keep reading; we’ve got a nice clip inside!
Press Release
ProCharger to Debut New Cog Race Supercharger Kit For 2011 5.0 Mustangs at 2010 Performance Racing Industry TradeshowPRI booth #3506
ProCharger, the undisputed leader when it comes to supercharger solutions for the hot new 2011 5.0 Mustang, is introducing the industry’s first Cog Race Supercharger Kit at the 2010 Performance Racing Industry (PRI) Show, December 9-11, 2010 in Orlando, FL. The new Cog Race Kit rollout follows on the heels of the Stage II Supercharger System and Tuner Kit and High Output System and Tuner Kit that were introduced at SEMA and in late July respectively.
The new Cog Race Kit features a rugged billet aluminum bracket and tensioner pulley, cog crank pulley and is designed around a proven, 50 mm dedicated cog drive belt. The bracket can mount a wide range of ProCharger supercharger models, including the F-1D, F-1, F-1A, F-1C and F-1R, which carry HP ratings of 1,000 to 1,300 HP. The Cog Race Kit also features a large, front-mounted air-to-air intercooler and a legendary ProCharger race bypass valve.
“We’re already seeing customers and dealers building these new 5.0 engines specifically for forced induction,” says Dave Werremeyer, Motorsports Operations Coordinator for ProCharger. “This new Cog Race Kit gives racers another ProCharger solution when it comes to building safe, reliable and championship winning Ford power. It’s just a matter of time until we see these new 5.0-based engines producing 1,200 plus horsepower and you can bet ProCharger will be right there.”
The new 2011 5.0 Mustang Cog Race Supercharger Kits are available now through ProCharger dealers and have a Manufacturers Suggested Retail Price starting at $7,196.
A Cog Race Kit and ProCharger F-Series Supercharger will be shown in ProCharger’s display at the PRI Show, booth #3506.
ProCharger: Leading the Way with Supercharger Systems and Tuner Kits for the 2011 5.0 Mustang
Realizing the performance potential of the 2011 Mustang’s new 5.0 engine, ProCharger is the first supercharger manufacturer to develop a clear forced- induction upgrade path for owners looking to take their new Mustangs to even higher power levels.
ProCharger High Output (HO) System and Tuner Kit: The 600+ HP Bolt On
• Dedicated 8-rib supercharger drive system
• P-1SC-1 Supercharger standard, D-1SC available
• No Cut – No Trim installation
• Air-to-Air intercooler
• Handheld Tuner (System only)
• Retains stock engine cover with NO trimming
• Fits under available strut tower brace
ProCharger Stage II System and Tuner Kit
• Dedicated, 8-Rib supercharger drive system (12-Rib Drive available)
• Larger front-mounted air-to-air intercooler (minor trimming to inside of front bumper cover required)
• Fabricated coolant tank and radiator fan shroud assembly
• Larger air filter
ProCharger Intercooled Cog Race Kit: The Hardcore 5.0 Race Supercharger Solution
• Available with F-1D, F-1 and F-1A superchargers (1,000 to 1,100 HP)
• Available with F-1C and F-1R superchargers (1,225 to 1,300+ HP)
• Large front-mounted air-to-air intercooler
• Dedicated, 50 mm cog drive belt
• Legendary ProCharger race bypass valve
• Regains stock engine cover with NO trimming
Thanks to the dedicated supercharger drive system, highly efficient supercharger compressor design and effective, air-to-air intercoolers, ProCharger supercharger systems for the 2011 5.0 Mustangs produce the largest, most reliable and safest power gains in the industry.
ProCharger: First 2011 5.0 Mustang into the 9’s and 8’s
Equipped with a ProCharger F-1C supercharger and air-to-air intercooler, a mildly built 5.0 Mustang from Evolution Performance in Aston, PA became the first forced-induction 2011 Mustang into the 9’s with an eye-opening 9.11 second ¼ pass in September. The Evolution crew then set the bar even higher with an amazing 8.89 @ 148 mph pass in early October.
Categories: 2011 Mustang, Aftermarket, Mustang Tech, Videos
Comments are closed.
