New UPR Ford Mustang products
Share this Post:
If you haven’t been keeping up with the Fox body Ford Mustang aftermarket scene, then you’d better take a good look at the latest offerings from UPR Products.  The UPR coil over kit spanner wrench and the factory air dam replacement kit are two slick new products to revamp the resto mod project sitting in the garage this Spring.
Both of these products are designed, crafted, and shipped straight from the good ole US of A, so be sure to take a good look at them when you are looking to improve upon, replace worn, or replace missing OEM (or other rubbish) equipment.
Keep reading to get the exact product descriptions, straight from UPR.
Press Releases – UPR Products
UPR Billet Coil Over Kit Spanner Wrench
Part Number: 2006-12
MSRP: $12.99
CNC Machined Billet Aluminum
* Works on UPR Coil Over Kits
* Makes ride height adjustments a snap
* Available in Satin, Blue or Black Finish
Make adjustments to your UPR Coil Over Kit even easier with UPR’s Billet Coil Over Kit Spanner Wrench. This wrench works on all UPR Coil Over Kits and locks into place using the holes machined in the adjuster ring. Machined hand grip so you get a comfortable but firm grip while making adjustments.
CNC Machined from 6061 Billet Aluminum for a perfect fit including the Diamond cutter final pass giving it the best finish possible. Made in the USA!
UPR 1979-93 Mustang Radiator Air Deflector
Part Number: 4500-01
MSRP: $39.99
* Easy 15 Minute Install
* Made from Aluminum
* No Drilling Required
* 1″ Longer Lip than Factory
* Brushed Satin Finish
Don’t overlook a key part of your 1979-93 Mustang’s Cooling System! The factory air dam/air deflector directs air to your radiator and without it your car loses some of its effectiveness. UPR now offers an Aluminum replacement Radiator Air Deflector that will hold up at speed better than the stock plastic piece which can flex. Attaches to the factory radiator support, no drilling required.
Precision cut for a perfect fit and designed for a bolt in installation. Installs in 15 minutes or less – No drilling required, and uses factory hardware. Made in the USA!
UPR Products
Categories: Aftermarket, Mustang Tech
Comments are closed.
