Auburn Customs Fox Ford Mustang Coyote Pedal Bracket
Share this Post:
All throughout the build-up of our latest Ford Mustang project car, Built to Cruise, we hit certain challenges and bumps in the road that required a healthy portion of blood, sweat, and tears…and ultimately, ground-breaking ingenuity.  One of the key highlights people really liked and latched during the build-up, was the StangNet-designed pedal relocation bracket for the 2011 Coyote 5.0-liter V8 swap into any late-model Fox platform Mustang.  This Coyote 5.0-liter pedal relocation bracket was spec’d out via our own CAD schemes, passed along to prototype stage, and is now being produced by one of our long-term suspension suppliers, J&M Products.  This pedal bracket can be used in any Ford Mustang from 1979 up through 2004, in addition to any other application with a vertical firewall.
For more details, specs, and pricing, be sure to keep reading to get the full description and link to the Auburn Customs store where you can pick one of these up for any of your projects you have coming up!
Product Description
The electronic pedal that comes with the Ford Racing Control Pak that is required for operation of the Modular crate motors does not easily bolt in to most applications. Auburn Customs has developed an easy pedal adaptor bracket that will easily bolt in to place.
This bracket directly fits any Mustang from 1979 to 2004 and also will work great on any project that has a vertical firewall. The Ford Racing pedal is an S197 Mustang pedal and is designed to be mounted at an angle. With this adaptor we compensate for the angle when being mounted on a vertical firewall and this gives you the correct angle for proper operation.
For FOX Mustangs (79-04) this bracket locates the pedal in the perfect spot next to the tranmission tunnel and also allows it to be directly mounted to the factory studs of the original pedal. We have compensated for the various switches and brackets under the dash to allow proper fitment.
  • Easy Installation
  • Stainless Steel Hardware Included
  • Mounts direct to FOX Mustang original pedal studs (reuse stock nuts)
  • Will work with any Control Pak pedal that is of THIS design
  • Solid one piece CNC construction
  • Positions the pedal at the proper location and angle
  • Will work on any vertical firewall for restomods or kitcars
  • Trimming of the Ford Racing pedal required
Source: Auburn Customs
Categories: Aftermarket, Mustang Tech, Built to Cruise
Comments are closed.
