Brothers Performance 1998 – 2004 Ford Mustang fuel pump
Share this Post:
In the midst of fuel system upgrades or replacements on the Ford Mustang, every modification fanatic has had to figure out the best way to keep the thoroughbred fed…and well.  Many aftermarket options have existed in the past, but few were a direct-fit or close to an OEM replacement…until now.
Brothers Performance has recently arranged to have such a direct-fit fuel pump for the 1998 through 2004 Ford Mustang.  This variable flow kit can be utilized as a complete stock replacement OR as an upgrade for “thirstier” pony cars.  The pump itself is rated at 290 liters/hour, and is suited for stock applications or even modified Mustang track cars.
Keep reading to get more details on this setup, straight from Brothers Performance.
Press Release
New Product Release From Brothers Performance
1998 -2004 Ford Mustang 290 LPH Electric In Tank Direct Replacement Fuel Pump Kit
In stock Today at Brothers Performance
• Available to fit All 98-04 Mustang GT & Cobra
• Direct fit replacement In-Tank Fuel Pump
• Factory wiring connectors – no cutting or splicing required
• 13.5 Volts
• 290LPH At 43Psi
• Great for modified and supercharged applications
• Emissions Legal in some applications
Now you can finally have a direct replacement fuel pump – Replace or upgrade any factory in tank electric fuel pump in your 1998-04 Mustang with this direct fit, variable flow fuel pump kit. This Brothers Performance fuel pump can be used as a stock replacement or and upgrade when running a higher horsepower engine. The 290Lph fuel pump allows for great drive ability in stock or highly modified Mustangs. These fuel pumps are now available and in stock at
Only: $259.99 each
Categories: Aftermarket, Mustang Tech
Comments are closed.
