HomeMustang News Jon Kaase Unleashes the Boss Nine 589ci Ford Mustang
The Boss is truly one of the most famous Fords Mustangs of all time, and every Mustang
freak and his brother has sought to put one in the garage. This passion has held strong
from the Classic days up through present, with many one-offs posted by the aftermarket, but
none have been fully blessed by FoMoCo. The lingering lust for a high-powered pony car with
the Boss lettering has Mustang fans grabbing at any possible concept they can fathom in
order to reproduce the legacy of the Boss Mustang experience. Now, Jon Kaase and his crew have
taken their best shot at recreating a Boss monster--and yeah, they have a winner here,
folks. With an output of 800 ft-lbs of torque and over 900 horsepower, this S197 Mustang
means business...because it's truly the Boss. Take a good look at the Kaase Boss Nine
589ci 2008 GT Mustang and witness how it became a fire-breathing thoroughbred.
Press Release from Jon Kaase
Since I was in high school, (class of 1970), I have always wanted a Boss 429 Mustang. It was
Ford's masterpiece of engineering. Their Holy Grail. Their Hemi Cuda. The problem is, I was
as far away from being able to afford one in 1969 as I am today. (Considering their present
value) If I could buy an original, it would be far too valuable to drive or put many miles
on it.
With the release of our new Boss Hemi engine parts, the next logical step was to build our
own version of the Boss 429 Mustang. I rationalized that a complete running car would
showcase the new engine parts, and create a new market for our parts sales. Although this
may be partially true, let's be honest here. I wanted this car! I want to drive it home and
give my family and neighbors a ride. Most of my neighbors think I have a garage that does
quick oil changes. They have no idea. I have not driven anything with over 360 HP since
1974. This car with 800 ft/lbs of torque and 900 HP should be a real handful.
The late Buddy Morrison told me years ago, in his laid back Texas delivery, "ya know, in a
street car, the torque is what you feel." I absolutely believe this. I think anyone who
builds one of these Boss Hemi cars for the street will definitely "feel" it.
My first idea was to buy a used 2005 mustang and start work from there. After finding that
the pricing was $18,000-$19000 for a good used one, I started to investigate new cars. If
you can get dealer cost, the new one was only $4500 more than a used one. What made it even
better was the new one had almost no interest on the loan, and I financed the whole thing.
The payment is $460/ month. It's worth it because it's new, and it's pleasure to work on.
(No dirt, oil, or road gunk.)
Realistically, a 466" Boss Hemi would be about right for this car, but, as they say,
anything worth doing is worth doing in excess. We took an aluminum block and Bryant crank in
on trade last winter, and decided to use them on this project. The block is 4.627" and the
crank is 4.375". This works out to 589 cu. in. With street compression, (10.5 to 1) and a
273/280 roller cam, the engine made 973 HP and 800 FT/LBS right away. The cam was a little
too big for a street cruiser, so we installed a 251 degree street roller, .660" net lift.
The engine still made 800 FT/LBS, with 885 HP, only now it's smooth at an idle all the way
up to 7000 rpm.
We installed a Billet Specialties front drive for all the accessories. This includes a
billet front timing cover, water pump, power steering pump, alternator, air conditioning
compressor, and serpentine belt with pulleys. We bought 3" stainless exhaust from
Granatelli, which includes everything from the header collector back.
This car is a natural for the Boss Hemi swap. There is plenty of room between the shock
towers, enough room for headers, and enough room between the front drives and radiator. Now
that the engine is installed for good, we can see that the hood needs no modification for
the air filter. It's close but the right filter assembly will fit. A stock rear sump Moroso
pan fits over the steering and crossmember perfectly.
D&D Performance engineered the trans and related parts for us. They supplied a Quick Times
bellhousing, McCloud twin disc clutch, hydraulic release bearing, Viper spec T-56 six speed
transmission, custom shifter, and a one piece Dynatech aluminum driveshaft.
At this time, (10/27/08) we are headed to Chuck Lawrence's house for the final "finish
up". He has to hook up the power steering lines, A/C lines, coolant lines, and fuel system.
We still have to hook up the ignition box and coil, and figure a way to get switched power
to it. The worst part will be the fuel system, as the pump and lines will have to be
completely re-engineered for carburetor use.
The car is still a work in progress, and we will continue to update this site with any
progress. It has to be finished by Thanksgiving, as we still have to get some things done
and drive it a little before the PRI show. We will have the finished car on display at the
PRI show (provided I don't crash it first). Please make plans to visit us at the show in
Orlando, at booth #5336.
