Home arrow Aftermarket News arrow AEM Brute Force Intake for '07-'08 Ford Mustang
AEM Brute Force Intake for '07-'08 Ford Mustang PDF Print E-mail
AEM is elated to release a brand new intake system for the 2007-2008 Ford Mustang.  The AEM Brute Force intake system for the S197 Mustang, equipped with the 4.6L V8, is a complete setup to raise power output to 7hp and 7 lb-ft of torque at 4,500 rpm.  Complete details for this fantastic piece are below or you can also visit the AEM site, at www.aempower.com.
AEM Brute Force Intake for Ford Mustang GT
AEM Brute Force Intake for Ford Mustang GT AEM Brute Force Intake for Ford Mustang GT
Official Press Relase
AEM BRUTE FORCE Intake System for 2007-08 Ford Mustang GT 4.6L V8 Delivers Maximum Power, Torque, and Superior Filtration!
May 16, 2008, Hawthorne, CA—AEM is proud to introduce its BRUTE FORCE intake system for the 2007-08 Ford Mustang 4.6L V8 (part # 21-8113D). The new AEM BRUTE FORCE intake for the Mustang GT includes a power spacer to assist in power production. The largest power gains for the 21-8113D are 7 horsepower and 7 lbs/ft of torque at 4,500 RPM as measured on the company’s Mustang Dynamometer. Dyno results and a description of AEM’s dyno and temperature testing procedures, along with a list of applications, are available on the company’s website at www.aempower.com.
AEM BRUTE FORCE intakes are dyno-tested against the competition to deliver unsurpassed performance. Each system is tuned on the dyno to deliver maximum torque and horsepower, and monitor OBDII sensors, Mass Airflow sensor (MAF) signal voltage and fuel trims during this process to ensure that all readings are within OEM parameters, eliminating the chance of a throwing a check engine light.
All BRUTE FORCE intakes are constructed of CNC, mandrel-bent 6061 aluminum, and feature reinforced, TIG-welded brackets and fittings for maximum durability. AEM also includes a heavy-duty steel heat shield with a powdercoated black finish, a complete hardware kit and comprehensive installation instructions with every BRUTE FORCE intake system. BRUTE FORCE intakes are available with AEM’s new gunmetal two-stage powder coat or mirror-polished finish.
All AEM intakes include AEM’s revolutionary DRYFLOW synthetic performance air filter; the first cleanable, reusable performance air filter that does not require oiling to filter and trap dirt and contaminants (more DRYFLOW key features can be found below).
DRYFLOW Air Filter Key Features
 ·         Will NOT void your vehicle’s warranty!
 ·         No oil eliminates chance of under- or over-oiling, taking the guesswork out of servicing
·         Filter element cleans in minutes and is Guaranteed for Life!
·         Unique filter media is independently tested at up to 99.52% cumulative filtration efficiency to particles as small as one micron, based on ISO 5011:2000 FINE DUST performance testing. Visit www.aempower.com for independent filtration test results
·         A mineral reinforced plastic interior cage increases structural rigidity—it’s virtually impossible to collapse!
·         No mesh screen means a reduced chance of filter damage from bumps during installation or cleaning
All AEM BRUTE FORCE intake systems carry a limited lifetime warranty and are either 50-state legal or pending, excluding “Off Road” only systems which are identified in AEM’s application guides. Some AEM products are legal in California only for racing vehicles, which may never be used upon a highway. AEM designs, manufactures and assembles its BRUTE FORCE intake systems in the U.S.A.
AEM performance products are Engineered to Outperform. The company manufactures high-quality street and race performance products that are distributed worldwide. AEM headquarters is located in Hawthorne, California. Visit www.aempower.com to learn more.
Sponsored Links
Sponsored by
site web
Powered by Google
