Home arrow Aftermarket News arrow SCT Raises the Bar with LIVEWIRE
Bookmark and Share
SCT Livewire tunerLate model Ford Mustang owners will soon get their hands on a powerful next-generation tuning device, straight from the labs at SCT, LLC.  SCT has a fantastic and technologically advanced tuner that will hit the aftermarket like a bolt of lightning.  The LIVEWIRE is like no other handheld tuner released before and its technology reflects in results.  Step into the StangNet store to take a closer look at a this forthcoming product by SCT.
Available at the SN Store
SCT LiveWire 1996-2007 Mustang
Price: $569.00
> Add to Cart <
SCT, LLC is quite honored to debut one of the most advanced custom tuning devices to hit the aftermarket yet.  Covering car, truck, and diesel applications, the LIVEWIRE is no ordinary flash tuner--it offers more power, more data elements, and more features to enable your Ford Mustang (or other vehicle) to do more with less.
Each LIVEWIRE is pre-programmed PCM flash tuner that comes pre-loaded with up to three different dyno-proven performance tunes and one fuel economy tune.  The LIVEWIRE unit can also be custom tuned by any one of SCT's 500+ tuners around the world.
One of the most prominent features of the SCT LIVEWIRE is the 128MB SD memory card that allows for the storage of multiple tunes, for up to 20 different vehicle applications, while preserving the complete factory uploaded program.  Coupled with long-term data logging of multiple PCM parameters, that can either be viewed in real-time and stored into memory or downloaded to a personal computer, these two robust features set this product well ahead of the competition.
SCT Livewire tuner
You asked, SCT listened.  As a result of extensive market research, the LIVEWIRE offers a new instrumentation feature.  The interface screen is capable of viewing and recording 6 different vehicle parameters and up to two additional 0-5 volt signals through a special analog input port.  This allows a user to record and monitor difficult signals, such as RPM, directly from the vehicle’s PCM without a signal converter or interface.  In addition, the analog port allows you to view and record other real-world signals such as boost, wideband O2 or exhaust/gas temperature through the use of external sensors.
In addition to several robust tuning features, LIVEWIRE also has a fully programmable LED shift light that reads the tachometer signal directly from the vehicle’s PCM for better accuracy and consistency.  LIVEWIRE completes this task to perfection by eliminating the need for additional external additional hardware and harness splicing.  A third LED is a warning light that allows you to monitor critical parameters, such as air/fuel or exhaust gas temperature and warn you if there is a potential problem before it is too late.
Don't worry about trying to find this fine piece of programming technology out there on the market--we've got you covered right here on StangNet.  If you want, you can preorder the LIVEWIRE now in the Store and shipments will move as soon as we get them in hand.
Sponsored Links
Sponsored by
site web
Powered by Google
