Home arrow Tech Articles arrow S197 Ford Mustang PMP Line Lock Kit Install
S197 Ford Mustang PMP Line Lock Kit Install PDF Print E-mail
Step 2: Install solenoid adapters into both of the solenoids.  Use teflon tape or paste on the fittings that are going into the solenoids.  This is the only time you will use the teflon.  Use a 7/16" open-end wrench to tighten.  Do not overtighten, but make sure you get a good seal.  Use an 11/16" open-end wrench to hold the solenoid in place.
S197 Ford Mustang PMP Line Lock install
Step 3: Park the car on a level surface.  Chock the rear wheels.  Break the lug nuts loose using your breaker bar and the 13/16" socket.  Jack the car up and support with jack stands on the K member.  Leave the jack for added safety, if you prefer.  Remove the wheels and set aside.  You may want to lie some newspaper down, as you will have some brake fluid dripping.  Here's the stock brake setup, for reference:
Step 4: Carefully remove the ABS Sensor wire clamp from the body using a body panel pin removal tool.
Sponsored Links
Sponsored by
