S197 Ford Mustang PMP Line Lock Kit Install |
Page 4 of 7 Step 8: Attach the caliper side adapter to the fitting on the stock rubber line using a 1/2" wrench.
Step 9: Reattach the bracket on the rubber caliper hose to the body using the 10MM bolt. You can put your ground ring terminal on this bolt, or on your screw for the solenoid, depending on the size of your ring terminal.
Step 10: Attach one end your braided hose with straight fittings to the "in" side of the solenoid (the right side in my setup). Use a 7/16" wrench for the fitting and a 7/16" wrench for the hose. Attach the other end to the hard line fitting. Hold the hard line in place with an 11/16" wrench and use a 7/16" wrench for the hose fitting. Use the 90 degree end of the other hose to connect to the "out" side of the solenoid. Use a 7/16" wrench to hold the fitting in place and a 7/16" wrench for the hose. Connect the other end to the rubber caliper side hose. Use a 1/2" wrench to hold the rubber hose adapter in place and tighten the braided hose with a 7/16" wrench. I went a little crazy with the zip ties, but wanted to make sure to keep everything out of the way.
