Home arrow Tech Articles arrow S197 Ford Mustang Adjustable Upper Control Arm Install
Bookmark and Share
S197 UCA install
S197 UCA install
S197 UCA install
The Bolt will not be able to be removed from the control arm yet, only the nut. The bolt will hit the gas tank at this point when trying to remove it.
S197 UCA install
Step 4.  Using an extension and the 18mm socket, remove the two bolts from the UCA mounting bracket.  These bolts go straight up into the body of the car.
Sponsored Links
Sponsored by
