Home arrow Tech Articles arrow 1996-2004 Ford Mustang Technical Service Bulletins
1996-2004 Ford Mustang Technical Service Bulletins PDF Print E-mail
StangNet.com continues to present Ford Mustang owners with technical documentation with the enclosed listing of all technical service bulletins (TSBs) covering the years from 1996 through 2004.  Be sure the computer you are using has the Adobe Reader software installed so you can view each of the documents listed in the table below.
Mach 1 Ford Mustang
Technical Service Bulletin ID
Description
00-04-02
VIBRATION/SHAKE—AT STEADY SPEED APPROXIMATELY 100 KM/H (62 MPH)— VEHICLES WITH 3.8L ENGINE AND CONVERTIBLE TOP
00-09-01
LEAK—TRANSMISSION FLUID LEAKS AT RADIATOR—VEHICLES EQUIPPED WITH AUTOMATIC TRANSMISSION AND TRANSMISSION OIL COOLER IN RADIATOR END TANK
00-09-04
NOISE—“POPPING/CLUNKING” HEARD WHILE PERFORMING A QUICK LANE CHANGE AT HIGHWAY SPEEDS AND/OR GOING UP AN INCLINE AT LOW SPEEDS—COBRA VEHICLES ONLY (DOES NOTINCLUDE COBRA R VEHICLES)
00-09-06
WINDSHIELD WIPERS—FRONT WIPERS OPERATE WHILE SWITCH IS IN “OFF” POSITION
00-09-07
VIBRATION/SHAKE—AT STEADY SPEED APPROXIMATELY 100 KM/H (62 MPH)—VEHICLES WITH 4.6L ENGINE AND CONVERTIBLE TOP
00-18-03
COOLING SYSTEM—COOLANT LEAK FROM PASSENGER SIDE OF INTAKE MANIFOLD AT REAR CORNER OF HEAD—VEHICLES BUILT FROM 7/1/1998 THROUGH 6/30/2000—VEHICLES WITH 4.6L 2V OR 5.4L 2V ENGINE
ENGINE—4.6L 2V OR 5.4L 2V—COOLANT LEAK FROM PASSENGER SIDE OF INTAKE MANIFOLD AT REAR CORNER OF HEAD—VEHICLES BUILT FROM 7/1/1998 THROUGH 6/30/2000
00-21-02
HOOD—HOOD REQUIRES EXCESSIVE EFFORT TO CLOSE—SERVICE TIPS
00-23-10
TRANSMISSION—FLUID IN-LINE FILTER KIT—REPEAT REPAIRS OF TRANSMISSION—SERVICE TIPS
01-01-09
DRIVEABILITY—HESITATION WHEN COLD—WITH NO DIAGNOSTIC TROUBLE CODES (DTC) PRESENT—VEHICLES EQUIPPED WITH 4.6L ENGINE AND MANUAL TRANSMISSION
01-04-08
ENGINE—3.8L—OIL PUMP LIQUID INJECTION SEAL (LIS) GASKET SERVICE PROCEDURE—MUSTANG VEHICLES EQUIPPED WITH 3.8L ENGINE—VEHICLES PRODUCED 11/27/2000 THROUGH 6/30/2001—SERVICE TIPS
01-05-08
NOISE—“TICKING” OR “CLICKING” FROM Article No.TRANSMISSION—HEARD IN 1ST GEAR ONLY—VEHICLES EQUIPPED WITH 4R70W AUTOMATIC TRANSMISSION ONLY
TRANSMISSION—4R70W—“TICKING” OR “CLICKING” NOISE FROM TRANSMISSION—HEARD IN 1ST GEAR ONLY—VEHICLES EQUIPPED WITH 4R70W AUTOMATIC TRANSMISSION ONLY
01-06-02
PASSIVE ANTI THEFT SYSTEM (PATS)—DIAGNOSTIC SERVICE TIPS
01-07-01
SUSPENSION—NOISE—“SQUEAK” FROM REAR SUSPENSION OVER BUMPS—COBRA MODELS ONLY
NOISE—“SQUEAK” FROM REAR SUSPENSIONOVER BUMPS—COBRA MODELS ONLY
01-08-03
VIBRATION—FELT THROUGH SEAT, FLOOR AND/OR STEERING WHEEL AT HIGHWAY SPEEDS WHILE IN 4TH OR 5TH GEAR—COBRA MODEL ONLY
01-09-07
DRIVEABILITY—HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS—SERVICE TIPS—OBD II VEHICLES ONLY
01-10-12
WIRING—WIRE HARNESS TERMINAL REPAIR KIT AND WIRE SPLICE PROCEDURE
01-12-03
DRIVEABILITY—DETONATION OR SPARK KNOCK ON HEAVY ACCELERATION—MUSTANG BULLITT GT VEHICLES ONLY
ENGINE—4.6L 2 VALVE—DETONATION OR SPARK KNOCK ON HEAVY ACCELERATION—MUSTANG BULLITT GT VEHICLES ONLY
01-13-07
NOISE—“CLUNK” NOISE HEARD ON 2-1 DOWNSHIFT VEHICLES EQUIPPED WITH 4R70W AUTOMATIC TRANSMISSION
TRANSMISSION—4R70W—“CLUNK” NOISE HEARDFROM TRANSMISSION ON 2-1 DOWNSHIFT
01-15-06
CLIMATE CONTROL—REPEAT HEATER CORE FAILURE
COOLING SYSTEM—REPEAT HEATER CORE FAILURE
01-17-04
BODY—HOOD SCOOP LOOSE OR DETACHED FROM HOOD
01-21-06
ELECTRICAL—REVISED MECHANICAL HOOD LAMP SWITCH TO REPLACE OLD STYLE MERCURY HOOD LAMP SWITCH
01-21-10
ENGINE—4.6L—OIL LEAK FROM HEAD GASKET AREA—ROMEO BUILT ENGINES ONLY
01-21-13
DRIVEABILITY—DIAGNOSTIC TROUBLE CODES (DTC) P0500, P1502 AND/OR U1039 CONTINENTAL MODELS ONLY—STICKING OR BINDING IGNITION LOCK CYLINDER—HIGH EFFORT WHEN TURNING IGNITION SWITCH
ELECTRICAL—STICKING OR BINDING IGNITION
01-23-05
TRANSMISSION—T-45 MANUAL TRANSMISSION—STUCK IN REVERSE—DIFFICULT TO SHIFT INTO REVERSE—POPS OUT OF REVERSE
01-24-06
ENGINE—ENGINE OIL SYSTEM PRIMING PROCEDURES—SERVICE TIPS
02-02-02
COOLANT—COOLANT SEEPAGE AT INTAKE MANIFOLD CROSS-OVER—VEHICLES EQUIPPED WITH 4.6L 2V ENGINE ONLY
ENGINE—4.6L 2V—COOLANT SEEPAGE AT INTAKE MANIFOLD CROSS-OVER
02-05-04
ENGINE—4.6L—FRONT END ACCESSORY DRIVE (FEAD) BELT SLIPS OFF WATER PUMP PULLEY WHEN SPLASHED WITH WATER
02-06-07
PAINT—MYSTIC COBRA—REPAIR MATERIAL REQUEST PROCESS—SVT MUSTANG COBRA ONLY
02-11-04
ENGINE—NEW GASKET REMOVER/CLEANER AND SERVICE TIPS FOR ALUMINUM HEADS AND BLOCKS
02-16-04
FUEL SYSTEM—FUEL PUMP “WHINING”/“BUZZING” NOISE COMES THROUGH ENTERTAINMENT OR TWO-WAY RADIO SPEAKER
RADIO—ENTERTAINMENT OR TWO-WAY COMMUNICATION—“WHINING”/“BUZZING” NOISEIN SPEAKERS CAUSED BY FUEL PUMP
NOISE—“WHINING”/“BUZZING”—COMES THROUGH SPEAKERS OF ENTERTAINMENT OR TWO-WAY RADIO
02-17-02
ENGINE—OIL LEAK FROM POSITIVE CRANKCASE VENTILATION (PCV) VALVE AREA—VEHICLES BUILT BEFORE 5/17/2002 EQUIPPED WITH 4.6L 2V ENGINE ONLY
02-17-06
LAMP—BRAKE—INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK
02-17-08
NOISE—WIND NOISE FROM THE “A” PILLAR AREA
02-21-13
ENGINE—STRAIGHTEDGE PROCEDURE FOR CHECKING CYLINDER HEAD AND BLOCK FLATNESS
02-22-01
DRIVEABILITY—SURGE/ROLLING IDLE—GEAR DRIVEN SYNCHRONIZERS—INCORRECT INSTALLATION—CAMSHAFT POSITIONSYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION
ENGINE—GEAR DRIVEN SYNCHRONIZERS—INCORRECT INSTALLATION—CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION
02-23-03
DRIVEABILITY—FUEL PRESSURE RELIEF VALVE (SCHRADER VALVE) DISCONTINUED
ENGINE—3.0L/3.8L/4.6L—FUEL PRESSURE RELIEFVALVE (SCHRADER VALVE) DISCONTINUED
02-23-04
DIAGNOSTIC TROUBLE CODE (DTC)—P1635 AND/OR P1639 PRESENT AFTER POWERTRAIN CONTROL MODULE (PCM) OR INSTRUMENTCLUSTER REPLACEMENT—GASOLINE ENGINE VEHICLES ONLY
LAMP—4X4 LAMP ILLUMINATED AFTER POWERTRAIN CONTROL MODULE (PCM) OR INSTRUMENT CLUSTER REPLACEMENT—GASOLINE ENGINE VEHICLES ONLY
SPEEDOMETER—INACCURATE AND/OR INOPERATIVE AFTER POWERTRAIN CONTROL
03-01-05
TRIM—PASSENGER SEAT RUBS AGAINST DOOR PANEL
03-03-06
SUSPENSION—DRIFT OR PULL TO RIGHT OR LEFT—MUSTANG COBRA MODELS ONLY
03-06-02
ENGINE—CYLINDER HEAD DECK LEAK—4.6 AND 5.4L ENGINES—NEW “SERVICE-ONLY” GASKET AND CYLINDER HEAD KITS AVAILABILITY
03-09-05
SUSPENSION—CLUNK OR POP NOISE FROM REAR SUSPENSION—MUSTANG COBRA ONLY—SERVICE TIPS
NOISE—CLUNK OR POP NOISE FROM REARSUSPENSION—MUSTANG COBRA ONLY—SERVICE TIPS
03-11-04
ENGINE—MUSTANG COBRA—TICK NOISE FROM
ENGINE—COBRA VEHICLES EQUIPPED WITH ENGINES BUILT BEFORE 11/1/2002 ONLY
03-18-01
ELECTRICAL—REMOTE KEYLESS ENTRY (RKE)—SERVICE TIPS
03-20-03
DRIVEABILITY—MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DTC’S P0442, P0455, P0456, P0457, P1442 OR CHECK FUEL CAP LAMP ILLUMINATED WITH DTC P0457
03-22-01
BODY—NOISE—HOOD SCOOP (SHAKER) RATTLE NOISE
ENGINE—NOISE—HOOD SCOOP (SHAKER) RATTLE NOISE
03-23-02
BODY—MIRROR—EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT—SERVICE TIPS
03-24-03
TRANSMISSION—AUTOMATIC TRANSMISSION GEAR SELECTOR LEVER STUCK IN PARK, UNABLE TO SHIFT INTO PARK—OVERDRIVE FUNCTION INOPERATIVE
03-25-05
PAINT—PIN HOLES AND/OR PAINT DELAMINATIONON VEHICLE HOOD—VEHICLES BUILT 6/1/2001 THROUGH 3/1/2003 ONLY
03-25-06
ENGINE—ROMEO BUILT 4.6L 2V—TICK NOISE FROM ENGINE—ENGINES BUILT BEFORE 9/17/2003
04-01-02
BODY—INTERIOR TRIM—HEADLINER SAGGING IN REAR
04-05-03
CLIMATE CONTROL—RATTLE NOISE FROM INSTRUMENT PANEL VENTS—DIFFICULT TO ADJUST
NOISE—CLIMATE CONTROL—RATTLE NOISEFROM INSTRUMENT PANEL VENTS—DIFFICULT TO ADJUST
04-11-01
DRIVEABILITY—STREAMLINED DIAGNOSTIC PROCEDURE FOR VEHICLES WITH MIL ON AND DTCS P0401, P0402, P1400 OR P1401—ADDITIONAL SYMPTOMS MAY INCLUDE RUNS ROUGH, LACKS POWER, SURGE, POOR FUEL ECONOMY
04-13-04
TRANSMISSION RATTLE NOISE OR DIFFICULT TO SHIFT—TREMEC T56 6 SPEED MANUAL
04-15-06
TR3650 MANUAL TRANSMISSION—JUMPS OUT OF GEAR 2ND AND/OR 3RD—CLASH NOISE AND/OR RASPY FEEL ON GEAR ENGAGEMENT
04-17-04
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED—SYSTEM LEAN DIAGNOSTIC TROUBLE CODES (DTC’S)—SERVICE TIPS
04-19-08
MANUAL TRANSMISSION HARD TO SHIFT INTO FIRST/REVERSE FROM A STOP
04-21-06
EXHAUST LEAK—CRACKED OR SEPARATED RIGHT SIDE EXHAUST PIPE—3.8L AND 3.9L ENGINES
04-24-03
LEATHER-WRAPPED STEERING WHEEL—LEATHER COMING LOOSE
04-24-05
REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR—TERMINAL TAB REPAIR
04-24-14
GENERAL PCM PROGRAMMING PROCEDURES
04-26-13
1-2 SHIFT CLASH, GRIND OR HARD TO SHIFT—TR3650 5 SPEED MANUAL TRANSMISSION
05-03-10
SAFETY BELT WEB STOP BUTTON SERVICE
05-09-03
INTERIOR PLASTIC TRIM—PAINT-TO-MATCH AND REPAIR—INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-14-03
SQUEAK/CREAK NOISE FROM STEERING RACK WHEN TURNING
05-16-11
SAFETY BELT RETRACTION SPEED
05-22-08
WDS COP KIT DIAGNOSTIC TIPS—COIL ON PLUG (COP) IGNITION SYSTEMS—ENGINE MISFIRE OR ROUGH RUNNING
06-04-02
BATTERY SERVICE—OPERATION OF BATTERY EYE—CHARGING SERVICE TIPS
06-04-04
LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS
06-04-09
A/C COMPRESSOR NOT OPERATIONAL / LOW FREON—SHAFT SEAL LEAKS
06-05-13
ENGINE MISFIRE WITH DIAGNOSTIC TROUBLE CODE (DTC) P0301, P0302, P0303, P0304, P0305,P0306, P0307, P0308, AND P0316
06-08-05
SPEED CONTROL DIAGNOSTICS—W/O SCP
06-14-04
MERCON ATF IS BEING REPLACED BY MERCON V ATF AS A SERVICE FLUID
06-15-08
KEYPAD DIAGNOSTICS—DEALER INSTALLED ACCESSORY
06-18-16
IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES—SERVICE TIP
95-16-10
FLUID—NEW ROTUNDA FLUID CHANGER—SERVICE TIP
95-21-01
SUPPLEMENTAL RESTRAINT SYSTEM—AIR BAG MODULES—DISCOLORED OR MARRED COVERS—PAINTING RESTRICTIONS
96-03-14
NOISE—LIGHT “CLICKING” AND/OR “GRINDING” NOISE—VEHICLES BUILT FROM 8/11/95 THROUGH 9/25/95 WITH T5OD MANUAL TRANSMISSION AND 3.8L ENGINE
TRANSMISSION—MANUAL—T5OD—3.8L ENGINE—LIGHT “CLICKING” AND/OR “GRINDING” NOISE—VEHICLES BUILT FROM 8/11/95 THROUGH 9/25/95
96-04-06
COOLING SYSTEM—COOLANT LEAK FROM UPPER RADIATOR HOSE—VEHICLES BUILT FROM 8/14/95 THROUGH 11/8/95 WITH 3.8L ENGINE
LEAKS—COOLING SYSTEM—COOLANT LEAKFROM UPPER RADIATOR HOSE—VEHICLES BUILTFROM 8/14/95 THROUGH 11/8/95 WITH 3.8LENGINE
96-06-05
TRANSMISSION—4R70W—#9 THRUST BEARING—SERVICE TIP
96-07-02
LOCKS—NEW DESIGN LOCKSETS HAVE BEEN INSTALLED ON CERTAIN TRIAL VEHICLES—CARS REFERENCED—SERVICE TIP
96-07-11
TRANSMISSION—4R70W—SPECIAL SELECTION PROCEDURE FOR LOW SERVO PISTON—SERVICE TIP
TRANSMISSION—4R70W—UNIQUE CASE WITH
LOW/REVERSE SPACER—SERVICE TIP
96-10-06
NEW GENERATION STAR (NGS) TESTER—INCORRECT INFORMATION DISPLAYED DURING DIAGNOSTIC MONITORING TEST RESULTS—VEHICLES WITH ON-BOARD DIAGNOSTICS (OBD) II
96-10-07
FUEL—CALIFORNIA REFORMULATED GASOLINE (CARFG)—SERVICE TIP
96-11-01
LOCKS—INTRODUCTION OF NEW LOCK DESIGN—SERVICE TIP
96-12-05
ANTI THEFT—DIAGNOSTIC PROCEDURES—SERVICE TIP
96-12-09
NOISE—“CHATTER” DURING TIGHT TURNS OR TURNS AFTER AN EXTENDED PERIOD OF HIGHWAY DRIVING—TRACTION-LOK
DIFFERENTIAL—7.5 AND 8.8 INCH RING GEAR
REAR AXLES
AXLE—NEW SERVICE KIT AVAILABLE FOR
TRACTION-LOK DIFFERENTIAL—7.5 AND 8.8 INCH
RING GEAR
AXLE—TRACTION-LOK DIFFERENTIAL—7.5 AND
8.8 INCH RING GEAR—“CHATTER” NOISE DURING
96-14-08
ENGINE—NOISE—“SQUEAL” NOISE COMING FROM FEAD DURING COLD START AT TEMPERATURES BELOW -7 DEGREES C (20 DEGREES F)—4.6L VEHICLES
NOISE—“SQUEAL” DURING COLD START ATTEMPERATURES BELOW -7 DEGREES C (20
DEGREES F)—FEAD IDLER PULLEY AND/OR FEAD
TENSIONER ASSEMBLY—4.6L VEHICLES
96-14-09
BELT—FRONT END ACCESSORY DRIVE (FEAD) “SQUEAL/HOOT”—DURING COLD START-UP AFTER COLD SOAK BELOW -18 DEGREES C (0 DEGREES F)
NOISE—“SQUEAL/HOOT” FROM FRONT END
ACCESSORY DRIVE (FEAD) AREA—DURING COLD
96-15-06
AIR CONDITIONING--FILTERING REFRIGERANT--SYSTEM FLUSHING--TRACER DYE--LEAK TESTING--O-RING TOOL--TSB REPLUBLICATION TO INCLUDE LATEST MODEL YEAR
96-16-01
SUSPENSION—FRONT—“RATTLE” NOISE—MOST NOTICEABLE IN COLD TEMPERATURES—VEHICLES BUILT FROM 8/14/95 THROUGH 1/19/96
NOISE—“RATTLE” FROM FRONT SUSPENSION—
96-17-09
NOISE—“RATTLE” FROM FRONT SUSPENSION—MOST NOTICEABLE IN COLD TEMPERATURES—
96-20-07
AIR CONDITIONING—NEW O-RING AVAILABILITY AND APPLICATIONS—SERVICE TIP
96-20-08
AIR CONDITIONING—NEW O-RING APPLICATIONS—THICKER O-RINGS FOR SPRING LOCK FITTINGS—SERVICE TIP
AIR CONDITIONING—SPRING LOCK COUPLING CLEANING PROCEDURE—SERVICE TIP
96-22-05
 MASS AIR FLOW SENSOR—REPLACEMENT AS AN ASSEMBLY—SERVICE TIP
96-23-07
ENGINE—3.8L—OIL LEAK AT #4 FRONT COVER/WATER PUMP STUD—VEHICLES BUILT THROUGH 1/10/96
96-24-06
WIRING—ELECTRICAL DIODE IDENTIFICATION AND SERVICE REPLACEMENTS
96-24-09
TORQUE CONVERTER—LEAK TEST PROCEDURE—SERVICE TIP
96-25-03
INTERIOR TRIM—CENTER CONSOLE—AVAILABILITY OF GAP HIDER FOR CENTER CONSOLE—VEHICLES BUILT FROM 6/1/96
96-25-12
AIR CONDITIONING—AIR CONDITIONING SHUTS OFF IN HIGH AMBIENT TEMPERATURES AND VEHICLE MAY OVERHEAT—4.6L AND GT OR COBRA
COOLING SYSTEM—OVERHEATING AND/OR
VEHICLE GOING INTO THERMO PROTECTION
MODE—VEHICLES WITH 4.6L ENGINE AND GT OR
COBRA
96-26-08
BLOWER MOTOR—INTERMITTENT OR INOPERATIVE—TEMPERATURES AT OR BELOW 0 96-26-8DEGREES C (32 DEGREES F)
96-26-12
TRANSAXLE—TORQUE CONVERTER REPLACEMENT GUIDELINES AND TORQUE CONVERTER/TRANSAXLE COOLING SYSTEMCLEANING PROCEDURES—SERVICE TIP
TRANSMISSION—TORQUE CONVERTER
CONVERTER/TRANSMISSION COOLING SYSTEM
97-05-06
ODOMETER—ODOMETER AND TRIP METER STICK—WILL NOT OPERATE AND/OR “CLICKING” NOISE—VEHICLES BUILT 3/14/96 THROUGH 9/13/96
NOISE—“CLICKING” NOISE FROM ODOMETER OR
TRIP METER—INOPERATIVE—VEHICLES BUILT
97-08-06
MALFUNCTION INDICATOR LAMP (MIL)—DIAGNOSTIC TROUBLE CODES (DTCS) P0300, P0301, P0302, P0303, P0304, P0305, P0306, P0307,AND/OR P0308 STORED IN MEMORY
LAMP—MALFUNCTION INDICATOR LAMP (MIL)ILLUMINATES—DIAGNOSTIC TROUBLE CODES(DTCS) P0300, P0301, P0302, P0303, P0304, P0305,P0306, P0307, AND/OR P0308 STORED IN MEMORY
97-09-05
LONG CRANK—STICKING IDLE AIR CONTROL (IAC) VALVE—VEHICLES BUILT FROM 11/1/94 THROUGH 3/30/96
STALL—AFTER STARTING WHEN ENGINEALLOWED TO SOAK FROM 1-4 HOURS—STICKING
97-09-07
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED—DIAGNOSTIC TROUBLE CODES (DTCS) P0300, P0301, P0302, P0303, P0304, P0305,
P0306, P0307, P0308—NO DRIVEABILITY
CONCERNS—4.6L 2V ENGINES ONLY
LAMP—MALFUNCTION INDICATOR LAMP (MIL)ILLUMINATED—DIAGNOSTIC TROUBLE CODES
POWERTRAIN CONTROL MODULE (PCM)—
REPROGRAM—4.6L 2V ENGINES ONLY
97-09-08
POWERTRAIN CONTROL MODULE—REPROGRAM POWERTRAIN CONTROL MODULE (PCM)—SERVICE PROCEDURES—SERVICE TIP
97-10-04
ENGINE COOLING FAN—MODULE COMPONENT SERVICE INFORMATION
INFORMATION
97-10-05
AIR CONDITIONING—COMPRESSOR FAILURE—INSUFFICIENT AMOUNT OF REFRIGERANT OIL AIR CONDITIONING—LACK OF COOLING—
MAY CAUSE COMPRESSOR FAILURE
97-11-11
TRANSMISSION—4R70W—ERRATIC OR PROLONGED 1-2 SHIFT
TRANSMISSION—AODE—ERRATIC OR PROLONGED 1-2 SHIFT
97-15-05
AIR CONDITIONING—OIL REFILL CAPACITY CHART—SERVICE TIP
97-19-04
BRAKES—BRAKE AND ROTOR SERVICE TIPS
97-21-10
TRANSMISSION—4R70W—NEW DESIGN ENHANCEMENTS FOR 1998 VEHICLES
TRANSMISSION—4R70W—NEW ONE-WAY CLUTCH (OWC) TO SERVICE AT THE INTERMEDIATEPOSITION
97-22-01
DELTA PRESSURE FEEDBACK EGR (DPFE)—DIAGNOSTIC TIPS
97-24-01
LEAKS WATER—DURING HEAVY RAIN AND/OR WHEN GOING THROUGH CAR WASH—CONVERTIBLE TOP VEHICLES ONLY
97-24-13
REMOTE KEYLESS ENTRY (RKE)—DIAGNOSTIC SERVICE TIPS
97-24-15
LAMP—LOW OIL INDICATOR LAMP ILLUMINATION—4.6L VEHICLES
OIL—LOW OIL INDICATOR LAMP ILLUMINATION—
4.6L VEHICLES
97-25-05
BLOWER MOTOR—“CHIRPING” OR “SQUEAKING” FROM BLOWER MOTOR AT LOW SPEEDS
NOISE—“CHIRPING” OR “SQUEAKING” FROM BLOWER MOTOR AT LOW SPEEDS
98-07-04
LEAKS—OIL—AVAILABILITY OF NEW SILICONE GASKET AND SEALANT
98-12-05
AIR CONDITIONING—FILTERING REFRIGERANT Article No.
AFTER A/C COMPRESSOR REPLACEMENT— 98-12-5
SERVICE TIPS
98-17-18
MOULDINGS—ROCKER PANEL—LOOSE
98-20-10
EXHAUST SYSTEM—LOOSE CATALYST OR MUFFLER HEAT SHIELDS
NOISE—“BUZZING” OR “RATTLING”—LOOSE
98-20-18
FRONT END ACCESSORY DRIVE (FEAD) BELT—BELT NOISE, DAMAGE, AND/OR BELT COMES OFF—VEHICLES WITH 4.6L ENGINE AND MANUALTRANSMISSION
98-22-02
CLUTCH—VIBRATION/NOISE FELT IN CLUTCH PEDAL WHEN LIGHTLY TOUCHING CLUTCH PEDAL
98-23-10
MASS AIR FLOW (MAF)—SENSOR CONTAMINATION—SERVICE TIP
98-23-12
TRANSMISSION—4R44E—DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY
TRANSMISSION—4R55E—DIAGNOSTIC TROUBLECODES (DTCS) P0705, P0708, P1704 AND/OR P1705
STORED IN MEMORY
TRANSMISSION—4R70W—DIAGNOSTIC TROUBLE
STORED IN MEMORY
TRANSMISSION—5R55E—DIAGNOSTIC TROUBLE
STORED IN MEMORY
TRANSMISSION—AX4N—DIAGNOSTIC TROUBLE
STORED IN MEMORY
TRANSMISSION—AX4S—DIAGNOSTIC TROUBLE
STORED IN MEMORY
TRANSMISSION—E4OD—DIAGNOSTIC TROUBLE
STORED IN MEMORY
98-25-03
GLASS—FRONT WINDOW MAY TRAVEL BEYOND THE UPSTOP AND OUT OF THE GLASS RUN
99-02-03
WATER LEAKS—WINDSHIELD SEALING—SERVICE TIP
WINDSHIELD—SEALING—SERVICE TIP
99-04-03
REPROGRAMMING POWERTRAIN CONTROL MODULES (PCMS)—OUT-OF-VEHICLE—EEC V VEHICLES ONLY
99-08-15
INTERIOR TRIM—DOOR TRIM PANEL REPLACEMENT—SERVICE TIP
99-10-01
BODY—DUST INTRUSION INTO LUGGAGE COMPARTMENT
WATER LEAK—EVIDENCE OF WATER LEAK INTO
LUGGAGE COMPARTMENT
NOISE—EXCESSIVE ROAD NOISE HEARD FROM
REAR WHEEL AREA
99-11-01
NOISE—TSB Special For Noise/Vibration/Harshness
VIBRATION—TSB Special For Noise/Vibration/Harshness
99-14-07
CALIBRATION INFORMATION—VEHICLES BUILT THROUGH 1/29/1999—APPLICABLE ENGINES ARE 2.0L, 2.5L, 3.0L, 3.4L, 3.8L, 4.0L, 4.2L, 4.6L, 5.0L, 5.4L, 6.8L, AND 7.3L—SERVICE TIP
99-18-05
TRANSMISSION CONTROL INDICATOR LAMP (TCIL)—TCIL ILLUMINATED WITH DIAGNOSTIC TROUBLE CODE (DTC) P0782 STORED IN MEMORY—VEHICLES BUILT BETWEEN 3/15/1997
AND 12/31/1998 AND WITH 4R70W TRANSMISSION
TRANSMISSION—4R70W—DELAYED OR NO 2-3
UPSHIFT—VEHICLES BUILT BETWEEN 3/15/1997
AND 12/31/1998
99-19-07
LAMP—INTERMITTENT MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION—DIAGNOSTIC TROUBLE CODES (DTCS) P0741, P0750, P0755, AND P1746 MAY BE STORED IN MEMORY—
VEHICLES BUILT FROM 8/1/1998 THROUGH 5/1/1999 WITH 4R70W TRANSMISSION
LAMP—INTERMITTENT TRANSMISSION CONTROL INDICATOR LAMP (TCIL) ILLUMINATION—DIAGNOSTIC TROUBLE CODES (DTCS) P0741, P0750, P0755, AND P1746 MAY BE STORED IN
MEMORY—VEHICLES BUILT FROM 8/1/1998 THROUGH 5/1/1999 WITH 4R70W TRANSMISSION
TRANSMISSION—4R70W—INTERMITTENT TRANSMISSION CONTROL INDICATOR LAMP (TCIL) ILLUMINATION—DIAGNOSTIC TROUBLE CODES (DTCS) P0741, P0750, P0755, AND P1746 MAY BE STORED IN MEMORY—VEHICLES BUILT FROM 8/1/1998 THROUGH 5/1/1999
99-20-07
COOLING SYSTEM—3.8L—UNDETERMINED LOSS OF COOLANT
COOLING SYSTEM—4.2L—UNDETERMINED LOSSOF COOLANT
ENGINE—3.8L—ENGINE OIL CONTAMINATED WITHCOOLANT
ENGINE—4.2L—ENGINE OIL CONTAMINATED WITHCOOLANT
99-21-08
BODY—“CREAKING” NOISE FROM LH REAR QUARTER AREA—CONVERTIBLES ONLY
NOISE—“CREAKING” FROM LH REAR QUARTER AREA—CONVERTIBLES ONLY
99-22-05
CONVERTIBLE TOP—IMPROPER FIT OF CONVERTIBLE TOP BOOT
99-22-06
NOISE—“POPPING” OR “OIL CANNING” NOISE FROM DRIVER’S FOOTWELL AREA
99-23-04
MALFUNCTION INDICATOR LAMP (MIL)—DIAGNOSTIC TROUBLE CODES (DTCS) P0442 AND P0455—NO DRIVEABILITY CONCERNS
99-24-02
LOCKS—REPLACE AND/OR REPAIR ANY LOCK COMPONENT—AVAILABILITY OF INDIVIDUAL LOCKS
Sponsored Links
Sponsored by
