Mustang Forums at StangNet
Creating Animated GIFs
This is a discussion on Creating Animated GIFs within the The Virtual Body Shop forums, part of the Specialty Fun Forums category; This question seems to come up a lot, so I'll stick this for now. Basically, you have three kinds of ...
Go Back   Mustang Forums at StangNet > General Site Forums > Specialty Fun Forums > The Virtual Body Shop
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 07-10-03, 09:06 AM
Moden's Avatar
Lightbulb Creating Animated GIFs
This question seems to come up a lot, so I'll stick this for now. Basically, you have three kinds of images on the internet - GIFs, JPEGs, and PNGs. JPEGs are good for pictures because they can store a lot of colors with minimal file size but, depending on their compression, can look crappy. PNGs are typically used only for posting final copies of work that is to be printed or something, they are very large but have no limits. GIFs are limited to 256 colors and get pretty large in file size if the image is too big. However, they're prefect for small icons. GIFs also have the unique ability to be animated.
Photoshop, as wonderful as it is, can not animate GIFs. You'll need a separate program for that. If you have a Mac, try GIFBuilder; if you use Windows try Babarosa GIF Animator. Both are pretty simple to use and have some neat extra features, but I'll just go through the basics here. (Edit: A lot of you probably have Adobe ImageReady, as it comes with later versions of PhotoShop. I don't have much experience with it, but it can also animate GIFs, as noted further down in the thread. )
The four main things you'll need to know are the Frame Disposal Meathod, Frame Delay, Frame Transparency, and Loop. The FDM is what each particular frame does when the next one comes up. There are four choices - Unspecified, Do Not Dispose, Revert To Background and Revert To Previous. If you feel like tinkering around with these settings to get files size down you can, but for the most part just choose Do Not Dispose and you'll be fine. If you notice extra crap showing up behind frames in the final GIF, go back and chose Revert To Background. (You need to do this for each frame.)
Frame Delay is quite simple. If tells the computer how long to keep each frame on the screen. This value is typically measured in 1/100ths of a second, so if you want a frame to show up for one second, you would type in 100. For a nice smooth looking animation, you'll probably want to set it to somewhere from 4 to 10. Once again, this needs to be done for each frame - that way, you can have some frames show longer than others. If you leave this value blank, the computer will simply try to play the frame as fast as it can, which typically looks bad.
Frame Transparency determines if the frame has any transparency. (Rocket science!) Basically, if you want a frame to have a backgound that "shows through" to the page, you make the background a color not used in the picture (say, bright pink). You then set the transparency to that color. This feature is also independant to each frame.
Finally, you have the Loop setting. This one is self-explanitory - you can either have the GIF play once and stop (no loop), loop forever, or loop a set number of times.
That's it!
-david-
  #2 (permalink)
Old 07-21-03, 01:15 PM
AdamantiumKnot's Avatar
  #3 (permalink)
Old 08-03-03, 06:58 PM
ryanrule's Avatar
impotent
ok, can someone help me with this, gifs dont animate on my comp, the used to , but not any mopre, cant think of anything i did that would cause this. i have xp pro
  #4 (permalink)
Old 08-04-03, 02:10 AM
what program and file formats are you working with?
  #5 (permalink)
Old 08-06-03, 06:02 PM
ryanrule's Avatar
impotent
i mean anywhere, like here in internet explorer. i assume those pictures u posted are animated gifs, but they dont animate, all i see is the first frame
  #6 (permalink)
Old 08-13-03, 11:06 AM
ryanrule's Avatar
impotent
  #7 (permalink)
Old 08-13-03, 11:47 AM
i dunno why they're not working for you, they've been working for everyone else i showed them to.
  #8 (permalink)
Old 08-13-03, 05:22 PM
ryanrule's Avatar
impotent
i know, that was my question, no gif animations anywhere work for me, i was wonderin of anyone knew a setting that i may hve touched or sumthin
  #9 (permalink)
Old 08-14-03, 01:14 AM
not a clue, sorry.
  #10 (permalink)
Old 08-19-03, 06:03 PM
just made a new one
  #11 (permalink)
Old 08-21-03, 12:32 AM
ryanrule's Avatar
impotent
this sucks
  #12 (permalink)
Old 08-21-03, 11:28 PM
Cammed90Notch's Avatar
Official Member
Can't I use Adobo Image Ready?
  #13 (permalink)
Old 08-22-03, 12:52 PM
care to clarify that statement?
  #14 (permalink)
Old 08-22-03, 10:09 PM
Official Member
Quote:
I was asking if I could use ImageReady to create animated gifs?
  #15 (permalink)
Old 08-22-03, 10:27 PM
yes you can. it's my program of preference
  #16 (permalink)
Old 08-23-03, 12:00 AM
Official Member
so how do you do it w/ ImageReady?
Thanks
  #17 (permalink)
Old 08-23-03, 09:56 AM
import a .avi file or go and make an image with layers then create animation from layers.
  #18 (permalink)
Old 08-24-03, 10:54 AM
EvilPopTarts's Avatar
Official Member
Quote:
With your browser open go to tools, then internet options.. Click on the advanced tab. Go down under multimedia and make sure the box is checked that says show animations.
  #19 (permalink)
Old 08-24-03, 09:38 PM
mustangfreak_2001's Avatar
i use adobe imageready 7.0 for my animated gifs
  #20 (permalink)
Old 08-24-03, 10:17 PM
Official Member
MustangFreak or anyone else, would ya'll mind posting some of your examples of your animated stuff?
  #21 (permalink)
Old 08-29-03, 08:30 PM
Quote:
i dont have any real good ones....but i could make one
  #22 (permalink)
Old 08-29-03, 08:55 PM
just made this in about 5 mins
  #23 (permalink)
Old 08-29-03, 09:51 PM
Official Member
Neat, can you send me the file so I can see how you did it? you can send it to notchking@yahoo.com
  #24 (permalink)
Old 08-30-03, 07:11 PM
just right click save as
  #25 (permalink)
Old 08-30-03, 10:41 PM
Official Member
will it show the layers though?
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
