Mustang Forums at StangNet
Would putting speedo gear in auto keep it from shifting into O/D?
This is a discussion on Would putting speedo gear in auto keep it from shifting into O/D? within the 4.6 Tech forums, part of the 4.6L Mustang category; I replaced my transmission (4R70W) recently. While I had it out I went ahead and put my speedo gear in ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-19-03, 12:49 PM
BennettDMB's Avatar
I replaced my transmission (4R70W) recently. While I had it out I went ahead and put my speedo gear in to compensate for my 4.10's. The 4.10's haven't gone in yet.....would having the speedo gear in without the 4.10's keep my tranny from shifting into O/D? I was thinking maybe since my speedo reads a lot slower than I am going the computer is keeping the tranny out of O/D. Any ideas?
  #2 (permalink)
Old 08-20-03, 06:04 PM
BennettDMB's Avatar
  #3 (permalink)
Old 12-19-03, 06:30 PM
Official Member
I would say that it probably would...From what i have read i would assume so becuase the computer reads the speed from and adjust gears accordingly. I could be wrong but thats my understanding
Anyone else?
  #4 (permalink)
Old 12-19-03, 07:53 PM
Official Member
Quote:
Speedo gear in a 4r70w? The only way to compensate for a gear change with a 4r70w is a computer chip or reprogram the EEC.
  #5 (permalink)
Old 12-19-03, 10:20 PM
BennettDMB's Avatar
Quote:
That's true for the 99 and up. Mine is a 1996 (Tranny is out of a 95)
  #6 (permalink)
Old 12-19-03, 11:17 PM
O-G
A 95' tranny is not a 4R70W, it's a AODE.
  #7 (permalink)
Old 12-19-03, 11:33 PM
98GTfromGA's Avatar
nope the speedo gear only sends a signal to the speedometer. the OSS sends the signal to the pcm
to tell it when to shift
  #8 (permalink)
Old 12-19-03, 11:45 PM
Dark Knight GT's Avatar
I can't get it up......ok that didn't sound right.
If the transmission is electronically controled, it will shift gears based upon rpms, not mph.
Since you have a 95 transmission, it is a AODE transmission as San~Man said. Not a 4r70w automatic. The only thing the speedogear will do is help to give a more correct speedo reading for the gear change. However, a speedo gear is but only so accurate.
If you have the stock vavle body and no aftermarket shift kits, then there is a good chance your transmission will not shift accurately. I say this because the stock computer programing and shifts are based on the stock rear end gears and the time it takes to clear certain rpms levels with those gears. Wether it be wide open throttle or partial throttle shifts. The computer sends a signal at a certain rpms to the transmission to begin a gear shift. At this point, certain electronical shift solenoids begin their work by feeding line pressure to certain pistons and clutch accessories in the transmission. Now, the idea is to get the transmission to shift by a certain target rpm which is typically red-line if you are full power on(WOT). Typically speaking, it takes the computer about 1 second to complete a shift from the time it begins the shift to the time the engagement of the following gear is complete. If you want the car to shift at lets say 6k rpms at WOT, the computer needs to begin the shift process about 1 second of WOT rpms before 6k rpms. Which with the stock rear end gears is about 1,000rpms before the target shift rpms. When you go to a steeper rear diff. gear, the motor will pass through each 1,000 rpm incriments faster than before due to the difference in gearing. The computer with stock programming however, is unaware of the gear change and therefore will have shift patern programming for the stock rear end gears. So, when at WOT with steeper gears than stock w/ stock ECU programming, the computer will still begin its shift about 1k rpms before the target shift rpms when it needs to start the shift process a bit sooner. Since it doesnt start sooner, there is a very good chance the shift will come later than needed and the motor may very well hit the rev-limiter before completeing the shift. For this very reason, you need to get the ECU flashed or a sport chip when doing a gear change in an AODE car.
I hope that helps out. Basically put, you need a chip or ECU flash when doing a gear change.
  #9 (permalink)
Old 12-20-03, 10:41 AM
Official Member
Dark Knight, that is the best explanation I have seen of how and why a rear-end gear change affects shifting of an automatic. Good job.
  #10 (permalink)
Old 12-20-03, 03:50 PM
Wasnt all that hard. I just remember what Jerry posted in his articles over at TCCOA and put it in my own words. However, I think Jerry's article would be more in-depth even than my explanation.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
