Mustang Forums at StangNet
Wheel/Tire Combos Known to fit
This is a discussion on Wheel/Tire Combos Known to fit within the MII Discussion forums, part of the Mustang II category; I have 15x8 Draglites with 4.5" backspacing on the rear of my car. With 255's, they rub the inner fender ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #126 (permalink)
Old 06-15-06, 10:53 AM
I have 15x8 Draglites with 4.5" backspacing on the rear of my car. With 255's, they rub the inner fender lips. I know I need the 5.5's, but hey these were free afterall.
  #127 (permalink)
Old 06-27-06, 10:59 AM
I am looking into buying these wheels. Revolution Classic 4 spokes. 14x6 with
4" backspace. Do you think I will be able to get away with it or will I need some thin spacers??? They are $250.00 U.S a pop plus $79.20 for a set of special sleeve wheel nuts.
http://www.sspmotorsports.com/sportwheels.html
They have some 5 spokes that look like they would fit too!
English RWD Escorts have 4 x 4 1/4 bolt pattern II
No one can say I didn't seach the world for wheels!!!!!
  #128 (permalink)
Old 06-28-06, 12:07 AM
78CobraII's Avatar
Moderator
Garage
Great find! I've looked at the Minilite (http://www.minilite.co.uk/) and Panasport (http://www.panasport.com/) wheels out of Europe a couple of times, but the price scared me away. They have a great 70's-80's sports car look like these that you found.
I don't think that the 4" backspace will get you...factory is 3.75". Its the offset that you have to be careful of.
The 15x7 Fox Mustang wheels mostly came with 12mm of positive offset. With these wheels, the MII needs about a 3/8" spacer at each wheel, maybe more if you use a 60 series tire or one wider than 225 width.
If you can get these in 5mm or less positive offset (0 is factory) and aren't going to run a really big tire, you could probably skip the spacers.
If these are essentially custom made and have to be imported from Great Britain, I'd consider a getting 5th wheel and extra center caps.
Here's some other possibilities:
Eagle Alloys (http://aewheel.com/) still advertises their Series 028, 203, 206, and 218 in 4-4.25", 15x7, 0 offset, and 4" backspacing.
Koenig (http://www.konigwheels.com/catalog_p...ID=1&ss_id=405) still makes a 15x7 wheel called "Rewind" that looks like a Minilite and is 4 lug and 0 offset, but they don't give a bolt circle, so it may be Nissan/Toyota (4-100mm?)...
Comopotive also makes a wheel like a Minilite in good sizes for us, and in 4-lug, but again no published bolt circle (http://www.usacomp.com/mlr.htm).
These Ronal "mesh" wheels would look good on a MII, but would be pushing the backspacing a bit at 9mm: http://www.ronalusa.com/wheels/ls.html
Don't forget that Centerline has a custom forged wheel line at reasonable prices: http://www.centerlinewheels.com/customs/customs1.php
  #129 (permalink)
Old 06-30-06, 03:07 PM
  #130 (permalink)
Old 06-30-06, 03:55 PM
Quote:
Originally Posted by 78CobraII
Great find! I've looked at the Minilite (http://www.minilite.co.uk/) and Panasport (http://www.panasport.com/) wheels out of Europe a couple of times, but the price scared me away. They have a great 70's-80's sports car look like these that you found. I love minilites, but I photo shopped them on my II and I didn't think they looked right. I have a 60's road race theme in mind.
If these are essentially custom made and have to be imported from Great Britain, I'd consider a getting 5th wheel and extra center caps. The 14" come with 16mm offset and 102mm Back space (4") They have a 3 pce wheel that comes in 15" that are available in any configuration, but they are something like $350.00 each!!
Koenig (http://www.konigwheels.com/catalog_p...ID=1&ss_id=405) still makes a 15x7 wheel called "Rewind" that looks like a Minilite and is 4 lug and 0 offset, but they don't give a bolt circle, so it may be Nissan/Toyota (4-100mm?)...I looked into these. I can't remember the bolt circles but, they don't come in 4 X 4 1/4" anyway
Comopotive also makes a wheel like a Minilite in good sizes for us, and in 4-lug, but again no published bolt circle (http://www.usacomp.com/mlr.htm). These come in the bolt pattern I checked before.
I called centerline for a customer and they said that they no longer build wheels with our bolt pattern
  #131 (permalink)
Old 06-05-07, 11:08 AM
MUSTANG J's Avatar
Official Member
After the Granada rotor / GM brake caliper up-grade and having the stock 8" ford Mustang II axles re-drilled to 5 on 4 1/2" these fit!
Wheel Vintiques 54 Series Magnum 500's. They are 14x7" with 4 1/2" Back space
The tires are 225/60/14" front and 245/60/14" rear. The rear has plenty of room, the front is about maximum.
  #132 (permalink)
Old 06-05-07, 01:33 PM
jeffnoel's Avatar
Why are your pictures so small?
Thanks for posting them but they really don't show much.
  #133 (permalink)
Old 06-12-07, 12:22 PM
MUSTANG J's Avatar
Official Member
  #134 (permalink)
Old 06-12-07, 01:55 PM
COBRAIIW's Avatar
Official Member
let's see if this works, I've been trying to post pictures, but I'm not too savvy at this.
Okay! I managed to get a thumbnail in!
The wheels are from a 1988 Thunderbird, 14in., with a 1/4in. spacer.
  #135 (permalink)
Old 06-12-07, 03:16 PM
Got anymore pics of that bumper?
david
  #136 (permalink)
Old 06-12-07, 09:52 PM
COBRAIIW's Avatar
Official Member
There is no bumper right now, I have a fiberglass one hanging in the garage waiting for modification.
I have to add in reinforcments, and mounting plates.
I turned another grill upside down, and cut out the turn signals to protect my radiator.
Kinda looks like it belongs there, LOL!
  #137 (permalink)
Old 06-21-07, 11:17 PM
doublecobraII's's Avatar
17" x 7's
i think the 7" wide rim is as far as it will accept in the front at least my fronts do not rub at all they have 225/50/17's on all four corners (buddy went to 18's on his camaro so he sold me these 17's (tires only) for 40 buxs already had the rims ....OK i have tryed to upload photos of my 17's i cannot figure it out HELP PLEASE
  #138 (permalink)
Old 06-23-07, 12:08 AM
3-0-II's Avatar
Official Member
Try uploading it to an image hosting site like imageshack.us or photobucket.com and then linking it
  #139 (permalink)
Old 08-10-07, 04:27 AM
78StangII2+2's Avatar
Official Member
Garage
I went with the 2005 Mustang wheel for the 6 Cyl (16 x 7) putting 205/55 x 16s on the front and 225/50 x 16s on the rear, using a 2" spacer/adapter so I could put my lacy spokes back on at any time.
Hopefully the pic will turn out. I am not sure how to do it on this site.
/paul
Cardomain Site - http://www.cardomain.com/ride/2219901
http://memimage.cardomain.net/member...01_73_full.jpg
  #140 (permalink)
Old 12-12-07, 08:24 PM
maverickwolfe's Avatar
Question
I know the stock tire was 195/70-13 but obviously that's a bit hard to come by these days so I ended up with a 185/70-13 on my stock rims.
I like the black and chrome of the stocker, so I'm just gonna clean and repaint them; but I need more meat, cuz these rubber pizza cutters ain't cuttin' it. so here's the question for you olders and wisers - How big a tire can I put on the stock 13x5.5(?) wheels?
  #141 (permalink)
Old 12-13-07, 02:21 PM
78CobraII's Avatar
Moderator
Garage
I have run as wide as a P205-60R13 on the 5.5" factory wheels, but its a smaller diameter (24"?) package than stock. Last time I checked there were several companies still offering this size. I don't think that there was ever anything wider than 195 in the 70 series 13" tire.
This 60 series tire will tend to lower your car a bit and will have the effect of increasing your rear-end numerical ratio, so you will turn more RPM's on the road. Your speedometer will be off by 5% or so at highway speed.
I found that the sidewalls on the BFG TA Radials weren't stiff enough in this size and that lead to some poor behavior in extreme manouvers. They were fine under most driving though.
Make sure that you have the 5.5" wide V8 rims though...at one point I picked up a replacement steel sport wheel in a junkyard that was only 5" wide. It probably came off of a 2.3L or 2.8L powered MII or Pinto. Otherwise it looked identical.
Oddly enough I'm looking at running P225-50R15 aftermarket wheels on my coupe which end up with nearly the same rolling diameter as the P205-60R13's! At least the sidewalls will be shorter and stiffer.
Good luck and post some pics when you get the tires mounted.
  #142 (permalink)
Old 12-13-07, 04:38 PM
MUSTANG J's Avatar
Official Member
I put 235/50/13's on the stock 5.5" II wheels!!
This is a good tire diameter tool that I use at work.
http://www.miata.net/garage/tirecalc.html
Good thread on 13" tires.
http://forums.stangnet.com/showthrea...ighlight=tires
My car with 205/60/13's front and 235/50/13's rear.
Mickey Thompson still offers wide 13" tires.
http://www.mickeythompsontires.com/s...tem=SportsmanI
Last edited by MUSTANG J; 12-13-07 at 04:41 PM. Reason: Had an additional thought;)
  #143 (permalink)
Old 06-15-08, 10:24 PM
Project 77's Avatar
I got a set of 17x9 4 lug cobra R's. The rears do not rub, but they are VERY close to the leaf springs. The fronts were another story, right up on the top of the A arms. I ordered a set of 1.25" bolt on spacers for all 4 wheels. I guess we'll see if they fit
  #144 (permalink)
Old 06-17-08, 07:37 AM
Hey Project77 you have got to post some pics without the spacers and then the spacers, front and back, please!
  #145 (permalink)
Old 06-18-08, 02:20 PM
Project 77's Avatar
Quote:
OK update...I was wrong, I ordered 1" spacers. I test fit the front with spacers and that's where it ended. Made the 17" wheels stick out past the fender by about half an inch, made the car look like a 4 wheel drive. I now have some options. stick with the 13" wheels, find a set of 16x8 Cobra R wheels. call a machine shop and see if they'll turn these spacers down by half an inch, or scrounge around for a set of chrome pony wheels. More updates to follow.
  #146 (permalink)
Old 06-18-08, 03:16 PM
why not run the 17x9 out back and some 17x8 up front. please can you post some pics.thanks
  #147 (permalink)
Old 06-18-08, 03:41 PM
Project 77's Avatar
I haven't been able to find 17x8 Cobra R wheels. I'll post up some pictures next time I venture out and fool with it, right now i'm going to call CJ ponyparts and see if they make a 17x8 silver finish Cobra R.
  #148 (permalink)
Old 06-19-08, 06:39 AM
i know my son bought some 17x8 for the front of his fox body from summit.
  #149 (permalink)
Old 06-19-08, 11:47 AM
Project 77's Avatar
I worry that 17x9 in the rear and 17x8 in the front might look funny.
  #150 (permalink)
Old 06-19-08, 03:12 PM
not really, the width of the rear fenders are wider that the front so the difference in the rim width would NOT look funny.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Post your World Product Widsor SR Head combos clarkjr 5.0 Tech 2 02-25-04 07:13 PM
