08-02-08, 04:19 PM
| | Member | | Join Date: August 2005 Location: St.Louis Missouri
These fit fine with !/2 inch spacers....235 60s on them too....if your running a bit low like I am...you must bend in the seam at the rear of the front wheelwells or itll rub your tires....taller springs are no problem though.....and slight clearancing of the wheelwell lips front and rear.
02-21-09, 12:37 PM
| | Member | | Join Date: February 2009 Location: Newport News, Virginia
My 77 Ghia sits on 3.5 x 15 w/155/80R15 in the front and 7.5 X 15 w/265/50R15 in the rear all tire are BFG T/a's. The wheels are all Centerline Convo Pro's. On race days the rear end wears 275/50R15 Nitto drag radials.
I have a pair of 7.00 X15 Convo pro's that will eventually go on the front when I'm not at the track. |
02-24-09, 10:19 AM
|  | Member | | Join Date: March 2004 Location: Boston, MA
| | | 15x8 Draglites
Have a line on (4) 15x8" draglites with 4.5"BS off a fox.
Will these fit front and back with the right tires?  |
02-25-09, 12:08 AM
|  | Official Member | | Join Date: December 2005 Location: Williamsburg, Iowa
Back on page 4, there is this little bit of info. Doesn't help with the front though. Quote:
Originally Posted by barrylee66 I have weld draglites 3 '' on front and 8'' with 4.5 inset with 265-50-15 radials
these fit perfect rolled lip because I do it on all my cars with fat tires it only took one time to learn. I tried 275-50-15 on 5.5 inset off my fox body stang they wont work without spacers 1'' by the way you can not run spacers at any nhra track as they are not allowed. | |
02-27-09, 02:56 PM
Has anyone tried a 15x8 with 4.5 backspacing with a 295/50 on the rear? I kind of want to do this, but don't want to blow a wad on tires and not be able to use them. If they wouldn't work, I will settle for 265/275's, just want to increase the contact patch for the rear as much as possible without too much modification. I know I will have to roll the fender lip, but no more mods than that. Anybody's input is greatly appreciated! Thanks!! |
03-02-09, 10:09 AM
| | Quote:
Originally Posted by macstang2 My 77 Ghia sits on 3.5 x 15 w/155/80R15 in the front and 7.5 X 15 w/265/50R15 in the rear all tire are BFG T/a's. The wheels are all Centerline Convo Pro's. On race days the rear end wears 275/50R15 Nitto drag radials.
I have a pair of 7.00 X15 Convo pro's that will eventually go on the front when I'm not at the track. | I Fubared with the size on the rear rims. They are 8.5 x 15 centerline convo pros with 3.375in backspacing.
Were's the darn edit button anyway? |
04-06-09, 04:49 AM
| | Member | | Join Date: March 2005
| | Quote:
Originally Posted by macstang2 I Fubared with the size on the rear rims. They are 8.5 x 15 centerline convo pros with 3.375in backspacing.
Were's the darn edit button anyway? | Got any pics of your car? would love to see what it looks like with those wheels/tyres on! Cheers, Dave. |
04-20-09, 02:25 PM
|  | Moderator | | Join Date: July 1998 Location: Birmingham, AL
| | Quote:
Originally Posted by LILCBRA Has anyone tried a 15x8 with 4.5 backspacing with a 295/50 on the rear? I kind of want to do this, but don't want to blow a wad on tires and not be able to use them. If they wouldn't work, I will settle for 265/275's, just want to increase the contact patch for the rear as much as possible without too much modification. I know I will have to roll the fender lip, but no more mods than that. Anybody's input is greatly appreciated! Thanks!! | I would purchase or borrow a tool like this one: Percy's High Performance, Inc.- Wheel Rite
Or talk to a tire/wheel supplier that has one.
You will need to know the backspacing, offset, and mounted tire width to make a good guess as to fit. |
04-20-09, 02:33 PM
Yet another Fox wheel that might be useful: SC Saleen Replica Style Wheels by Wheel Replicas
The size closest to usefulness for us is:
Size Pattern Offset / Backspace Lip Depth
17x8 4 x 4.25 +19mm / 5.20" 1.04"
Of course you have to have a way to deal with the poor offset...spacers or wider rear axle, etc.
Its nice to see that the Fox guys are still getting new wheels anyway. |
06-02-09, 06:31 AM
| | Official Member | | Join Date: June 2009
| | Quote:
Originally Posted by insanemach1 well ihave looked all over for the 1/2 inch bolt in spacers but all i can seem to find is 1 inch anyone know if i could use a 1 inch bolt in with the 16 inch pony rims for the front was gonna use tire size 205/50/16 not sure if they would fit or not. not sure if i mentioned it earlier or not but this is for a 4 lug | I have 1inch spacers on mine I have used ponys with 245s all around, it rubbed in the front when hitting bumps. I was just trying them. I ended up using turbines 225 front and 235 rear. |
06-02-09, 06:57 AM
After reading all of this I am confused. I wanted to get a set of rodlites for the rear with drag radials. I planed on 15X7 with 3.5 back spacing I thought that was the ticket. I did want the 15X8 but I thought the 4.5 back space would not work you guys are saying it would? I didnt want to use spacers with the drag wheels. I also could not see the pics posted there was a error. |
06-02-09, 11:26 AM
I've seen several folks here and on other boards using 15" x 8" rear wheels on their MII's, but I would hesitate to it to anyone due to differences in car usage, suspension setup, tire dimensions, etc.
I highly recommend a lot of measurements anytime a expensive tire/wheel combo is to be purchased, especially in a situation where the fit is marginal. I would either purchase/rent the Percy's tool above, or build something similar using the dimensions of the wheel/tire combo and some cardboard before purchase.
In reference to adapters/spacers, I have heard H&R recommended for years as the best quality in the field: WHEEL SPACERS & Alloy Wheel Spacer Kits at Performance Alloys.com
This guy also seems to have a good product, and he has a picture of a failed adapter that mmakes you consider the posiblity of failure: WheelAdapter.com is your number one source for wheel adapters, wheel spacers, used wheels, and wheel studs.
I guess the moral is don't use them unless you just have to, use really high quality parts if you have to (both the adapter/spacer and wheel studs), don't use them in high stress situations like racing, and do follow the recommended inspection and re-torque schedule. |
06-02-09, 05:49 PM
The wheel tool is a great idea thats probably what I will do before I buy the new rear rims every car is alittle differant. | | Thread Tools | | | | Display Modes | Rate This Thread | Linear Mode | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | | |
