Mustang Forums at StangNet
Wheel/Tire Combos Known to fit
This is a discussion on Wheel/Tire Combos Known to fit within the MII Discussion forums, part of the Mustang II category; I thought it would be helpfull to have a list of combos that users have personally tried and know work ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-19-03, 12:49 AM
77sleeper's Avatar
GO BUCS!
Beware all IIs are slighly different and may have different fitment issues than yours
Fox 4-cyl polyglass with 185-70R14 slight rub @ full lock
Fox 14x6 steel wheels with 205-60R14 no rubbing
  #2 (permalink)
Old 09-19-03, 08:03 PM
parthos's Avatar
14x7 rim 4 inch backspacing, 26x9.5-14 tire this is only for the rear
  #3 (permalink)
Old 09-22-03, 07:38 PM
kcobra302's Avatar
finally found the receipt for my wheels.
centerline convo pros
rear 15x7 3 3/8 backspacing with 235-55-15
front 15x4 1 3/4 backspacing with 185-60-15
fronts are very close to the fender flare portion of the chin spoiler - there are a few rub marks. rears fit perfect. my king is at "factory" ride height. i can send pics if anybody needs them.
when i had the factory king cobra wheels on the car
13x5 1/2
rear 205-70-13
front 195-70-13
  #4 (permalink)
Old 09-23-03, 05:11 PM
pig 'rassler
195/70R13 on 13x5.5 OE wheel
225/50-15 on 15x7, 4" backspace ("0" offset)
  #5 (permalink)
Old 09-26-03, 06:40 AM
2muchtime's Avatar
245/ 60 /14 7in rim 3 1/2 backspacing, rear only..
lays down some thick marks, will have pics this weekend..
  #6 (permalink)
Old 10-15-03, 04:32 PM
Power Surge's Avatar
Front: Weld Draglites, 15x3.5, M/T Sportsman fronts, 26x7.5-15s
Rear: Weld Draglites, 15x6 with 3.5 backspace, M&H Racemaster G60/15 Muscle Car Drag DOTs (26.2 tall, 8" tread, 11" section width)
This combo clears all factory parts, and also clears SSM traction bars.
For those who are into traction .
  #7 (permalink)
Old 11-04-03, 09:22 AM
kcobra302's Avatar
here are a few photos of the rear tires. they are from last fall.
  #8 (permalink)
Old 11-04-03, 09:23 AM
kcobra302's Avatar
one more
  #9 (permalink)
Old 11-24-03, 04:17 AM
74stang2togo's Avatar
Is there a verdict on 15x7 "Turbines" off of an 87-93 Mustang GT?
  #10 (permalink)
Old 11-24-03, 08:58 AM
1badII's Avatar
Official Member
Quote:
I know someone who's running 15" turbines with 225/50R15's on his II with no problems.
  #11 (permalink)
Old 11-26-03, 02:16 AM
What is the largest wheel dimensions that will fit on the front and rear of the II that is still feasable for daily driving? Also I found a set of Wheels 13x7 4" back spacing. Do you think these would work with my 74 ghia?
  #12 (permalink)
Old 12-08-03, 11:45 PM
Official Member
I picked up some 14" steelie rims off of an 84 LTD (paint them gloss black add trim rings and chrome lugs with white letter tires, looks good), put some 245/60/R14's on, a slight rubbing on hard turns, keep in mind real hard turns and its very slight. Front rims are next, I'll let you know what I turn up.
Chris
  #13 (permalink)
Old 12-19-03, 07:23 PM
15x7 Turbines with 215/70/R15s fit great on the rear (fills the wheelwell up nicely, no rubbing) but they're just a little bit too wide for the front (some rubbing with the wheel turned hard).
(Just put mine on my II this week)
  #14 (permalink)
Old 12-24-03, 01:26 PM
HaveII's Avatar
What is the backspacing on a Turbine? How much space do you have between the back of the tire and your leaf springs?
  #15 (permalink)
Old 12-27-03, 04:02 PM
MUSTANG J II's Avatar
Usually when dudes put fox Mustang wheels on a II they use 1/2" wheel spacers for the front.
  #16 (permalink)
Old 12-29-03, 11:22 AM
Quote:
I'm not sure what the backspacing is, but it looks like there's plenty of room between the springs and tires (a few inches I beleive, the car's at home and I'm at the library right now, so I'm not sure).
I'd use wheel spacers up front, but I keep hearing so much flack about using them that I think I'll just live with having a little wider turning circle.
  #17 (permalink)
Old 12-31-03, 02:29 PM
76_Cobra_II's Avatar
Official Member
{{{15x7 Turbines with 215/70/R15s fit great on the rear (fills the wheelwell up nicely, no rubbing) but they're just a little bit too wide for the front (some rubbing with the wheel turned hard).}}}
The largest tires you can run up front with the turbines is 205/60/15 with very little rubbing. The largest in the rear is a whopping 235/60/15.
I currently have 225/50/15's all the way around (Im the one that 1BADII was talking about) they dont rub unless you Lock the wheel. I just dont like how thin the tires look.
  #18 (permalink)
Old 01-14-04, 11:07 PM
The 78 that I had I ran the big and little combo
15 x 3.5, and 15 x 8.5 w 4 7/8 back spacing... centerline autodrags
The rear wheel wells had to have the inner lip rolled up, and that was it.
I had the Mickey Thompson sportsman pro's 26x10.5 tires. Fit great
Gawd I miss that car.
  #19 (permalink)
Old 01-18-04, 10:02 PM
Official Member
fatties
It would be nice if you had some pics of the back end of that. Maybe some wheel well snap shots. I'd like to see how those fit.
Dan
danimal@imaxx.net
  #20 (permalink)
Old 01-21-04, 03:25 PM
HaveII's Avatar
Now we are talking! I see alot about 225 and 235 60 x 15's. I know you can fit alot more meat than that. I have 245/60/14's with lots of room to spare on the inside. I would like to get a 26x10.5x15 tires under mine. How tights is a 10.5" tire? (if you lower air pressure at the strip, car sit level, etc.) Did they stick out any? I have no beefs about triming up the lips on the wheel wells, but I will need to leave enough to hold the trim on (I will relocate trim screws if needed). Otherwise I would roll them.
I would like to use a Weld draglites or a Crager Superlites which have backspacing in 1" increments. 3.5, 4.5, and 5.5 on the 15x8's in 4 lug. Any chance the 5.5" backspacing would fit? Sounds like too much, but 4.5" sounds like it would be giving up some space even if we are only talking about 3/8". Who else has put some fat tires on their II's? Strlegal, any pictures? Didn't Partho stuff some good size meat under his? Where's the beef?
  #21 (permalink)
Old 01-24-04, 01:23 PM
Sorry, but unfortunately I don't have any pictures of just that area. Actually I don't have any real pictures of the car. I was able to copy a picture from a video I had of it. The picture is in the picture tread list, near the end. Oh, and the measurements on the sportsman pro tires are a little miss leading, they actually measure the same as a 26 x 8.5 slick. When I took the sportsman pros off, I replaced them with 245/65/15's and later wished I had went with the 255's, but super shops was out of the 255's at the time. Yep I said super shops... its going on 8 years since I had that car.
The set up I had in the car a 9" lincoln versailles rear which is the same length as the stock 8" I took out, and the wheels were 15 x 8.5 centerline autodrags with 4 7/8 back spacing. No clearance issues with the inner fender well. and no the tires did not stick out. Now my car did stand a little higher in the rear them most, but that was cause I replaced the springs with a new JC whitney set, no air shocks. And the way I found that the inner lip had to be rolled, the day I put the tires on, I had about a 1/4 tank of gas in it, I filled it up on the way home and they rubbed.... so my wheels did go into the finder wheels. As for the wheel off set, better to fudge with to much then not enough, you can always add spacers. and if you want to see a car with some meats on it, when you see my car, I listed 2, the green one has some real meats on it.
  #22 (permalink)
Old 03-13-04, 04:54 PM
Official Member
Quote:
does anyone know where i can get a set of those 1/2 inch spacers i have been looking all over, i got a set of pony rims from a 92 stang i would like to put on my car. only thing i can find is the 1/4 inch slip ons which i am afraid to use
  #23 (permalink)
Old 03-14-04, 12:09 AM
77sleeper's Avatar
GO BUCS!
search posts by me, I started a thread about 3-4 months ago about them in here
  #24 (permalink)
Old 03-14-04, 11:43 PM
These don't fit very well 255/50/17's on 17X9's They touch if you look at the car too hard. Just put them on to see what it would look like.
  #25 (permalink)
Old 03-15-04, 03:59 PM
Official Member
Quote:
well ihave looked all over for the 1/2 inch bolt in spacers but all i can seem to find is 1 inch anyone know if i could use a 1 inch bolt in with the 16 inch pony rims for the front was gonna use tire size 205/50/16 not sure if they would fit or not. not sure if i mentioned it earlier or not but this is for a 4 lug
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Post your World Product Widsor SR Head combos clarkjr 5.0 Tech 2 02-25-04 07:13 PM
