View Single Post
  #22 (permalink)
Old 01-29-04, 04:56 PM
Wikkdgt's Avatar
Wikkdgt Wikkdgt is offline
Official Member
I actually bent my front driver side pinch weld. I didn't use the factory jack, but used a floor jack in the same spot the manual states to place the scissor jack. Mine bent outward due to the weight of the vehicle and because I used the wrong jack. When it bent outwards it also pushed out my rocker panel about a 1/4 of an inch. Big time eyesore. Anyways I had to bend it back with some pliers and then removed the bent plastic pushpin that holds the panel on and replaced it with a nut and bolt. Now you can never tell it even happened. I won't put the floor jack there anymore. I get a 2x4 block and put it on the floor jack and push it further under the car to find my jack point. No problems anymore.
