Mustang Forums at StangNet
Update loose steering
This is a discussion on Update loose steering within the 4.6 Tech forums, part of the 4.6L Mustang category; I have isolated the loosenes, Now what? The problem seems to be where it attached to the Rack and pinion. ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 10-18-03, 12:48 PM
I have isolated the loosenes, Now what? The problem seems to be where it attached to the Rack and pinion. I moved the steering shaft it feels solid from the steering all the way down to the rack and pinon attaching bolt. It is not loose at the attaching point.
Let me try and describe it. When you move the steering shaft sure enough you can feel the play in what feels like inside the rack mounting point before it engages. Do I need a new rack and pinion? Could it Be my steering gear? I looked at the Manual, How do you adjust the steering gear?
As aways thanks for all
  #2 (permalink)
Old 10-18-03, 01:16 PM
KISSEL's Avatar
Official Member
I have the same problem with loose steering on my 01. Left and right, maybe an inch or so. Ford didn't give me an answer to this one, so I'm stumped as well.
  #3 (permalink)
Old 10-18-03, 01:21 PM
Thanks for getting back to me
Quote:
so you took it to the dealer? and they didn't know what to do? If you figure it out let me knw, I will do the same
  #4 (permalink)
Old 10-18-03, 01:25 PM
KISSEL's Avatar
Official Member
Yeah, I took it in a while back. They said that the "play" is normal. I think they didn't want to fix it. I didn't push the point. But I know that it is not normal because it did not do that before.
  #5 (permalink)
Old 04-29-04, 09:38 AM
LByellowStang's Avatar
edit: nm
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
