12-28-03, 11:12 AM
|  | I AM the random post master...bow down | | Join Date: May 2003 Location: Daytona Bch, FL
| | | Time to play everyones favorite game
Take a guess at what my HP and Torque should be with my new combo. Also what should I be at in the 1/4 mile? My car still has the stock 2.73's in it
TFS Twisted Wedge Heads, TFS Stage 1 Cam, Edelbrock Performer 5.0, FMS 65mm TB, BBK Long Tubes, O/R H-Pipe, Flowmaster 40 Series 2 Chamber, Pro 5.0 Shifter, 17x9 2003 Cobra R 245/45/17 Nitto 555's up front, 275/40/17 Nitto 555R's out back |
12-28-03, 12:04 PM
|  | Founding Member | | Join Date: March 2002 Location: Overland Park, KS
I'll keep an eye on this one, as my h/c/i is the same, and my exhaust is similair.
J |
12-28-03, 01:31 PM
up...
anyone want to take a guess??? |
12-28-03, 03:11 PM
| | Founding Member | | Join Date: September 2002 Location: Arkansas
| | Quote: |
Originally Posted by 1105 Take a guess at what my HP and Torque should be with my new combo. Also what should I be at in the 1/4 mile? My car still has the stock 2.73's in it
TFS Twisted Wedge Heads, TFS Stage 1 Cam, Edelbrock Performer 5.0, FMS 65mm TB, BBK Long Tubes, O/R H-Pipe, Flowmaster 40 Series 2 Chamber, Pro 5.0 Shifter, 17x9 2003 Cobra R 245/45/17 Nitto 555's up front, 275/40/17 Nitto 555R's out back | I want to guess between 285-300hp |
12-28-03, 04:57 PM
|  | Official Member | | Join Date: February 2003 Location: San Diego
12-28-03, 05:50 PM
|  | Official Member | | Join Date: December 2003 Location: Chicago, IL
295rwhp. Im about to to buy the exact same combo as u except with the trick flow intake.
Hope to see good numbers either way.  |
12-28-03, 05:57 PM
| | Official Member | | Join Date: December 2002 Location: Massachusetts
i say 285 rwhp. Do you have pulleys? For tracks times im gonna guess 13.7's.. The 2.73's will kill you on the track. |
12-28-03, 06:29 PM
|  | bubb rubb says: "woo woooooo" | | Join Date: September 2002 Location: Syracuse, NY
12-29-03, 10:39 AM
| | Quote: |
Originally Posted by yellow1995Cobra i say 285 rwhp. Do you have pulleys? For tracks times im gonna guess 13.7's.. The 2.73's will kill you on the track. | 280-290rwhp seems like the most common response and no I don't have any pullies on my car. I would have thought that I'd be somewhere around 13.4 or 13.5 with the 2.73's then a high 12 with 3.73's  after I get a new balancer and a few other little things fixed, I'm getting a rearend rebuild kit and some 3.73's to put in. |
12-29-03, 11:03 AM
| | Founding Member | | Join Date: March 2002 Location: Ft. Lauderdale, FL
| | Quote: |
Originally Posted by 1105 280-290rwhp seems like the most common response and no I don't have any pullies on my car. I would have thought that I'd be somewhere around 13.4 or 13.5 with the 2.73's then a high 12 with 3.73's  after I get a new balancer and a few other little things fixed, I'm getting a rearend rebuild kit and some 3.73's to put in. | the guy i bought my combo from ran a 13.2 with it.
gt40 intake (ported lower)
twisted wedge heads (heavily ported)
trickflow stage 1 cam
scorpion 1.6rr
bbk 70mm throttle body
fms unequal shorties
bassani o/r x-pipe
flowmaster 2 chamber cat back
3.55 gears |
12-29-03, 05:47 PM
| | Quote: |
| I would deff get some pullies as well, they are cheap and proven HP adder on our cars.
Only reason i said 13.7's was cause when i had 2.73 gears (all the bolt ons and cobra mani) on a 100 shot all i could manage was 13.8's on street tires. The 2.73 gears just plain blow. Once i went to 3.55's i was running 13.9's without the juice but i was on nitto's which was also a big help.
Theres alot of other factors when comparing two totally diff setups.. i guess the only way to find out is to run the car. |
01-01-04, 10:34 PM
|  | Official Member | | Join Date: May 2003 Location: Bellevue, WA (yes, the land where every 16 year old kid drives a brand new BMW!)
let me know about pulleys... I have a set I just got, but decided not to use them as I already have them apparently
-ASP Aluminum pulleys... brand new, never used, black to match the others... | | Thread Tools | | | | Display Modes | Rate This Thread | Linear Mode | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | | |
