Mustang Forums at StangNet
MSD Distrib w/ steel gear & FMS cast iron cam, OK? or NO?
This is a discussion on MSD Distrib w/ steel gear & FMS cast iron cam, OK? or NO? within the 5.0 Tech forums, part of the 5.0 Mustang category; i just recieved my MSD distributor from my parts guy. and its got a warning tag on it. it says ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 01-12-04, 10:09 PM
i just recieved my MSD distributor from my parts guy. and its got a warning tag on it. it says the distributor gear is made of billet steel. and not to use it with iron cams etc....
well when i bought my car. it already had a ford motorsports 'b' cam in it?
and the receipt from summit showed the part #. i looked it up. its a cast iron cam.
i emailed MSD's tech address. asking. no reply. been a couple days too.. and i really need to get this done NOW on my 2 days off.
ive been told its okay to do, because its a ford cam. and ive also been told no, buy a iron cam gear?
can somebody clear this up for me please. thanks in advance
derek
  #2 (permalink)
Old 01-12-04, 11:53 PM
somebody must know something? bump
  #3 (permalink)
Old 01-12-04, 11:58 PM
Official Member
I just threw my Pro billet MSD in with a E-303 over 2 years ago and never had a problem. I pulled it last month and the gear looks great. I assume you are in the same boat and would tell you tp go ahead and stick er' in. The gear on the B cam is the same as the stock cam, thats why you can throw a cam in without changing the distributor. I dont see why it cant be done the other way around, ya know. Just my $.02
  #4 (permalink)
Old 01-13-04, 04:38 AM
EMW150's Avatar
All hydro-roller cams have a steel gear. Stay with the one you have. The only time you would need to switch would be if for some reason you were running a flat tappet cam or a solid roller. If it was an early style non-efi MSD distributor, they need a steel gear installed because they come with cast.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gears Install Write-up? forrealb50 5.0 Tech 11 12-18-03 09:19 PM
