01-31-04, 04:03 PM
| | Member | | Join Date: January 2004
| | | pictures and video of my sct dyno tune of my blown bird
I went ahead and got my mildly modified bird dynotuned by sct. These are my mods aed rev 1 kit, headers, dual exhaust, 36#hr injectors, 90 mm L maf, 75 mm tb, 01 pi engine and other minor mods. I initaly started at 301 hp and 315 ftlb of torque when I was all said and done I picked up 27 hp and 49 ftlb of torque for a total of 328 hp and 364 ftlb at the wheels. I made over 300 ftlb of torque at the wheels from 1800 rpm to 5500 rpm. I can punch it rolling 40 mph and roast the tires. What do you think? MY dyno right click and save |
01-31-04, 06:06 PM
|  | cantthinkoftitle | | Join Date: April 2002 Location: Ya, here's to The Drunken Clam boys, where they don't ask for proof of age and neither do I...
| |  Sleepers  |
01-31-04, 06:49 PM
|  | Official Member | | Join Date: September 2003 Location: Newark, CA.
edit: ok, I'm lame, I didn't even read the entire subject of this post. nm
Good numbers by the way, is that an Allen Supercharger?
01-31-04, 07:34 PM
| | | my blower |
01-31-04, 07:38 PM
|  | Founding Member | | Join Date: June 2002 Location: Chicago, IL
Congrats, that is one bad bird. My buddy use to have a 91 SC, with all sorts of mods too. But I think yours takes the cake. |
01-31-04, 07:50 PM
I hate to say this but I love embarasing the 5.0 and 4.6 and camarows/firebirds and ss models. My favorite races were when I raced a supercharged civic and a turbo charged civic they each put 10 k into the engine and I totaly smashed and destroyed them. They thought they were bad because they were runing high 13s and mid 14s |
01-31-04, 08:27 PM
Just make sure you stay away from modified camaro/firebirds. They are fast from the factory, but once they start to mod, they are hitting corvette territory. |
01-31-04, 09:00 PM
|  | Official Member | | Join Date: October 2003 Location: Acworth, GA
Cool, post some pics soon!  I wish I could do that to my T-bird, but it's too freakin old  |
02-01-04, 02:13 AM
| | Official Member | | Join Date: January 2004 Location: Cary, NC
| | Quote: |
Originally Posted by Sleepy1 Just make sure you stay away from modified camaro/firebirds. They are fast from the factory, but once they start to mod, they are hitting corvette territory. | Are you kidding me? A late-model Firebird/Camaro equipped with an LS1 is beyond corvette territory WITHOUT modifications. You better check yourself. |
02-01-04, 02:20 AM
|  | the polarbear conservation corps protects a polarbear homie straight outa' compton because polarbears love klondike bars | | Join Date: October 2003 Location: Portland, OR
very cool  |
02-01-04, 03:58 AM
|  | Stay thirsty my friends | | Join Date: December 2001 Location: SN Moderator: Orlando, Fl.
02-01-04, 10:33 AM
| | | pics of the car and blower |
02-01-04, 11:05 AM
|  | Official Member | | Join Date: July 2003 Location: New york
| | Quote: |
Originally Posted by oldskooler79 Are you kidding me? A late-model Firebird/Camaro equipped with an LS1 is beyond corvette territory WITHOUT modifications. You better check yourself. | I think you should do some better research |
02-01-04, 02:54 PM
|  | Founding Member | | Join Date: July 2002 Location: In the garage, On the floor.
I think he was being sarcastic... LS1's NEVER LOSE.
GREAT CAR!
Wish you had more detailed shots of the main components... aka S/C'er. |
02-01-04, 04:54 PM
| | | you asked for it.
pictures of my blower and other mods and tweeks that I have done or had done.
It is a nightmare to install headers on the bird. I had to drop my K member and lower the engine down below the frame rails to bolt them up then jack up the motor.
The old iron logs
I installed a sc 145 spedo and a sc boost vaccum gauge losing volt meter for a volt light big deal
magnum powers ported blower
The K member out and in the drive not bad to remove hard to install
coated to reduce heat transfer.
passanger side install
It is a real pain to install but aint they purdy
custom intake tube that I made
opening up the elbow for a 75 mm throttlebody it was 67 mm check bottom picture.
opening up the blower inlet
ported for pi heads
ported manifold
very tight.
It is sure tight and a real pain to change a belt or tighten the alt
ported intercooler not shown
before I ported it
Picture of front with heat exchanger while enlarging the holes in bumper bumper cover removed 28000# transmission cooler top center.
picture of the modified intercooler. I had the center inlet opened up for 3/4 inch hose for more coolant flow and to quickly reduce the tempetueres of the air charge tempeture if you look close at the manifold you can see a picture of the lightning air charge tempeture sensor. It is there if the act gets to hot it will pull timing and add fuel to prevent detonation.
02-01-04, 05:40 PM
Not bad.
Although, if you ever get the chance, you should clean those ports up a tad. I'm not sure what technique you have but, do you use flap wheels? I've noticed that using flap wheels, a wire brush, and a cotton wheel w/ some metal polish works out well. It smooths out the the ports to ap oint where they're almost completely smooth w/ no rough edges.
Also, if you find a small 3M flap wheel, that'll do wonders for making the ports nice and even. |
02-01-04, 05:50 PM
nice pictures  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
