Mustang Forums at StangNet
Need help with SN95 wheel hub bearing removal
This is a discussion on Need help with SN95 wheel hub bearing removal within the 94-95 Tech forums, part of the 5.0 Mustang category; I'm in the middle of a SN95 Cobra brake converion on my 89 notch. I am sand blasting all of ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 02-02-04, 12:16 PM
I'm in the middle of a SN95 Cobra brake converion on my 89 notch. I am sand blasting all of the parts I got from the bone yard to knock the rust off before powder coating. I wanted to get some tech advise on the wheel hub bearings.
* Are they pressed in?
* Can I use a large socket to tap them out?
The bearings appear to be in good condition, but I figured for the money I could replace them. Any tech advise on this would be appreciated. I just need to get them out so I can finish sand blasting and get all of my parts off to the powder coater.
  #2 (permalink)
Old 02-02-04, 02:47 PM
RIO5.0's Avatar
GoldMember
I may be wrong here?? but I believe you have to buy the entire hub to replace that bearing....
  #3 (permalink)
Old 02-02-04, 04:48 PM
Thanks! I have been doing some research and this is the same answer I keep getting. This is why I have loved all of my Ford's.
  #4 (permalink)
Old 02-02-04, 04:53 PM
rudeone707's Avatar
GoldMember
the front hubs are a single unit, the bearing are pressed in. The bolt holding it in is is a 35mm and is torqued at 280 ft lbs i think.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need help with SN95 wheel hu bearings shallchr 5.0 Tech 2 02-02-04 04:53 PM
help finding front wheel bearing assembly jokernj1 SVT Tech 3 01-27-04 02:22 PM
Gears Install Write-up? forrealb50 5.0 Tech 11 12-18-03 09:19 PM
