Mustang Forums at StangNet
C4 tranny question
This is a discussion on C4 tranny question within the MII Discussion forums, part of the Mustang II category; Did Ford shorten the shifter linkage that is attached to the C4 between years on the Mustang II? I noticed ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 155,000 Members!!
Reply
  #1 (permalink)
Old 04-18-04, 06:59 PM
CanadianCobra's Avatar
Official Member
Location: I'd love to settle down if I could afford it.
C4 tranny question
I noticed after I installed a rebuilt tranny I got from a II parts car that the inside shifter didn't match up to where Drive, Neutral, Park, etc should be. The new throw pattern seems to be shorter. After trying to figure out the problem, it seems that the shifter linkage on the tranny itself is about 3/4" smaller then the original I had.
Since both transmissions are from IIs, I thought they would be the same.
So, did Ford create a shorter throw for our cars?
  #2 (permalink)
Old 04-19-04, 04:18 PM
Mstng2's Avatar
There should be a slider at the end of the shifter linkage bar. You loosen the end and you have 2-3 inches of movement for adjustment. Is yours not set up this way??
  #3 (permalink)
Old 04-20-04, 01:20 PM
Official Member
I forgot to mention that I have been playing with the slider on the linkage bar; and, I've been adjusting the actual shifter in the car to try and make something work.
No matter what I do, the shifter throw pattern seems to be at least 1/2" shorter then the original.
Even on the metal shift pattern that requires the driver to use the button on the shifter to go into reverse is off. When I set up the slider linkage so Park is in the right position, the low-gear on my tranny will be where Second is supposed to be.
  #4 (permalink)
Old 04-22-04, 09:37 AM
75stang302's Avatar
this is the proper procedure for adjusting the shifter. loosed the nut where the shift rod attaches to the lever on the transmission. place the shifter in the car in low possition then place the lever on the trans to low and tighten the nut
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
tranny question a885.0 5.0 Tech 2 02-02-04 06:48 PM
