Mustang Forums at StangNet
Switching to Synthetic Oil
This is a discussion on Switching to Synthetic Oil within the 4.6 Tech forums, part of the 4.6L Mustang category; Aight guys, my car is a 2001 w/ 364?? miles and its time for an oil change. Anyway I know ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 04-28-04, 04:28 PM
BigPonyMan's Avatar
Aight guys, my car is a 2001 w/ 364?? miles and its time for an oil change. Anyway I know a lot of guys use synthetic so I figured I'd switch over to that, but I've heard that if you want to do that you have to get all the regular oil flushed out of the engine. Is this true, that you can't mix synthetic w/ regular? And also, what brand and grade of oil is everybody using?
  #2 (permalink)
Old 04-28-04, 04:33 PM
bdcardinal's Avatar
tree hugger
mobil 1 5w-30 with a motorcraft FL-820S filter. you dont have to flush it, mobil 1 is compatable with all dino oils. just change your oil like you would normally, put in the mobil 1, and next time you change the oil almost all of the dino oil will drain out.
  #3 (permalink)
Old 04-28-04, 06:22 PM
Go HoTO!'s Avatar
Official Member
Man is this thread going to open a can of worms when it comes to synthetic oil choices, however, Mobil 1 is a good choice. I use it.
let you car break in properly, then just start using it. Change every 5,000 miles to avoid warrenty issues. 3,000 mile intervals is a waste of money.
BTW, I am a chemiical engineer and my best friend works for an oil additive company (the world's largest). He started in R&D. The biggest advantage of synthetic oil over mineral oil is that it will extend the time between major engine overhauls. Don't believe anything else.
I have three vehicles in my driveway. I use it on my Suburban, because I will keep it for 150k + miles and on the Mustang because I only change the oil twice a year anyway. My primary car, 2002 Intrepid, I use mineral oil because I put 50K miles on it at year. Change every 6,000 miles and get rid of it just before it hits 100k. So how you drive your car and how long you plan to keep it makes a difference.
  #4 (permalink)
Old 04-29-04, 03:00 AM
You shouldnt have any issues, I personally recommend Mobil 1 5w30.
If you want your motor to last, use synthetic or at the very least a blend, end of discussion Dino oils only should be used until the motor is broken in IMO!
  #5 (permalink)
Old 04-29-04, 09:16 AM
Official Member
BPM, time for an oil change.
Use Mobil 5w-30, and keep the oil full.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Synthetic Oil Question claytucc3 4.6 Tech 133 10-04-07 11:47 AM
what weight of synthetic gear oil/transmission fluid/ engine oil? IndyBlk5.0 5.0 Tech 9 02-20-04 08:47 PM
synthetic oil jcp123 Classic Tech 9 01-27-04 11:43 PM
