Mustang Forums at StangNet
351W .30 over bore = ?
This is a discussion on 351W .30 over bore = ? within the MII Discussion forums, part of the Mustang II category; Hey here one for the engineers out there and High perfomance engine guys/gals! I am going to put the displacement ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 153,000 Members!!
Reply
  #1 (permalink)
Old 05-14-04, 12:02 PM
Mstng2's Avatar
Hey here one for the engineers out there and High perfomance engine guys/gals! I am going to put the displacement of the engine on the side of my cowl scoop when it's finished. It's a 351W bored .30 over. Does anyone know or can calculate the actual displacement of the engine for me?? I'm guessing around 368 or so but would like to be specific and have custom graphics made for it.
THanks in advance!
  #2 (permalink)
Old 05-14-04, 12:30 PM
cobraii351's Avatar
A .030 bored 351 is 357cid.
Tim
  #3 (permalink)
Old 05-14-04, 01:45 PM
Power Surge's Avatar
A 351 bored .030 over will give you about 5 extra inches. So you'd wind up with a 356. Just for reference, a 302 would go to a 306, and a 460 would go to a 466.
  #4 (permalink)
Old 05-14-04, 03:48 PM
Windsor II
and a 351W bored .060" over will give you 362ci of hot running, thin cylinder wall, overheatin' fun
  #5 (permalink)
Old 05-14-04, 03:55 PM
jeffnoel's Avatar
Ditto on the 356.
  #6 (permalink)
Old 05-14-04, 08:11 PM
Blue Thunder's Avatar
Official Member
3.5 stroke x 4.030 bore rounds up to 357 cubic inches. (unless you remove all floating points, of course, which is against standard mathematical rules)
You actually gain more cubic inches from boring a motor with a longer stroke than you do by boring a motor with a shorter stroke, but it's not usually a big difference.
If you increase the bore of a motor by .030" which has a 2" stroke, you will only gain 3 cubic inches of displacement. While boring a motor by .030" which has a 5" stroke will yield an increase of 7 cubic inches. (rounded up, when applicable)
Of course, that difference, while remaining proportionately similar, becomes far more apparent(and valuable from a performance perspective) when you further increase overbore:
2" stroke x +.100" = +11 cubic inches.
5" stroke x +.100" = +25 cubic inches.
By the way, why not take a jab at the imports and put 1.9L (x3) on the cowl?
  #7 (permalink)
Old 05-14-04, 08:17 PM
77sleeper's Avatar
GO BUCS!
AND more compression too
  #8 (permalink)
Old 05-14-04, 10:09 PM
zwhitr's Avatar
http://www.edelbrock.com/automotive/math.html
Formula for CID (cubic inch displacement)
CID = NUMBER OF CYLINDERS x SWEPT VOLUME
Note: CID = N x 0.7854 x bore x bore x stroke (all in inches)
Example: What is CID of a V8 with a “30 over”, 4 inch bore and 3.48 inch stroke?
CID = 8 x 0.7854 x 4.030 x 4.030 x 3.48 = 355 cu. inches
or you could use Volume = Pi X r(squared) X H
About Compression Ratio
Formula for CR
CR = COMPRESSION RATIO = CYL. VOLUME @ BDC ÷ CYLINDER VOLUME @ TDC
= 1 + (SWEPT VOLUME ÷ VOL @ TDC)
= 1+ (0.7854 x BORE x BORE x STROKE) ÷ (CCV + HGV + PDV)
CCV = Combustion Chamber Volume, in cubic inches
Note: if volume is given in cc’s then ÷ 16.4 to get cubic inches.
HGV = Head Gasket Volume, in cubic inches,
= Head gasket compressed thickness x 0.7854 x bore x bore
PDV = (Piston Deck Volume) + (Piston Dome Effective Volume)
= (0.7854 x bore x bore x deck to piston distance) + (volume of piston depressions - volume of piston bumps)
Example: What is CR of the engine in #9 if heads have 72 cc chamber, head gasket is compressed to 0.040 inch and flat top pistons give 0.025 deck clearance at TDC?
CCV = 72 ÷ 16.4 = 4.39 cubic inches
HGV = 0.040 x 0.7854 x 4.030 x 4.030 = 0.51 c.i.
PDV = 0.025 x 0.7854 x 4.030 x 4.030+ 0- 0 = 0.32 c.i.
CR = 1+ (0.7854 x 4.030 x 4.030 x 3.48 ÷ (4.39 + 0.51+ 0.32))
= 1+ (44.39 ÷ 5.22) = 9.5 CR
  #9 (permalink)
Old 05-15-04, 04:57 PM
77sleeper's Avatar
GO BUCS!
like I said
Quote:
  #10 (permalink)
Old 05-16-04, 12:55 AM
Official Member
Quote:
You talk like a bowtie boy. That's a bored over 350.
A 351 has a bore and stroke of 4.000 x 3.500
CID = 8 x (pi/4) x bore^2 x stroke
= 8 x 0.7854 x 4.030" x 4.030" x 3.500" = 357 in^3
  #11 (permalink)
Old 05-16-04, 01:02 AM
zwhitr's Avatar
Quote:
Thems fight'n words.
Check the link I was cut'n and past'n
Edelbrock tends to cater to them there chebbies
on a quiet night you can just sit and here a chevy rust.
  #12 (permalink)
Old 05-16-04, 06:46 AM
Apsychotic's Avatar
Official Member
357
Hey, in my opinion, the "357C.I." would look the coolest on the cowl anyways.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
