Mustang Forums at StangNet
Installation of a 3550 into a Fox. What I need to know????
This is a discussion on Installation of a 3550 into a Fox. What I need to know???? within the 5.0 Tech forums, part of the 5.0 Mustang category; Like it says.. I am going to be putting a 3550 into my 83 GLX 5.0. I already have the ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 05-23-04, 06:42 PM
Stang8URMPRT's Avatar
Banned
Like it says.. I am going to be putting a 3550 into my 83 GLX 5.0. I already have the double hump cross and what not... I need to know exactly what I need to modify on the crossmember for the 3550 to fit it. Any info would be great and maybe a tech article with pictures? Thanks
Nick
  #2 (permalink)
Old 05-23-04, 09:25 PM
Banned
ttt
  #3 (permalink)
Old 05-23-04, 10:44 PM
All you need to modify is the opening where the shifter comes up to the cockpit needs to be bigger. You also need to modify where the crossmember is on the car it needs to be moved back.
  #4 (permalink)
Old 05-23-04, 11:01 PM
bluebeast's Avatar
was your car and auto before i know when we did my friends he had an auto and the cross member fit perfect not need to move anything.
  #5 (permalink)
Old 05-24-04, 12:06 AM
v8only's Avatar
Official Member
as long as your car is an original manual equipped, you won't have to modify the trans tunnel. if your doing an auto to 5 speed conversion, that's a whole different story.
on that trans x member, where the tubes are on either end, you'll see how those tubes are tac welded onto the trans x member. grind off those little tac welds, which will allow the x member tubes to slide forward and back. that's all you'll have to modify. as long as you have the 3550 bell, everything else should bolt right up.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
