Whats up guys. I am a new member of the board. Some of you may know me from 3.8mustang.com and v6power.net. Anyways, I created a new product that will help cut down on the gear whine noise and vibration that alot of people complain about with their aftermarket shifters. These gaskets will remove the need to use messy RTV silicon when installing your shifter. Instead of putting a bead of the silicon down, you simply lay these pre-cut gasket over the base of the transmission and then install your shifter. I am also including gaskets for the shifter handle as well. The shifter handle gaskets will also help cut down on vibration. The gaskets will in no way interfere with the proper functioning of your aftermarket shifter. They can be used on all T45 & T5 transmissions regardless of what aftermarket shifter you have. i.e. Pro 5.0, Tri-Ax, etc, etc. I am selling these for $12 shipped to your door. I accept paypal @
fiveomuscle@yahoo.com
If you would like to pay with another form of payment please email me and we can work something out. Also email me if you have any questions. Thanks guys! ***Update, I now produce gaskets for TR3650 and T56 transmissions*** Here are some pics....
http://www.mustangmods.com/data/4565..._installed.jpg http://www.mustangmods.com/data/4565/gaskets.jpg
