View Single Post
  #36 (permalink)
Old 04-15-05, 07:36 PM
Snake1's Avatar
Snake1 Snake1 is offline
Quote:
Originally Posted by 88GTsocal
Only possible if the hunting idle only happens when the A/C is on.
as you probably know Ford heaters are on all the time except when in the off position,doesn't matter is the A/C is on, or heater side is on because your Compressor kicks in on heat side also.
Put your lever on mix on the heat side and go watch your compressor kick in, Trust me i've been thru all of this with my 88GT and R 12. if it doesn't kick in,not enough oil in your system to activate it.
