View Single Post
  #40 (permalink)
Old 04-15-05, 09:01 PM
89MustangGX's Avatar
89MustangGX 89MustangGX is offline
I have nothing productive to add!
Quote:
Originally Posted by Snake1
On the heat side, the compressor kicks on for a bit then kicks off,on the ac side it stays on until you switch over to the heat side,then it starts its on/off cycle again
I've never seen this before, not on any of my Fords ... and the A/C has worked fine.
As mentioned above, the A/C only cycles on with A/C and Defrost. It does cycle when it's on however, that is normal.
It sounds like maybe you had a stuck clutch in your compressor or something else going on.
