I have a cold start idle problem that lasts for about 5 mins of driving then is fine or if I shut it off and start it up again couple of times it seems to go away as well. It doesn't do the standard high idle at start anymore, rather it now surges up to 1500 RPM and the down to 100-400 RPM. If you don't give some throttle, it just dies.
I have replaced the Idle Air Bypass
Cleaned the ACT, Mass Air filiments
tested the temp sensor at 180* it reads the right ohms (as per a Chilton manual)
I should probably check it cold and clean Pin 10 as suggested in this thread.
What else should I be looking at?
