Quote:
Originally Posted by HISSIN50 also, i find it easiest (on a fox) to stand on the driver side to remove it. to get the screen below the grommet and valve out, a magnet works for some; i use a pair of really long needle nose pliers. a curved dental pick would work too. if you buy a new screen ahead of time, you can see what it looks like and how to grab ahold of it.
good luck. |
Just a little more on that, my basket was really stuck in there ( I mean really stuck!!!!) I ended up using a tool that I made to get it out. I use a bolt that I welded a screw on the end of it, the screw really digs in on the basket and the bolt head give you something to grab on to. If it helps any one
