Mustang Forums at StangNet
Automatic tranny troubles, car wont shift gears?
This is a discussion on Automatic tranny troubles, car wont shift gears? within the 5.0 Tech forums, part of the 5.0 Mustang category; This post may look a little familiar but I figured I had to repost it to clear up that I ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-01-04, 08:08 PM
StreetDreamsGT's Avatar
Official Member
This post may look a little familiar but I figured I had to repost it to clear up that I have an automatic transmission not a manual. I recently had my car put in a shop to have my exhaust taken care of and my new motor mounts (ENERGY SUSPENSION!!!!!) tossed in. Drove it home, and I noticed the rpms kept climbing well past normal. Normally they'd switch up tween 2500 n 3000 or so I hit 40 n was in 4000 then I pull my foot off n the car pretty much stayed there I stepped on it again and the car revved till it was back at bout 4000 n then i felt it kick in. For the whole time I've owned my car it's shifted round 2500/3000. Today I pulled the filtler and changed the fluid, there was a small metal piece in the bottom of the pan, looked like the dipstick kinda, a lil thicker n bout an inch long. Anybody know what could be up?
  #2 (permalink)
Old 11-01-04, 08:33 PM
NYC LSC's Avatar
How's the throttle valve cable bushing look on the throttle body?
  #3 (permalink)
Old 11-01-04, 10:04 PM
Official Member
don't think it's in bad shape, i'll have to take a closer look @ it tomorrow, what kinda effect could that have on it?
  #4 (permalink)
Old 11-01-04, 11:32 PM
Official Member
A bad cable or misadjusted one can cause the problems you are having. Take it somewhere to get checked out since a badly adjusted TV cable will fry a transmission easily.
  #5 (permalink)
Old 11-02-04, 07:05 AM
rsw007's Avatar
Official Member
sounds like tv cable changed during motor mount swap.
  #6 (permalink)
Old 11-02-04, 08:05 AM
crazypete's Avatar
All my crevices are greased.
If the piece looked like a little bouy, then that is the factory plug that goes into the dipstick tube apeture to keep crap from falling in. Toss it. You said you pulled the pan. Is the fluid level fine and the fluid look ok?
If the fluid is low, it will ...lose gear and neutral.... at lights and such and when you rev it and the pump turns, it will suddenly jump into gear and the car will move.
If it's revving past it's normal point and doesnt shift either
1. If it feels like it's neutralling above the normal rpm shift point, you have a stuck valve in the valvebody. Remove valvebody and move everything around till you find the culprit, remove valve and turn in steel wool, reinstert and repeat until it's moving freely
2. If you're powering above the shiftpoint, the TV cable needs to be lengthened since the trans thinks you are at full throttle.
Get under the car at drivers side, about halfway down and feel up where the shifter cable goes in. There will be a second lever there. Make sure it's free moving. There is some way to adjust the clip on the throttle lever below the TB by pushing the clip out but this method never works properly. You want the cable just tuaght when the throttle is closed and fully pulled with the throttle wide open. The factory system is calibrated for factory geometry so I agree the motor mounts are the cause (unless the lever is stuck). Lowering the motor also lowers the trans, remember that.
Here is the standard adjustment method:
http://www.txchange.com/aodadj.htm
Good luck!
CrazyPete
  #7 (permalink)
Old 11-02-04, 01:47 PM
Official Member
thanks guys i'll check it out, I drove it today and found out it does shift but not till i'm up round 4500 rpms.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
