Mustang Forums at StangNet
Stock disk brake lines fit stock drum car?
This is a discussion on Stock disk brake lines fit stock drum car? within the Classic Tech forums, part of the Classic Mustangs category; Im swapping stock disk brakes on the front and was wondering does the stock disk brake hoses match up to ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Classic Mustangs > Classic Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 11-16-04, 06:37 AM
jb1dsl's Avatar
Official Member
Im swapping stock disk brakes on the front and was wondering does the stock disk brake hoses match up to the drum hard lines or do i have to change the lines some. Any special stuff i need to get to do the change over?
Thanks!!
  #2 (permalink)
Old 11-16-04, 09:20 PM
jb1dsl's Avatar
Official Member
  #3 (permalink)
Old 11-17-04, 11:03 AM
The lines that extend to each front wheel from the proportioning block are different. They terminate facing the opposite direction on disks vs drums. Also, the flex lines are different.
Are you going from manual to power? If so, a bunch of things have to be changed.
  #4 (permalink)
Old 11-17-04, 05:15 PM
jb1dsl's Avatar
Official Member
nope manual to manual, so i need to get the hard lines and the brake hoses?
  #5 (permalink)
Old 11-18-04, 01:00 AM
Official Member
The hard lines to the master cylinder have a different size flare fitting. The hoses are different since they connect to the calipers with banjo bolts. You can use the original front distribution block, since it only serves to branch the fluid to left and right sides.
If you have the money, get the SS braided hoses (they make them to fit the original lines off the dist. block), and fabbing some new hard lines is a piece of cake. The parts are available at most any parts store.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
