11-23-04, 10:32 PM
| | Founding Member | | Join Date: January 2002 Location: East ARKANSAS Delta
| | | Does the stock starter work with a tremec 3550?
Me and a friend were putting together a list of things he was gonna need to swap his AOD out for a 3550. I Know you need the new bell housing, but does the factory starter work with it? Also I know you need a differnt clutch kit for the TKO , but do you for the 3550? Anything else specific to the 3550 I am forgetting? |
11-23-04, 11:33 PM
|  | Founding Member | | Join Date: January 2002 Location: Massachusetts
My factory starter bolted right up to my Tremec 3550. However, it was from a 5-speed equipped car, not an AOD. Buy a 5-speed starter and compare it to the AOD before installation. If they're the same, use the AOD unit and return the new one (just don't use it!)
As for the clutch, I bought a Centerforce Dual Friction Clutch for a '90 GT and it works just fine.
11-23-04, 11:36 PM
Ok thanks for the info. Have I mentioned how cool I think your car is?  |
11-23-04, 11:48 PM
11-23-04, 11:52 PM
|  | I have nothing productive to add! | | Join Date: July 2001 Location: Mill Creek, WA
| | Quote: |
Originally Posted by Hissing Cobra My factory starter bolted right up to my Tremec 3550. However, it was from a 5-speed equipped car, not an AOD. Buy a 5-speed starter and compare it to the AOD before installation. If they're the same, use the AOD unit and return the new one (just don't use it!)
As for the clutch, I bought a Centerforce Dual Friction Clutch for a '90 GT and it works just fine. | I'll second that. Stock starter and a stock clutch work fine with the 3550.  |
11-24-04, 06:00 AM
| | Member | | Join Date: February 2004 Location: Boca Raton
On a 5 speed, I needed to break the weld spots on the cross-member too. I'm not familar with the AODs. Stock clutch and starter and flywheel worked fine. I've got ~30k on the 3550 and wish I'd have indexed the bellhousing (seach this board for details). The input shaft bearing is starting to make noise. |
11-24-04, 12:15 PM
|  | Official Member | | Join Date: July 2003
| | Quote: |
Originally Posted by gray ghst On a 5 speed, I needed to break the weld spots on the cross-member too. I'm not familar with the AODs. Stock clutch and starter and flywheel worked fine. I've got ~30k on the 3550 and wish I'd have indexed the bellhousing (seach this board for details). The input shaft bearing is starting to make noise. |
your clutch adj is probably too loose, does the noise go away with partial clutch pedal pressure? |
11-24-04, 06:45 PM
v8only,
I'm going to check, but, the car has the stock self adjusting clutch mechanism. Is there some trick I'm missing? |
11-24-04, 08:18 PM
Ok so I guess my only question then is are the aod and
t-5 starters any different? |
11-25-04, 01:53 AM
| | Quote:
v8only,
| yes, actually, you need to get rid of the self adjusting setup, it really sucks. I've got into great detail HERE: http://50stangs.com/techarticles/clu...djustment.html | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
