Mustang Forums at StangNet
97 GT PI HEAD SWAP DYNO SHEET INSIDE
This is a discussion on 97 GT PI HEAD SWAP DYNO SHEET INSIDE within the 4.6 Tech forums, part of the 4.6L Mustang category; Hopefully someone will find this usefull. The car originally dyno'd ~186 HP bone stock and rated at 215 Crank HP. ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 12-02-04, 06:18 PM
theosan's Avatar
Post 97 GT PI HEAD SWAP DYNO SHEET INSIDE
Before the head swap (everything else already on the car) it dyno'd
213.4 RWHP / 282.6 FT. LB
All in all car feels very fast and strong...and I'm happy with the result. I will be removing the C&L mass air meter and get a new dyno tune. Should be able to squeeze out 270 RWHP.
  #2 (permalink)
Old 12-02-04, 06:36 PM
NiteRydaGT's Avatar
Official Member
Nice numbers.
Do you have a 5 speed or automatic?
  #3 (permalink)
Old 12-02-04, 07:33 PM
tomustang's Avatar
Banned
did you regap the plugs to .40?
  #4 (permalink)
Old 12-02-04, 07:36 PM
Sick96Stang's Avatar
Official Member
#'s are looking a little low. I have the mods listed in my sig and made 212 rwhp and 284 rwtq. Most 99+ GT's are making right around 250 rwhp stock right?
  #5 (permalink)
Old 12-02-04, 07:49 PM
NiteRydaGT's Avatar
Official Member
Quote:
Most 99+ dyno around 230-240 RWHP.
The owner of a local Mustang shop dyno'd his 01 5 speed at 233 RWHP stock.
  #6 (permalink)
Old 12-02-04, 07:55 PM
Official Member
Wow those dyno alot lower than I thought they did.
  #7 (permalink)
Old 12-02-04, 07:59 PM
they are rated at 260 crank hp why would they dyno 250 rwhp? that makes no sense
  #8 (permalink)
Old 12-02-04, 08:02 PM
Official Member
Quote:
For some reason I thought I remeber numerous people saying there 99+ GT dynoed at around 250 rwhp but you are right that would make no sense since there crank #'s are 260.
  #9 (permalink)
Old 12-02-04, 08:29 PM
Official Member
With no other mods than the PI swap I went from 189 to 230 after the tune it was 242. Nice numbers man and get rid of that maf its worthless.
  #10 (permalink)
Old 12-02-04, 09:41 PM
good numbers man! hopefully you squeeze out that 270rwhp...thatll be sweet!
what do you guys think my 97 will dyno at??
MODS:
trick flow upper plenum
bbk 75MM throttle body
bbk cold air intake
bbk underdrive pullies
bbk off road h-pipe
american thunder catback exhaust
4.10 gears (dont matter in hp numbers)
bbk timing adjuster
frpp aluminum driveshaft....
last 3 dont really matter.
But how much you guys think i will pull???
oh almost forgot! all that PLUS my PI swap.
  #11 (permalink)
Old 12-02-04, 09:42 PM
MyEarsHurt's Avatar
Official Member
What does it take to get 300 HP at the wheels with a PI swap, Porting? Mild/Agressive Cams? Miracle? I am shooting for 300 rwhp in my 98 gt, and I was planning on a PI headswap with either porting or aftermarket cams....whats it gonna take to get to 300?
  #12 (permalink)
Old 12-02-04, 11:14 PM
NiteRydaGT's Avatar
Official Member
Quote:
Pretty much everything you can think of minus a blower. P/P heads, cams, every bolt on in the book, and a great tune. It's tough but it has been done.
  #13 (permalink)
Old 12-02-04, 11:17 PM
Official Member
Ask nickthegenius his is at 290 I believe.
  #14 (permalink)
Old 12-03-04, 12:42 AM
theosan's Avatar
Nice numbers.
Thanks. I have a 5 Speed.
  #15 (permalink)
Old 12-03-04, 03:20 AM
Banned
Yes nice numbers!
  #16 (permalink)
Old 12-03-04, 03:30 AM
Official Member
Very nice but how do you pass CA-smog with that beast? :confused:
  #17 (permalink)
Old 12-03-04, 04:58 AM
98stangv8's Avatar
Official Member
what is yours dynoing at?
  #18 (permalink)
Old 12-03-04, 11:37 AM
theosan's Avatar
Quote:
The beast is completely street legeal and always pass smog test. The h-pipe has cats and I went with shorty headers instead of long tubes for the same reason. Everything looks stock, you can't even tell that I have new heads and intake unless I tell you.
BTW, I didn't change out the cam to some of the nice aftermarket ones but I know I will eventually have to inorder to break 300 RWHP.
  #19 (permalink)
Old 12-03-04, 12:01 PM
Gearbanger 101's Avatar
SuperMod
Canadian Colossus
I've even seem them dyno as low as 220-225rwhp, so his numbers are actually pretty good.
  #20 (permalink)
Old 12-03-04, 12:16 PM
if you get every bolt on including long tubes...you could probably do it with VT Stage 2 cams and stock PI heads.
  #21 (permalink)
Old 12-03-04, 03:28 PM
MyEarsHurt's Avatar
Official Member
Cool, I think thats probably what I am going to do....thats what I have been thinking about for a while now. And then I am gonna get a cutom tune at detroit speedworks...so hopefully I will break 300, but I guess I would be happy with 290
  #22 (permalink)
Old 12-03-04, 04:11 PM
5spd GT's Avatar
"the 5.0 owns all"
Ls1's are rated at 305-310 (98-02) but they dyno around 290-295rwhp...why would they dyno that high..."that makes no sense"
A stock 99+ Gt 5spd will dyno anywhere from 225-235rwhp...
  #23 (permalink)
Old 12-03-04, 04:20 PM
Quote:
actually 01-02's will dyno 300+ all day long
but there is a reason for that...its called a vette
  #24 (permalink)
Old 12-03-04, 05:05 PM
tomustang's Avatar
Banned
whatever.
  #25 (permalink)
Old 12-03-04, 05:11 PM
theosan's Avatar
Quote:
No. Should I and Why ?
Thanks.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
