I have had mine for a couple weeks and no problems so far, just make sure all the hoses are cable tied so they can't pop off easy. I would recommend checking all the lines periodically when you first get it on to ensure no mishaps. The snow kit is definitely a more elaborate kit and I would recommend it over my mr.freeze to anybody who has the extra money and patience for the install. This is only due to the tunability of the kit, not durability. It is true that the mr.freeze kit is made up mostly of plastic pieces and rubber lines, but if its not near any extreme heat I dont see any reason for problems. It is hard to pass up a water/meth kit for well under 200 bucks with such an easy install, isn't it ? I'm only running 10-12lbs of boost and the gains were mostly in the midrange hp and midrange to peak tq. My inlet temps went way down which is always good. Different jets would make this kit a lot nicer.
