04-18-05, 12:30 AM
| | Member | | Join Date: August 2002 Location: Dallas, Texas
| | Quote: |
Originally Posted by RedGTvert Yes, guess the reason you got detonation when trying to lean it out was that 11.0:1 CR you are running. I am just wondering if they have a tad too much timing.
This is why I said, you cannot just throw parts at a car to make lots of power, unless the parts are matched real well. I am guess you called SHM, and asked for recommendations and this is what they gave you, so you bought it. I am still surprised that 11:4 is the leanest you could go, but with that CR, it limits you N/A. On a positive note, nitrous loves that type of CR, so if you were to go with this type of power adder, look out for the numbers then.
PS. I have seen 99/01 Cobras make 600+rwhp and 420+tq. Like I said, these things are not TQ monsters unless you have something on there like a 2.2L KB. I still say your numbers are not that far off. With a better tune, maybe 10 more rwhp. | what would cause the a/f to need to be that rich though? that is what i still dont understand, and SHM doesnt have an answer for it either. the timing is at stock. when they tried to advance it, it started detonating again. SHM recommended the stroker and cam combination, and when i told them i was planning on a stage one head port, they said that would be even better. i was planning on a blower, so it is all kinda sad...
but, they are still decent numbers, and it drives well.
any ideas, anyone?
04-18-05, 01:44 AM
|  | Official Member | | Join Date: April 2003 Location: Houston/DC
That compression is pretty high to run on 93 octane. To cope with this they could either lower the timing, or the a/f ratio. They clearly chose the latter. The main problem is that your a/f ratio is quite high for a daily driver car on pump gas.
I am still trying to find the thread of a guy with a 96-98 Cobra. He had full bolt ons, longtubes, Dr. Gas offroad X pipe. Tuned by MPH in GA it put down 300rwhp, it had NO internal/headwork/cams done to it at all.
I still think that your numbers are 30hp low, but I have no idea why. Did HPP have any answers? Manny campaigns a 4v in NMRA if I recall correctly. |
04-18-05, 07:09 AM
|  | Founding Member | | Join Date: July 2002 Location: Ohio
| | Quote: |
Originally Posted by RedGTvert Don't take me wrong, they are not bad heads. They flow decently, but lack the velocity of the c's or 03/04 heads. They do very good with FI, but N/A they cannot keep up with an equal set of 03/04 heads. | Yeah, you are right. That is what I was thinking. The B heads are the ones wanted for Forced induction. |
04-18-05, 07:17 AM
|  | Official Member | | Join Date: May 2003 Location: Jacksonville, FL
those numbers are pretty damn respectable in my book for a N/A 2 valve 4.6 bro........ |
04-18-05, 08:26 AM
|  | Official Member | | Join Date: May 2004 Location: Southwestern PA
| | Quote: |
Originally Posted by Dan_Soprano those numbers are pretty damn respectable in my book for a N/A 2 valve 4.6 bro........ |
It's a 4v
I would have the tuner take out timing and lean out the a/f. If that baby has some big ports you're gonna need more cam and more rpms to make the power you're looking for. Plus the bigger cams will help bleed off your cylinder pressures which is causing your detonation.
04-18-05, 10:31 AM
| | Quote: |
Originally Posted by Red35th I still think that your numbers are 30hp low, but I have no idea why. Did HPP have any answers? Manny campaigns a 4v in NMRA if I recall correctly. | Manny's only thought was that it could be just a bad head/cam combination. not much input other than that. Quote: |
Originally Posted by 69fb00GT It's a 4v
I would have the tuner take out timing and lean out the a/f. If that baby has some big ports you're gonna need more cam and more rpms to make the power you're looking for. Plus the bigger cams will help bleed off your cylinder pressures which is causing your detonation. | Yes, Dan Soprano, if this were a 2v with these numbers n/a, i would be quite the happy camper. it is a 4v, however, leading to my quandary.
69fb00GT, what do you mean by helping to bleed off cylinder pressures, and this causing detonation? i am not familiar with this. |
04-18-05, 05:01 PM
cams with more duration leave the valve partially open during the compression stroke. This will lower your compression pressures, resulting in more friendly pump gas scenarios. Plus you'll probably pick up some more HP too if those heads flow well. Only problem, you'll probably be a little softer on teh bottom end.
Sounds to me like detonation is keeping you from respectable numbers....as posted above...if the tuner hasn't already tried pulling some timing and taking out some fuel..ask him to try it.
I believe i've also read that the 96-98 4v intakes are pretty restrictive...maybe you can get yours extrude honed or ported. |
04-18-05, 07:25 PM
|  | Founding Member | | Join Date: November 1999 Location: Wellington, FL
| | Quote: |
Originally Posted by johnny98 what would cause the a/f to need to be that rich though? that is what i still dont understand, and SHM doesnt have an answer for it either. the timing is at stock. when they tried to advance it, it started detonating again. SHM recommended the stroker and cam combination, and when i told them i was planning on a stage one head port, they said that would be even better. i was planning on a blower, so it is all kinda sad...
any ideas, anyone? | It is becuase you are getting detonation, so the tuners is richening uo the mixture to avoid it. A blower with that combo is out of the question, uless you are ready to run 100, and that would cost an arm and leg to drive, that is why I say nitrous. A 200 shot on there would be sweet with your CR.
Hpw is your MAF reacting? |
04-18-05, 07:28 PM
| | Quote: |
Originally Posted by Red35th That compression is pretty high to run on 93 octane. To cope with this they could either lower the timing, or the a/f ratio. They clearly chose the latter. The main problem is that your a/f ratio is quite high for a daily driver car on pump gas.
I still think that your numbers are 30hp low, but I have no idea why. Did HPP have any answers? Manny campaigns a 4v in NMRA if I recall correctly. | 93 on pump gas is not as serious as you are believing. There is absolutely no reason it cannot be done. My new engine, when it is built will be running that kind of CR on pump gas, and it will run all day long.
30rwhp?? Not with that combo, sorry. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
