05-20-05, 03:57 PM
|  | Official Member | | Join Date: June 2004 Location: Ventura, CA
| | Quote: |
Originally Posted by BB1966 Reen,does the MII make the track any wider than the stock front suspension??? Thanks in advance | Nope. Also, Heidt's now offers 5/8" shorter control arms (narrows the track 5/8" per side) to accommodate other wheel and tire sizes. |
05-21-05, 09:23 PM
|  | Official Member | | Join Date: December 2004 Location: Beaufort , NC USA!!!!
Sweet! Thanks again! BTW why dont this thread rate a sticky?????????????? |
05-24-05, 01:07 AM
05-24-05, 07:26 AM
|  | Founding Member | | Join Date: September 2002 Location: Virginia
05-24-05, 07:32 AM
|  | Founding Member | | Join Date: July 2002 Location: Austin TX
What is different about the Cobra R's IRS and the regular one? |
05-24-05, 09:01 AM
| | Quote: |
Originally Posted by Edbert What is different about the Cobra R's IRS and the regular one? | There are some notable differences throughout the years:
1999: 28-spline axles, 3.27 gears, soft rubber bushings
2000 R: Massively more beefy. 31-spline axles, exotic 3.55 Girodisc hydro-mechanical posi unit, improved CV joints, improved camber adjustment, hardest bushings of any of the IRS units. Reduced wheel hop.
2001-02: Basically like 1999 but with a small axle improvement; axles are 31-spline on the inside but still 28-spline on the ends. Gears are 3.27:1.
2003-04: Much more like the 2000 R unit. 3.55 posi (but not Gerodisc), 31-spline axles (a bit shorter), hard bushings (still not as hard as the 2000 R), improved camber, improved bump steer. info from the DVS Restorations website |
05-24-05, 07:55 PM
|  | Founding Member | | Join Date: May 2002
awesome car!! I have a dumb question about the rear end. What does it use for upper arms? I only saw the lowers and struts. are the halfshafts supposed to act like an arm? and also on that note with inboard brakes... what happens if you snap a half-shaft? |
05-24-05, 08:14 PM
It has upper control arms,they bolt tot the top of the cradle. Bad azz set up Reen!!!! Keep the updates comin! |
05-24-05, 08:32 PM
| | Quote: |
Originally Posted by 67coupestang awesome car!! I have a dumb question about the rear end. What does it use for upper arms? I only saw the lowers and struts. are the halfshafts supposed to act like an arm? and also on that note with inboard brakes... what happens if you snap a half-shaft? | I assume you're referring to the red convertible. Yes, the half shafts act as control arms as well. They are designed to do this and can handle all of the loads involved. If one fails, you will have suspension failure on that side manifested as a radical change in camber, but it's built not to fail. There are thousands upon thousands of cars on the road with this design, commonly referred to as a "Jaguar IRS". |
05-24-05, 08:33 PM
| | Quote: |
Originally Posted by BB1966 It has upper control arms,they bolt tot the top of the cradle. Bad azz set up Reen!!!! Keep the updates comin! | I think he was talking about the IRS on the red convertible, not the Cobra IRS above. Now I've mixed the thread all up! |
05-25-05, 01:12 PM
| | Quote: |
Originally Posted by NasaGT Sticky this thread! | That would be a good thing...who has the power?? |
05-25-05, 02:57 PM
|  | Official Member | | Join Date: May 2003 Location: HOUSTON TEXAS
My God that is sweet ! Who ever said money doesn't buy happiness was full of **** !
you ever see what those motors can do on stock cams, intake, and heads with twin 57mm turbos ? How about 700 RWHP, and 595 RWTQ
same set up seen here in a video of a 2001 Bullitt Mustang - just need forged pistons and rods I'm sure he he
video - http://www.modularpowerhouse.com/for...ittnomusic.wmv
more info on the kits - http://www.modularpowerhouse.com/for...splay.php?f=74
how are you doing that front end to run that rack, and pinion / coil over etc.. new K member - sorry if I missed that info posted alredy. Is there a kit for all that ?
looking for a 68 coupe to adopt, mine is very jealous  |
05-25-05, 03:21 PM
| | Quote: |
Originally Posted by 68 & 00 GT how are you doing that front end to run that rack, and pinion / coil over etc.. new K member - sorry if I missed that info posted alredy. Is there a kit for all that ? | The front end is a Heidt's MII setup with a smattering of custom and modified parts to make it all fit together. There are more pics of it all on the previous pages. |
05-25-05, 07:45 PM
05-25-05, 08:55 PM
|  | Official Member | | Join Date: August 2004 Location: Oceanside, CA
05-27-05, 05:24 PM
05-28-05, 11:59 PM
go knock on the biggest da#@ piece of wood you can find right NOW!!! |
05-29-05, 12:31 AM
| | Official Member | | Join Date: February 2003 Location: Denver, CO
Pete,
Who did you pisz off not to deserve a sticky by now? I remember when you first came to the board everyone gave you crap because you were new ; but you definitly gained thier respect rather quickly and were able to contiribute to other members questions as well as your own. Even though you are selling the car you are not looking for free advertisement but you are keeping us all up to date on a project most of us could never dream of completing. I hope you have a few biddders lined up for that car. I just hate looking for the next thread to see what is next for the convertible.
My point - Please sticky this thread! |
06-01-05, 08:48 PM
| | Founding Member | | Join Date: August 2002 Location: Shreveport, La
| | Quote: |
Originally Posted by reenmachine The front end is a Heidt's MII setup with a smattering of custom and modified parts to make it all fit together. There are more pics of it all on the previous pages. |
What kind of modified parts were required for the heidt's MII?? I will be puting one of these setups in my car some time in the near future. Just wondering if there is any tips or pointers you might point out before I order one up.
Thanks for the heads up
Graham |
06-02-05, 09:04 AM
Reen-
How many hours would you say that it took to put in the MII front conversion/set up?
Thanks!
ps. sticky please! |
06-02-05, 09:35 AM
| | Founding Member | | Join Date: May 2001 Location: Toronto
Holy smokes!!!!!!
Awesome...simply...awesome.
I really want to start a project like this in the next few years...on a '67 FB.
Thanks for showin us how it's done.  |
06-02-05, 11:29 AM
|  | Official Member | | Join Date: December 2004 Location: Bay Area, CA
| | | Heidt's and Horsepower
Reen,
What kind of horsepower do you suppose you could throw at the Heidt's? It seems like the limit would just have to do with whatever you throw in the 9" rear, but do they have any type of rating for the half-shafts or U-joints?
If it turns out I can actually afford it, (ha!) I'm seriously thinking about an IRS after my floor pans are done. In my dreams I'd like to have a low-compression 351w/408 under the hood approaching 500hp, and supercharge it later if I ever want something extra.
thanks,
Joe |
06-02-05, 12:56 PM
| | Quote: |
Originally Posted by blk 02 What kind of modified parts were required for the heidt's MII?? I will be puting one of these setups in my car some time in the near future. Just wondering if there is any tips or pointers you might point out before I order one up.
Graham | The only mods I had to make had to do with fitting the 4.6. If you're installing a regular small block you won't need to change a thing. |
06-02-05, 12:58 PM
| | Quote: |
Thanks!
ps. sticky please! | With the car stripped, it takes me about 40 hours start to finish. That's with being really anal about the measurements and every little detail, and spending a lot of time on fitment and surface prep to get nice welds. I could probably do it in half the time and have it function fine, but not look nearly as clean and finished. |
06-02-05, 01:02 PM
| | Quote: |
thanks,
Joe | Well, it's got a Currie Trac-Loc 9", 31-spline Strange axles, and monster U-joints. The Currie solid axle setup with basically the same specs is rated to 600+ horsepower conservatively, and I bet that this would be similar. The only semi-unknown is the U-joints and halfshafts, and I'm in the process of just doing the calculations myself to be able to answer this question. Heidt's can't answer it -- they just say "well, nobody's ever called us claiming they broke one."  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | | |
