Mustang Forums at StangNet
help me choose between two cams
This is a discussion on help me choose between two cams within the 5.0 Tech forums, part of the 5.0 Mustang category; alright, i found two cams that are right in my price range and im just wondering which one you guys ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 05-03-05, 10:05 AM
ECU5.0's Avatar
Banned
alright, i found two cams that are right in my price range and im just wondering which one you guys think would make better power.
cam #1: Adv. Duration 270/280 Duration@.050" .204"/.214" Gross lift .448"/.472"
cam #2: Adv. Duration 280/290 Duration@.050" .218"/.228" Gross lift .471"/.471"
keep in mind when deciding which one is better that i will be running 1.7 rockers with the cam also. these are the Crane cams Blue Racer cams. thanks in advance
  #2 (permalink)
Old 05-03-05, 11:25 AM
Official Member
My quarter said came up "heads", so cam #1.
Seriously though... I'm no cam expert so wouldn't try to tell you one over the other.
Here's bump for ya.
  #3 (permalink)
Old 05-03-05, 11:28 AM
ECU5.0's Avatar
Banned
thanks man. i dont even know what half of that crap means...so i couldnt even begin to decide which one
  #4 (permalink)
Old 05-03-05, 12:17 PM
tjm73's Avatar
What is your price range?
  #5 (permalink)
Old 05-03-05, 12:30 PM
BaXTeR3221's Avatar
Official Member
I would love for someone to explain to me what the cam specs actually mean.
  #6 (permalink)
Old 05-03-05, 12:43 PM
squeeeg's Avatar
From what I understand, and I am sure I am not 100% right, but here it goes.
Duration is how long the valve is open. This is what actually created clearence issues with a cam. Lift is how far the valve itself opens. the numbers are in the order of intake/exhaust for each measurement. Cams are measures at .050 inches to get the numbers. Hope this helps and hope somebody can fill in more infor for us.
  #7 (permalink)
Old 05-03-05, 12:52 PM
srothfuss's Avatar
Last night I stabbed the same guy 7 times in a row.
Ask.... And Ye shall receive!
Valve Lift
Valve lift is probably the most mentioned term when it comes to bench racing and bragging about whose camshaft is bigger. In cam speak, there is only lobe lift, not valve lift. The cam lobe raises the lifter, which in turn raises the pushrod and actuates the rocker. From there, the rocker multiplies the lobe lift by the rocker ratio to determine the actual amount that the valve is pushed off its seat. Basically, as the camshaft rotates in the engine, the lobes lift the valvetrain and actuate the valves accordingly. One way to effectively increase the amount of valve lift without actually changing the camshaft is to utilize a higher-ratio rocker arm. For example, a lobe lift of 0.310 inch multiplied by the typical small-block Chevy 1.5:1 rocker ratio would provide a valve lift of 0.465 inch. On the other hand, simply changing to a 1.6:1 ratio would deliver an additional 0.031 inch lift to move the valve a total of 0.496 inch from its seat. Of course, with this additional lift comes additional duration as well, which brings us to our next subject.
Valve Duration
The next most popular camshaft measurement is the duration of time a camshaft lobe keeps the valve off its seat. The purpose of a valve is to regulate the flow of air. In order to measure a camshaft's duration, you must use a degree wheel in conjunction with a predetermined lift point. The most common duration references are advertised duration measured at 0.050-inch lift. While the advertised numbers are supposed to be measured at 0.020-inch lift, some cam grinders measure farther down the lobe to make their camshaft look more radical than it really is. Because of this confusion, most engine builders use the 0.050-inch duration figure, as will we throughout the rest of this story.
Duration is probably the biggest factor in determining an engine's overall character. When the length of the duration is increased, the engine's maximum top-end potential will increase as well. This is due to the intake and exhaust valves being held open longer to move more air and fuel through the cylinder. While this long-duration technique is great for making upper-rpm power, there is also a negative effect that must be considered. When the valves stay open longer, it requires them to leave the seat sooner and close back down on it later, which causes an overlap condition. This allows the combusted cylinder pressures inside the cylinders to fall at low rpm, which in turn creates a loss of low-speed torque. >> As for upper-rpm cylinder-pressure bleeding, there isn't enough time for a considerable amount of pressure to disperse before the next engine cycle can begin.
Sooner or later, the question of ultimate valve timing manipulation will enter the picture and issues of piston-to-valve clearance will become a problem. While most enthusiasts believe that total valve lift is primarily responsible for piston-to-valve clearance, it actually plays only a small part. Pistons contact the valves due to extensive amounts of duration. Camshafts that typically measure less than 0.550-inch lift and 220 degrees of duration (at 0.050-inch lift) are usually safe with flat-top pistons, but even then they should be checked for acceptable clearance.
Overlap
While valve duration is the amount of time a valve remains off its seat, overlap is a measurement of time that the intake and exhaust valves in the same cylinder are both open simultaneously. This overlapping of the valves is required to take advantage of an engine's maximum potential but comes with a few disadvantages. The first drawback: When a cylinder fires during its combustion stoke, both valves are closed in order to contain compression. However, to maximize exhaust potential, an engine builder may use a camshaft that opens the exhaust valve before the piston reaches bottom dead center (BDC) and closes slightly after the exhaust stroke passes TDC during the early induction cycle. The benefit here is a well-scavenged exhaust stroke but it comes at the expense of some bled-off cylinder pressure and a slightly contaminated intake charge. Along with a disturbed intake charge, the engine's vacuum signal is weakened because the piston's vacuum is not only drawing its intake charge from the induction system, it's also pulling dirty air from the open exhaust valve. This weakened air signal raises emissions and lowers idle engine vacuum, which plays a major role in the operation of engine-driven accessories. Along with the previously mentioned problems, excessive overlap also creates a weak torque curve, as the induction system is not functioning at its maximum potential when the cylinder is not being filled properly. In this case, low- and mid-speed torque are traded for peaky upper-end horsepower.
Lobe Separation Angle (LSA)
The next concern should be lobe separation angle. We know that the intake valve opens to create power and the exhaust valve follows to keep that power building. Lobe separation angle (LSA) basically describes the amount of lifter movement time between the intake at its maximum lift point and the exhaust at its maximum lift point. Of course, this is relative to the camshaft duration, which determines how long it takes the lifters to travel to and from their maximum lift points.
Refer to the diagram of two camshaft lobes. Points A and B are the beginning and end points of measurement for the camshaft's LSA, C and D refer to the intake's 0.050-inch duration measurements, and E and F indicate exhaust duration.
Notice that points E, G, and D form a triangular area, which is called the camshaft area of overlap. Once all of these points are understood, it's easier to see how a wider (higher numerically) LSA would create a smaller area of camshaft overlap. Now assume we tighten (numerically lower) the LSA. Points A and B would move closer together and cause overlap points E, G, and D to form a larger triangular overlap area. This means that the LSA can be used to alter the overlap of the intake and exhaust valves, and a wider LSA will offer the best idle vacuum and emissions, and allow the camshaft to carry out its power curve for a longer period of time.
This doesn't necessarily mean the engine will make more power the higher it is spun, but rather that the engine will not nose over quite as quickly as a more peaky engine would. As for tightening the LSA, valve overlap will become more evident and provide a number of benefits. Improved peak power potential is one and a stronger vacuum signal at maximum airflow efficiency is another. The strong maximum efficiency signal is also a way of saying that responsive power (peak torque) at or near the same maximum airflow efficiency will improve. As far as making the right choice, a street-driven vehicle should look for a wider LSA, while a race car can benefit from a tighter one. Either way, once the principles of camshaft design are understood, they can be used in conjunction with one another to develop the ultimate grind.
Intake/Exhaust Centerline
Anyone other than a camshaft engineer or competitive engine builder rarely discusses the subject of intake and exhaust centerlines. The reason for this is because they are both ground into the camshaft as initial timing points and allow an engine builder to phase the camshaft in with the rotating assembly. Earlier, we discussed how a camshaft must spin at half the speed of a four-stroke bottom end in order for it to operate the valves and deliver the spark at the correct time. The engine builder only needs to know the specifications in order to degree the camshaft in with the bottom end and check its accuracy to make sure the cam was ground correctly. Most builders only check the intake centerline because the exhaust centerline is phased off the intake, which means that if one is correct then the other is too. Unlike LSA, these centerline specifications are predetermined and ground into the camshaft at the time of manufacture. This means they cannot be altered unless the camshaft is completely reground.
....copied from a hot rod mag
  #8 (permalink)
Old 05-03-05, 02:49 PM
ECU5.0's Avatar
Banned
Quote:
well the first cam i have posted is $139 and the other one is $109. which includes lifters. thats the kind of price range im lookin for. i want the cheapest build ever
edit: dont know if i said but it will be in a motor with cobra upper and lower with either stock ported or gt40 heads and stock bottom end with 3.55 gears. im not going for anything super crazy or fast as you can tell...but i just want something that will run good and hard.
  #9 (permalink)
Old 05-03-05, 02:56 PM
MrKwik's Avatar
Are those flat tappet cams?
  #10 (permalink)
Old 05-03-05, 02:58 PM
Official Member
The definitions are great but aren't of much use when you're looking at specs and trying to decide which cam will make the most of a particular combination. That's pretty much why I steer clear of making cam recomendations.
  #11 (permalink)
ECU5.0's Avatar
Banned
i found them in a jegs catalog. it says hydraulic lifters included. part # 270-wg1107k and 270-wg1163k
  #12 (permalink)
Old 05-03-05, 02:59 PM
Grn92LX's Avatar
Fidanza Man!
Quote:
Ding ding ding!
  #13 (permalink)
Old 05-03-05, 03:03 PM
runningmole's Avatar
Stock heads? keep your stock cam
  #14 (permalink)
Old 05-03-05, 03:07 PM
MrKwik's Avatar
Quote:
Neither! I would stick with the factory roller before going to flat tappet. If you change it, get one for a roller motor and you can reuse the stock lifters.
And I think the trick Flow stage I is only like $139. I know alot of poeple run that one and like it but every combo is different. If your keeping stock heads though, you probably wont see any noticeable increase in power and will probably loose some bottom end. It will sound cool though so if thats your reason for changing it then go for it. Be sure to use fresh springs though or the motor will peter out before the cam gets up in its powerband.
  #15 (permalink)
Old 05-03-05, 03:15 PM
ECU5.0's Avatar
Banned
ok...well the jegs catalog didnt say anything about them not being for a 5.0 HO motor. but i just checked the website and they are hydraulic flat tappet cams. guess its back to the drawing board. AAAAAHHHHHHH!!
  #16 (permalink)
Old 05-03-05, 03:18 PM
ECU5.0's Avatar
Banned
well the heads are gonna be ported or they are gonna be gt40 heads. yeah, springs are going to be a must...even if i stick with the stock cam...which i dont really want to do. i dont really care what it sounds like as long as it pulls hard and runs hard
  #17 (permalink)
Old 05-03-05, 03:29 PM
ECU5.0's Avatar
Banned
the only problem with the trickflow stage 1 is that with 1.7 rockers im sure ill have clearance issues. im trying to stay away from fly cutting the pistons unless it is absolutely necessary and the only way to get a cam that will work. if i could find a cam with just a little more lift than the stock cam and more duration that would be awesome
  #18 (permalink)
Old 05-03-05, 04:02 PM
MrKwik's Avatar
Ah...missed that you were using 1.7's. I used an e303 with 1.7's and GT40 heads with no clearance problems but you would definately want to check it. If your no concerned with having that big cam sound then you might just stick with a stocker. Theres alot of fast cars still running a stock cam.
  #19 (permalink)
Old 05-03-05, 04:07 PM
ECU5.0's Avatar
Banned
i mean, i wouldnt mind a nice lope in the idle but its not necessary. would advancing the stock cam do anything beside make it a dog down low? ive got a roller timing set sitting in the tool box that is going on the new motor that i can advance the cam with. im just trying to do this cheaply and with no problems
  #20 (permalink)
Old 05-03-05, 04:29 PM
ECU5.0's Avatar
Banned
how about this cam....im sure it would work just fine...im just wondering about the specs. Performance Hydraulic; 351W Firing OrderDuration- 204 Int./214 Exh.; Valve Lift- .448 Int./.472 Exh.; Lobe Separation- 112 Deg. plus i can get it through my work for under 100 bucks. or is that basically like the stock cam. i dont know the specs on the stock cam so im not sure if that one is any different
  #21 (permalink)
Old 05-03-05, 06:50 PM
bobbys9350's Avatar
Official Member
Ed Curtis custom grind!!!
  #22 (permalink)
Old 05-03-05, 07:23 PM
Thenemesis's Avatar
Banned
be like JJPA the new guy who posted whos got a srt 4 and thought 5.0's used 2 cams Hell you could just put both in there according to him lol (sorry dude but thats a new one in my book )
  #23 (permalink)
Old 05-03-05, 07:27 PM
ECU5.0's Avatar
Banned
Quote:
that would probably be the best route to take by far....but im trying to keep this build super cheap since im getting the motor for free and probably getting the heads for a couple hundred bucks
  #24 (permalink)
Old 05-03-05, 07:36 PM
Official Member
Quote:
Hey i take offense to that!! J/K hey man like i said i came from a DOHC 4 banger, so i had 2 cams. Im trying to learn this stuff, which my dad knows alot about, but i would like to learn it myself. I would love the sound of a big cam in my car, but with the GT40 heads i guess its not a good idea.
  #25 (permalink)
Old 05-03-05, 09:03 PM
ECU5.0's Avatar
Banned
anyone have any idea about the cam i posted? its a sealed power cam cs195r
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dyno results with Comp Cams thanks to SCT Kurgan 4.6 Tech 26 05-30-06 11:44 PM
Comp Cams help RedBullitt 4.6 Tech 1 10-13-04 12:02 PM
Really smart 4.6 guys> Trying to identify cams... Back2Mustangs 4.6 Tech 10 09-06-04 12:13 PM
PI cams vs Aftermarket cams Black-stang 4.6 Tech 2 03-23-04 01:17 PM
Cams choices....???? BlackHatch 5.0 Tech 5 12-31-03 12:21 PM
