Mustang Forums at StangNet
Modular Motor Specs!!!!!!!!!!!!!!if Anyone Is Curious
This is a discussion on Modular Motor Specs!!!!!!!!!!!!!!if Anyone Is Curious within the 4.6 Tech forums, part of the 4.6L Mustang category; Basic Modular Engine Dimensions 4.6-liter SOHC and DOHC Aluminum block weight (bare): 86 lbs. Iron block weight (bare): 154 lbs. ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 4.6L Mustang > 4.6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 06-18-05, 07:44 PM
Assembled cylinder head weight: 44 lbs.*
Displacement: 4.6 liters/281 cubic inches
Bore: 3.552 inches
Stroke: 3.543 inches
Bore spacing: 3.937 inches
Main journal dia.: 2.657 inches
Rod journal dia.: 2.086 inches
Rod length: 5.933 inches
Deck height: 8.937 inches
*Assembled 302 iron head weighs approx. 55 lbs.
5.4-liter (8 cylinders) and 6.8-liter (10 cylinders)
-Return to menu
Displacement: 5.4 liters/6.8 liters (330 cubic inches/415 cubic inches)
Bore: 3.552 inches
Stroke: 4.165 inches
Rod length: 6.657 inches
Deck height: 10.078 inches
1996 4.6 SOHC 215HP Mustang Engine
Throttle body: 65mm (2.559 inches)
Intake manifold: composite, cast No. F6ZE-CG
Cylinder heads: cast No. RF-F5AE-AE
Combustion chambers: 49.77cc
Valves: 1.752/1.339 inches
Rockers: roller type, w/1.80:1 ratio
Camshaft lift: .473/.473-inch lift
Compression ratio: 9.30:1
Pistons: hypereutectic w/.153-inch dish
1997 4.6 SOHC 215HP Mustang Engine
1998 4.6 SOHC 225HP Mustang Engine
1999 4.6 SOHC 260HP Mustang Engine
Throttle body: 66.8mm (2.630 inches)
Intake manifold: composite, cast No. XR3E-DC
Cylinder heads: cast No. RFXL3-CZOD
Combustion chambers: 42.40cc
Valves: 1.752/1.417 inches
Camshaft lift: .505/.534-inch lift Duration (I/E) @ .050" 186/194
Pistons: hypereutectic w/.188-inch dish
2000 4.6 SOHC 260HP Mustang Engine
Throttle body: 65mm (2.560 inches)
Combustion chambers: 42.45cc
Rockers: roller type, w/1.81:1 ratio
Compression ratio: 9.74:1
2001 4.6 SOHC 260HP Mustang Engine
Intake manifold: composite, cast No. 1L2E-DL
Cylinder heads: cast No. RF1L2E-6090-D22D (or D24D)
Pistons: hypereutectic w/.145-inch dish
2001 4.6 SOHC 265HP Mustang Bullitt Engine
Throttle body: twin 57mm (twin 2.24-inch)
Intake manifold: cast aluminum, cast No. RF-2RE3-9A448-AA
  #2 (permalink)
Old 06-18-05, 07:46 PM
dsg_gt2004's Avatar
Official Member
good info.
  #3 (permalink)
Old 06-18-05, 07:58 PM
Official Member
Thanks...
  #4 (permalink)
Old 06-19-05, 12:08 AM
Official Member
OH I was hoping for crank end play or bearing specs/journal diameters????
WOW! bling there the are,,, sort of
  #5 (permalink)
Old 06-19-05, 01:07 AM
Tylerb59's Avatar
Banned
Thanks, here is another link which may be useful.
Modular Mix and Match
  #6 (permalink)
Old 06-19-05, 01:23 AM
what is weird that no one picks up on is that not only in 99 did they go to the PI heads but they also went to different cams! The 99 and newer has cams with more lift and more duration!
Andrew
  #7 (permalink)
Old 06-19-05, 01:28 AM
squares98's Avatar
Official Member
Quote:
Andrew
uhh, some of us picked up on that in 1999
  #8 (permalink)
Old 06-19-05, 03:35 AM
east_sidaz40's Avatar
Official Member
Great info , thx man
  #9 (permalink)
Old 06-19-05, 10:14 AM
Official Member
I think you should post this in the " POST THE BEST FAQ TECH THREADS IN HERE" section. Its a nice thread.
  #10 (permalink)
Old 06-20-05, 11:25 AM
Official Member
Is it true that the 99 had a bigger TB than the 2000+, but had less compression (bigger dish piston)? Who else noticed that? I also didn't know they changed the intake & heads in 2001.
Good info none the less, points to you!
  #11 (permalink)
Old 06-20-05, 12:31 PM
97v6Silver's Avatar
it came to $4.56 and i got $0.44 change from a 5, man, they must be dumb
can you read?
  #12 (permalink)
Old 06-20-05, 01:08 PM
Gearbanger 101's Avatar
SuperMod
Canadian Colossus
Quote:
That's a great idea.....that is unless someone already has it covered.
http://forums.stangnet.com/showpost....4&postcount=25
Maybe reading the "Best FAQ tech threads" thread before suggesting he post this in it would help?
  #13 (permalink)
Old 06-20-05, 02:33 PM
Official Member
Quote:
Originally Posted by 97v6Silver
can you read?
Quote:
Originally Posted by cougar694u
...Who else noticed that? I also didn't know they changed the intake & heads in 2001...
Uhhh, yeah, dumba$$, that's why I asked if anyone else knew or noticed that. I didn't know, and wasn't sure if it was common knowledge. That's why I asked the question, moron.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Curious, does a S\C fit on a stock motor ? TheDamned 94-95 Tech 9 05-10-05 05:42 PM
Modular Depot or Modular Powerhouse chimchim 4.6 Tech 25 04-30-05 08:39 PM
What valve spring is in your forced induction 2v modular? droptop2001GT Power Adders 7 08-26-04 12:15 PM
Few (modular) newbie questions 5.0_GT_kid 4.6 Tech 7 06-08-04 01:39 PM
4.6/5.4 Modular Drive mandrel j.speed 4.6 Tech 0 01-22-04 09:38 AM
