Mustang Forums at StangNet
Ineed a t5 swap kit help!!!!
This is a discussion on Ineed a t5 swap kit help!!!! within the 94-95 Tech forums, part of the 5.0 Mustang category; tranny went south and this is my daily driver I need to find a t5 conversion kit quick cause an ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech
Over 160,000 Members!!
Reply
  #1 (permalink)
Old 07-07-05, 07:05 PM
Official Member
Exclamation Ineed a t5 swap kit help!!!!
tranny went south and this is my daily driver I need to find a t5 conversion kit quick cause an AODE is not going back into this stang any info helps
  #2 (permalink)
Old 07-07-05, 07:16 PM
SeventyMach1's Avatar
Keep it lubed .... keep it straight .... and keep it slow. It will come out.
They should have the parts you need.
  #3 (permalink)
Old 07-07-05, 08:13 PM
Hef5.0weisen's Avatar
Official Member
Location: NJ native, currently NM, and 4 month stints in Middle Eastern countries
got mine from mustang parts specialties
  #4 (permalink)
Old 07-08-05, 12:14 AM
mine came from www.ampperformance.com
honestly though, if i had to do it over again, i would have pieced together the kit. if i had done it that way, i could have used aftermarket parts rather than the stock stuff. (clutch, flywheel, etc.) if you would like me to list everything you need, let me know.
  #5 (permalink)
Old 07-08-05, 11:19 AM
droptopford 5 0's Avatar
Official Member
i looked at the amp swap kit but likewise would like to use an aftermarket shifter, adjustable clutch cable, aftermarket quadrant etc., so maybe it would be worthwhile to list the parts, and its easy to know all the major parts, but its usually the small parts( bearings, c clips, mounting hardware etc...) that get forgotten. im sure many of us would appreciate a complete list
  #6 (permalink)
Old 07-08-05, 11:23 AM
cavscout371's Avatar
Official Member
You can always find deals at junk yards I thought about gettin one out of an older 4-cylinder fox car.
  #7 (permalink)
Old 07-08-05, 11:56 AM
well, the reason i suggested piecing together a kit is because i bought the 94/95 AODE-T5 swap for over $2000 and then replaced everything with aftermarket stuff over the course of the next year. i could have saved a ton of money had i just pieced the swap together with aftermarket parts to begin with. give me a little bit and i'll start putting together a list for you.
  #8 (permalink)
Old 07-08-05, 12:13 PM
Official Member
Yeah thats a good idea thats why I would do the junk yard for the hard to find stuff like pedal assembly, tranny and starter and you would have money left for clutch and better housing etc...
  #9 (permalink)
Old 07-08-05, 01:20 PM
I have had dealings with all of the companies below with the exception of fordpartsdiscounted.com and my experiences with them were problem free. Some of the parts may be able to be found cheaper elsewhere, or may be substituted with other brands or stock parts to save money, but this should give you a solid starting point as to what you need to buy and some places to buy the parts. There may be some small odds and ends that still need to be found, but to the best of my memory this list is complete.
http://www.ultrarev.com
Fidanza Aluminum Flywheel - PN#: 186501 - $319.00
http://www.buyfordmotorsport.com
King Cobra Clutch (Disc, Pressure Plate, Throwout Bearing)- PN#: 7560-C302 - $169.00
http://www.steeda.com
Steeda Tri-Ax Shifter - PN#: 555-7353 - $179.95
Steeda Clutch Adjuster Kit (Quadrant, Cable, Firewall Adjuster) - PN#: 555-7042 - $99.95
http://www.summitracing.com
ARP High Performance Series Flywheel Bolt Kit - PN#: ARP-100-2801 - $7.88
ARP Pressure Plate Bolts - PN#: ARP-150-2201 - $7.95
Energy Suspension Transmission Mount - PN#: ENS-4-1104R - $26.95
http://www.stangparts.com
94-95 V8 T5 Transmission - $750.00
94-95 T5 5.0L Bellhousing - $200.00
86-01 Shifter Bolts - $25.00
86-95 Bellhousing Bolts - $25.00
86-95 Transmission Bolts - $25.00
86-95 5.0L 5spd. Flex Plate - $44.95
94-95 5spd. Pedal Assembly - $175.00
79-99 Leather Cobra Shift Knob - $35.00
http://www.50resto.com
1979-04 Lower Shifter Boot - PN#: LRS-7277 - $36.95
1994-98 5-Speed Shifter Boot & Bezel - PN#: LRS-04567CAA - $194.95
94-95 T-5 Steel Bearing Retainer (Transmission may include this already, check first!) - $48.95
http://www.fordpartsdiscounted.com
94-95 Pilot Bearing - $14.42
94-03 Release Fork - $26.76
Other necessary parts:
T4M0 5spd. EEC (Necessary for perfect driveability)
Manual Transmission Harness
Dust Cover for the bellhousing to cover the clutch cable and fork
Total - $2412.66 (Almost exactly what i paid for my complete swap with all stock parts from ampperformance.com)
If you have any other questions about anything, feel free to drop me a PM.
  #10 (permalink)
Old 07-08-05, 01:37 PM
FYI:
I guess that's a decent deal on T-5's from "stangparts". But you can get a reman from http://www.phoenixhardparts.com/ for $695. You can also opt for a warranty. Talk to Matt.... the GM.... and see if he will accept the AODE as a core. I'd give them a call, too.
  #11 (permalink)
Old 07-08-05, 03:16 PM
toplessmustang's Avatar
Official Member
got everything for my swap off ebay.around $750 with new clutch,pp,flywheel.
  #12 (permalink)
Old 07-22-05, 02:33 PM
Official Member
wow, thanks guys, i appreciate the help and will keep you posted if i make any kind of progress over the summer
  #13 (permalink)
Old 07-22-05, 05:07 PM
HISSIN50's Avatar
"How long do you think it'll take me to get any help?" --Richard Harris
That is a great list Green 94.
FWIW, one should be able to get a new stock flywheel for ~100 beans from D&D (we cant all afford nice alum flywheels).
  #14 (permalink)
Old 08-03-05, 12:51 PM
95BlackTan50's Avatar
Official Member
Awesome list Green 94. I'm going to FFW in Bristol this weekend looking for some parts for the swap. Since the T5, Bell Housing and Pedal Assembly are unique to 94-95 cars, does anyone know if there is a good way to tell the difference between the older and newer parts? I know that the T5 output shaft is longer by about 0.7 inch and I would expect the bell housing to be longer by about the same so a side by side comparison would be easy. I'll have a tape measure with me just in case.
Are the Ford part numbers marked on these parts? If so, then I would expect them to have the F4 designation to tell me if it's a 94/95 part. I do have a cross reference of the Borg Warner part number so that may be an option for the T5.
Also, from other research I've done on the it LOOKS like the V6 T5 is the same except for a couple of the gear ratios. Has anyone ever used a V6 tranny for a V8 T5 swap?
Thanks for any information.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Anyone have problems with Mr. Freeze kit? ProCharger GT 4.6 Tech 29 10-29-09 10:13 AM
SHM stroker kit, results... help. johnny98 4.6 Tech 33 04-18-05 07:28 PM
MPH Mongoose Kit vs. Vortech Tuner kit MidnightGT 4.6 Tech 14 04-18-05 07:31 AM
Mustang Depot Kit 65straightsick Classic Tech 4 07-06-04 09:12 PM
