Mustang Forums at StangNet
trickflow stage 1 or fms e303?
This is a discussion on trickflow stage 1 or fms e303? within the 94-95 Tech forums, part of the 5.0 Mustang category; time to change the timing chain,so that means cam swap.im looking for one that will be blower friendly for when ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-03-05, 07:13 AM
94opalgt's Avatar
Official Member
Cool trickflow stage 1 or fms e303?
time to change the timing chain,so that means cam swap.im looking for one that will be blower friendly for when i put one on the car,i know the e303 is but im not sure about the tfs.any help guys?
  #2 (permalink)
Old 08-03-05, 07:58 AM
Killercanary's Avatar
The car that set the bar.
The e303 is probably one of the most notorious cams you can put in our cars to cause idle problems. It is sometimes a hit or miss thing, but more often than not it WILL cause the "surge and die syndrome."
  #3 (permalink)
Old 08-03-05, 08:25 AM
94opalgt's Avatar
Official Member
all right,thanks killer.i'll just scratch that one off the list.so that just leaves one,unless someone else can chime in here with another option?steeda #19 maybe?
  #4 (permalink)
Old 08-03-05, 11:19 AM
Go with a custom ground cam that way you can get all you can out of that a lil magic stick. Its def. well worth the money that you spend and plus they can make it sound really radical to. Dont get me wrong or nothing the tf stage 1 cam is a good cam if you put some 1.7 roller rockers on it you get almost as much lift and duration as mine. Yet the lobe seperation isnt the same the tf is a 112 and mine is a 110 that is where you get the lobe sound at.
  #5 (permalink)
Old 08-03-05, 01:54 PM
94opalgt's Avatar
Official Member
ok but the springs on my heads are omly good for about 540 lift.with the 1.7's wouldnt that put me over on tfs cam?im not sure how you go about figuring that out.if its 498/512 with 1.6's what would it be with 1.7's?over 540 right?i am new to this but i am slowly learning,i hope.
  #6 (permalink)
Old 08-03-05, 02:01 PM
rio95's Avatar
Official Member
530/544
Pretty Close.
  #7 (permalink)
Old 08-03-05, 02:43 PM
CManT1914's Avatar
Official Member
Quote:
You can do like me and put split ratio rockers on (even though I have upgraded springs, good for .600" lift) and run 1.7 on intake, 1.6 on exhaust. This puts it at .530" intake, .510" exhaust.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stereda #19 vs trickflow stage 1 cam (Help) Darek78 94-95 Tech 4 05-02-05 08:09 AM
Best cam choice for twin-turbo...E303 or TFS STAGE 1?? IMPORTSMOKER Power Adders 7 12-11-04 09:16 AM
Trickflow Stage 1 Black Sun 5.0 5.0 Tech 9 08-26-04 02:12 PM
anyone running trickflow stage cam 91lxntch 5.0 Tech 6 07-07-04 07:51 AM
trickflow stage one cam.. 89lxvert34 5.0 Tech 17 05-30-04 07:11 AM
