Mustang Forums at StangNet
Stoping rust
This is a discussion on Stoping rust within the 5.0 Tech forums, part of the 5.0 Mustang category; Hi all... My ride has been hit hard with cancer and I'm about to pick it up from the body ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-21-05, 10:34 AM
Boss 351's Avatar
Here sthhhhhhhheeeve take a picthh of my man flower hmmmthhhhhh
Stoping rust
Hi all... My ride has been hit hard with cancer and I'm about to pick it up from the body shop because I just had the rocker panels replaced. So far the floor boards and what not are okay but do have a layer of rust.
I want to know what's the best method to stop the rust? This car has not been maintained properly and has been used for 13 cold and hard quebec winters. I won't be using this thing for winter but I want to stop the rust since it will slowly eat away at the metal, even if the car is stored.
First I was thinking about scraping off the rust scales, painting the suspension parts (for a clean look) and getting the entire underbody coated with oil as well as inside the door jams and hidden areas.
Then I thought about cleaning off all the floor boards by removing as much rust scales and using a very good rust paint like POR or whatever, and getting the other stuff (that we don't see) oiled. But I'm wondering if the paint will just hold the humidity in the rust and just basically advance the corrosion where an oil coating will "drain" out the humidity and freeze the rusting.
arrrghhh! Living in the snow belt sucks for this...
  #2 (permalink)
Old 09-21-05, 11:01 AM
88GT17MA's Avatar
Official Member
You need to remove the rust entirely. Sand/scrape it off first until you get down to fresh metal, and then prep and paint it. There are certain types of paints and coatings. Some just add a protective layer, some just look nice, and some actually have rust preventatives in them. I personally wouldnt oil the car like your saying.....
  #3 (permalink)
Old 09-21-05, 12:51 PM
PuterAmI's Avatar
Official Member
Do not oil.
Once you clean to bare metal, use etching primer.
You can also look at POR-15 and other types of coatings sold out of Eastwood Company.
  #4 (permalink)
Old 09-21-05, 12:58 PM
srothfuss's Avatar
Last night I stabbed the same guy 7 times in a row.
If you want to prevent future damage, invest in some POR-15 (it isn't cheap)
  #5 (permalink)
Old 09-21-05, 02:04 PM
Boss 351's Avatar
I called a POR-15 rep... I will get some Marine clean to make sure the underbody is free from oils and whatever after I'm done scraping the metal to make sure there aren't any loose scabs or anything. Then I'll have to apply some metal ready and once all that dries, finally a coat of POR-15 black paint...
POR15 isn't that expensive but sure will be A LOT of work though!
  #6 (permalink)
Old 09-21-05, 02:40 PM
9350coupe's Avatar
Official Member
That stuff works great
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
got a new plan, and some questions about rust sealers and such. hungrymonkey Classic Tech 5 09-20-05 12:58 AM
What do you guys recommend I do with this rust? NasaGT Classic Tech 24 12-05-04 01:08 PM
WTF ? rust emitting gas bubbles under my bran new paint 68 & 00 GT Classic Tech 25 06-18-04 12:10 PM
Trunk rust -- how to fix? (Pics inside) iamadonut Classic Tech 8 04-21-04 03:56 PM
Undercarriage rust pheare 5.0 Tech 9 04-18-04 10:44 PM
