Mustang Forums at StangNet
Steering box and steering column for my 67
This is a discussion on Steering box and steering column for my 67 within the Classic Tech forums, part of the Classic Mustangs category; I had thisproject car on the back burner but it seems I may have to drive it sooner than later. ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Classic Mustangs > Classic Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-28-05, 01:57 PM
Official Member
I had thisproject car on the back burner but it seems I may have to drive it sooner than later. But I need a steering box and steering column. My question is what year(s) mustangs are compatible with my 67? I plan on trying to get one from the junk yard. And I can all but guarantee there will not be any 67's out there. SO I am hoping I can use one out of a 5.0 or some thing. Please advise.
  #2 (permalink)
Old 09-28-05, 02:01 PM
Edbert's Avatar
There were two different ones in 67, and which date the newer ones were used depends on which factory
Basically they have long-shaft (early) and short-shaft (late) versions. Mine was a San Jose car made in November 1966 and it had the long-shaft.
Have you priced new steering gearboxes?
  #3 (permalink)
Old 09-28-05, 02:54 PM
Official Member
Not yet, but I have heard from other folks that they range from 500 to 700 bucks. If possible I would like to upgrade the steering, seeing as I am planning on putting a 5.0 engine in it eventually. But at this point I just want to fix the steering the most cost effective route.
  #4 (permalink)
Old 09-28-05, 03:27 PM
yeloxr7's Avatar
Official Member
Borgeson "remanufactured" steering gearbox for my 69 Cougar was about $365. Use with a late 67/68 column.
www.borgeson.com
  #5 (permalink)
Old 09-28-05, 05:48 PM
Official Member
You want one of the 67-70 boxes with the quicker ratio......
Look here for compatibility info.
http://www.mustangsandmore.com/ubb/D...BoxRatios.html
  #6 (permalink)
Old 09-28-05, 05:52 PM
Official Member
Oh, and I forgot, if you get it out of a Mustang, get the column also. 68 Tilt or non-tilt fit in addition to the 67. I would get a collapsible as well for safety reasons.
  #7 (permalink)
Old 09-28-05, 08:26 PM
65ShelbyClone's Avatar
Quote:
If he gets the '68 column, he'll also need a '68 brake pedal. The '68 pedal has a different bend to clear the fatter collapsible section at the bottom.
  #8 (permalink)
Old 09-28-05, 09:36 PM
Tim65GT's Avatar
Official Member
Garage
Sorry to highjack, but I have a collapsible '68 column I was planning to swap into my '65 when I replace the steering box. Should I be looking for a new brake pedal for clearance? I have an Auto, so no clutch pedal.
  #9 (permalink)
Old 09-28-05, 10:40 PM
CochinoFilipino's Avatar
I'm in the bay area, ,,,,I have a 68 mustang for parts. It's manual but it may have been converted to manual, don't know.
I believe 68 is when ford started with the collapsable column. I was going to swap it into my 67 but it's not a big deal to me, just more work to do.
PM me if you're interested, I have the column, box and the pedal and whatever else you'd need. But you'll have to remove it all yourself. That would be a good thing, so you know how it should go in.
Anyone know what a fair price is for a 68 column?
  #10 (permalink)
Old 09-29-05, 12:49 AM
Quote:
I never tried it; all my research and frustration deals with '67-68s. I'm pretty sure you will need a different pedal, though.
  #11 (permalink)
Old 09-29-05, 07:13 AM
Edbert's Avatar
I have an AT-67 arrangement, I took the collapsible part of the 68 column and adapted a 67 top so i could use the woodgrain steering wheel. The job was trickier than I thought and I am considering going back to the heart peircing solid shaft but the rack and pinion I have (TCP) is for the collapsible style shaft...sigh.
So I continue with adapting the 68 column and internals with the 67 upper-collar. Now you tell me I need new freaking pedals? AAAARRRRGGGGHHH! You sure?
  #12 (permalink)
Old 09-29-05, 12:03 PM
Official Member
CochinoFilipino
Check your PM..
  #13 (permalink)
Old 09-29-05, 01:55 PM
Quote:
No, I'm not 100% sure. I found tons of BS information regarding the subject. I read and was told that both pedals are different for a '68, but I installed a '67 clutch pedal with no problems. My factory '68 brake pedal has a large bend in it while '67s do not, but I've seen pictures of '68 pedal assemblies that are the same .
  #14 (permalink)
Old 09-29-05, 02:58 PM
Edbert's Avatar
Cool, I'm keeping my fingers crossed. This weekend looks like it will be the first Saturday of less than 98 degree temps in over 5 months, I am hoping to finally get some more work done on the old girl.
I'm going to push the steering column towards the top and see what fits. As always I'll post results here.
  #15 (permalink)
Old 10-04-05, 08:30 PM
Quote:
The bend appears to be the same in my both my 67 and 68.
Both cars are automatic. The 68 has power assist, the 67 does not.
Anyone else have info on this?
  #16 (permalink)
Old 10-04-05, 08:39 PM
Edbert's Avatar
Oh crap! I said I'd check mine out and post results and or pics. Well i checked it out and took pics, I just forgot to follow through.
let me say that for a November 1966 Stang (67 model year) from San Jose the 1968 column (of unknown date and factory) fit fine beside my factory PDB pedal. Was approximately 7/16ths of space at the closest point.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Does anyone have a 19:1 Steering box? XXBULLETSXX Classic Tech 13 05-14-05 10:37 AM
steering box question.... boingo Classic Tech 3 05-07-05 06:27 PM
Anyone else suffering witha whining power steering pump? sphinx 5.0 Tech 2 05-04-05 10:19 PM
How do I get the steering column apart from steering box? 67GTFastback Classic Tech 4 08-21-04 10:59 PM
'68 Steering box and steering column in '65? Loup-garou Classic Tech 2 08-07-04 10:45 PM
